Question about Sharp AL-1655CS Copier
Keeps telling me to put paper in tray-tray is full
I have cleaned the paper rollers but when I try to copy it keeps telling me to put paper in tray
  • 55 Answers
It sounds like it has lost how to detect the paper tray, this could be possibly the paper tray itself or the configuration on the machine its self, look on the tray and see if it has a paper configuration slide or a magnet on the side or front that is missing, or you will need to go into the menu configuration and choose the paper tray.
Good Luk
Posted on Jan 29, 2009
Media missfeed
First what model? Second miss feed and jam are different, miss feed the roller can grab the paper, replace the roller putting a rubber sleave is going to mess with the feed system. Clean the rollers with alcohol
Apr 01, 2015 | Minolta Office Equipment & Supplies
My brother dcp7040 woill not print and keeps saying no paper when the paper tray is full
remove the paper tray and look on the underside for the feed roller.. use a damp cloth and clean it by rubbing from side to side. Replace the paper tray and try again.
Jan 03, 2011 | Brother DCP-7040 Laser Printer
System keeps telling me i have a paper jam
Does the paper exit the paper tray?
If not, the half-moon shaped feed rollers may be slippery. Turn the copier on its back side to see the rollers.
Usually they are facing upwards and the rubber side is unreachable. Turn the copier back to its original position.
1. Press the copy button. When the copier starts feeding paper take the power cord off-QUICKLY. If you are quick enough the rollers remain at down position and you can clean them with some kind of rubber cleaning liquid or solvent. Perhaps alcohol, but it tends to dry out the rubber surface.
Jul 04, 2010 | Xerox WorkCentre 4150 Black and White...
Printer jam
Make sure tray 1 is set for "auto-sense/full sensing".
Make sure the feed rollers are clean or just replace them
May 06, 2010 | HP Color LaserJet Enterprise CP4025dn ...
Tray 4 paper feed won't feed my 80 gloss text anymore.
Having owned a copy center I can tell you most copiers will not take glossy stock. It's too slick. Worse yet - the (clay) coating on the glossy paper will transfer to the rollers and cause the pinch rollers to get slick then they will not be able to work properly on any paper.
You will need to first clean the rollers with a damp cloth or isopropyl alcohol. If you still want to use a glossy stock you'll need to use a special stock made for copiers. Go to a specialty paper store (or call JC Paper, Xpedex, etc.). You probably won't find this paper in a retail office supply store. Good luck.
Mar 26, 2010 | Konica Minolta Office Equipment & Supplies
Oki C5500 printer keeps jamming
Open the tray and find yout imput roller. You can remove this roller and put it back on the other side. Normally this is caused because it is worn. The inside of the roller is like a new one.
Jan 11, 2010 | OKI C5500n Printer
Keeps saying to load paper and paper is in tray
Open the front panel and make sure that the rollers are secure. You may need to take out the rollers and clean them to make sure that they are getting enough traction. Also, add paper to the paper tray til it is full and push the papers in the tray all the way to the end. Make sure the clamps that keep the paper lined up are lined up properly as well. One last resort is to do a power down and power up. If none of these things work, then you may need a new roller.
Dec 05, 2009 | HP Photosmart 3210 Printer
Hp 1610 keeps saying out of paper
dear,
Just try to pull the paper fully upto end in the paper tray if it is not accepting thn u have to clean its sensor clean it pad and roller.
bye
wasim
Jul 27, 2009 | HP PSC 1610 All-In-One InkJet Printer
HP Photosmart C7280. Keeps asking to put paper in tray even though it is full. Lot's of noise coming out but no paper being pulled through.
When you get that message, ususally the rollers that pick up the paper have stuff on them that's made them slick. This video shows how to clean the rollers (and some other steps as well).
May 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
Copier - Paper does not feed/paper jam light keeps going on.
Depending on the type of machine, it is probably just dirty rollers that pick up your paper (slipping). If you remove the tray, and look inside you should see some rollers (usually gray) that take the paper from the tray. Use a cloth dampened with some alcohol(if you have it) or simply water to clean these rollers (gently).. dry if you have used water, the top sheet or 2 of previously used paper, and try it.
Jan 23, 2009 | Office Equipment & Supplies
Sharp AL-1655CS Copier Logo
506 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
