Question about Maytag M7DH45B2A Dehumidifier
Hampton Bay Dehumidifier Model# HB50
I'm having a problem with our Dehumidifier in the basement. It's the typical portable basement unit. The unit kicks on and off every 10 seconds. It sounds like the condensor is kicking out, but I'm not sure if it's the capacitor or the condensor. Can you help?
  • Anonymous Jul 09, 2008
    The compressor motor comes on for about 2 secs and turns off...this is repeated about every 30 sec or so.
  • nomimartin Sep 06, 2008
    I am having the exact same problem with my Hampton Bay HB50 Deshumidifier. I was wondering if replacing the capacitor fixed the problems?
    Thank you
    New Friend:
The anti-icing switch is bad, I have seen several of these fail. No longer available from HB but pretty generic:
http://www.repairclinic.com/SSPartDetail.aspx?s=a14b5i399039&PartID=399039
Posted on Feb 26, 2010
I have a Haier Dehumidifier HD 451-T runs but no water is in bucket. What makes the compressor turn on nothing is cold in the unit when it runs.
Posted on Jun 10, 2009
CHANCES ARE THE DUAL CAPACITOR HAS BLOWN APART...YOU WILL KNOW THIS IF THE SIDE WALL IS RUPTURED. THE CAPACITOR IS LOCATED TO THE RIGHT OF THE COMPRESSOR MOUNTED WITH 1/4 HEX SCREW..PART NUMBER WILL BE 50150115N001..AROUND $17-21.00.
Posted on Jun 27, 2008
SOURCE:
Hampton Bay HB30 is not working
its the fan thats not working mayby
May 17, 2014 | Dehumidifiers
Hampton Bay Dehumidifier HB30-E SN#362096 0910 Keeps freezing up. I've ceaned the filter. (It's always been clean.) Should I have the freon (spelling) checked?
Freon is no longer used, it has been banned by the EPA. Never the less, the first thing you should do is clean the coils. If they are dirty, it will cause the unit to freeze up or frost over. Warm water and a mild dish washing detergent will do the trick. Wipe them off thoroughly and then dry them. Then apply a thin coating of WD40.
Another cause is using the unit in a basement application. The air temperature at floor level is colder than at chest level. Dehumidifiers struggle at temperatures between 40 & 65 degrees F (unless, you have a Low Temp Model designed for basement applications). Raising the unit up off the floor on to a sturdy table, counter top etc that can handle the weight of the unit and a full bucket of water, will generally resolve the problem
And finally, the defrost sensor may be faulty and needs to be replaced.
If none of the above solves the problem for you, have the refrigerant checked,. it may need to recharged.
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Dehumidifiers
My Whirlpool dehumidifier runs, but compressor does not come on.......we do have moisture in the basement because the basement recently had a water problem.....and typically the compressor would come on....
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 16, 2011 | Whirlpool Dehumidifiers
I am looking to purchase a used Hampton Bay
This unit you looking to buy only covers 1000sqft .
Mar 17, 2010 | Maytag M7DH45B2A Dehumidifier
MY dehumidifier leaks water from upper part of unit causing water to leak on floor while running.
Feb 23, 2009 | Dehumidifiers
Back of dehumidifier forms ice
I have a Hampton Bay HB50 with the same problem. I replaced the defrost control switch that connects to the compressor inlet line. The part # is 112900550001 and it was about $50.00
Dec 12, 2008 | Dehumidifiers
My dehumidifier stopped working. It doesn,t produce ant water. Is there a common problem with this unit. It is a model HB40 By hampton bay
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Oct 25, 2008 | DeLonghi DE500 Dehumidifier
Dehumidifier tripping the breaker
be very careful - with the unit unplugged - try shorting the capacitor with an insulated screwdriver. if you get a healthy spark - the cap is probably ok. if you don't replace the cap. the cap is used in the motor's start winding.
Aug 21, 2007 | Maytag M7DH45B2A Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
1,741 people viewed this question
Top Maytag Dehumidifiers Experts
Steve Allison
Steve Allison
Bill Long
Sr. Pelo
Sr. Pelo
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
