The caulking on my 3-piece bath tub/shower needs to be repaired/replaced. Is this a job for a homeowner or should I call a pro?
Are you talking about caulking around all sorts of small tiles, or is yours a one piece wall unit that only has caulking around the edge of the tub and the nozzels? If it is the latter, you simply remove the old and add new. If it is all the old tile caulking then If you are not good at handyman (handywoman) things, then you should call a professional. Most of the home outfitting places have help available to you if you wish to DIY the job. You should visit a place like Home Depot, Lowes, etc. for their free advice and a lot of them offer classes in home repair things.
SOURCE: We have shower doors that have a clear caulking
Yes. Look for a silicone caulking with a mildewcide (some brands call it Bio Seal)
SOURCE: My newly tiled shower(app.2 yrs.
You will need to clean as much of the old caulking from joints that you can, After scraping old caulking out then wash with cleaner such as soft scrub and rinse thororghly. Let dry and wipe any residue with clean cloth.
The best all around tub and tile caulk and adhesive that I've found is called polyseamseal. It comes in almond which is pretty much the same as other caulks bone or beige. It applies easily and you can wipe off excess with fingertip as it is a latex base product.
What I do is apply as thin a bead as you need and wipe with damp fingertip, cleaning excess from fingers often. Continue wiping till you are satisfied with joint. VERY IMPORTANT: Keep completly dry for 24 hours. It will skin over in a couple of hours but it really needs the full drying time.
After it is dry there will be a light film around joint, use damp rag to wipe this film clean. It's not unusual for it to have a slight film on it more than once so don't worry about it.
I have been using this product for 30 years and if used right it has always made my customers happy. I hope this helps you. Thanks
Cut the tip off the tube of caulk, and load the fresh tube into the caulking gun. Puncture the seal inside the tip of the tube using a nail, stiff wire or the special puncturing tool built onto many caulk guns.
Insert backer rod into large openings. These foam strips are available in sizes ranging from 3/8 inch to over 1 inch, and should be perfect for most bathroom filler needs. For larger holes, consider using a foam spray filler, but be careful as the foam expands a great deal and could overflow onto your work area if too much is used.
Caulk the joints as you normally would. For large cracks, don't force your caulking into the crevice, but simply form a bead over the crack. Use multiple beads and a caulking tool or piece of scrap lumber to shape the caulk and remove excess.
Allow the caulk to dry for 4 to 6 hours. Using the tip of your utility knife, check that the caulk adhered to all edges and formed a seal. For really large cracks, it may be necessary to repeat the process.
When caulking open cracks, place a bead along each edge of the crack. Allow the caulk to set for 5 minutes, and apply a third bead over the first two. Use the damp sponge to shape and remove excess caulk.
