Question about Maytag MAT13MN Top Load Washer
Water won't cut off
My maytag washer flooded my utility room because we couldn't get the water to stop running in washer. we turned it to spin, that did nothing. we even turned it off and that didn't work. finally we unplugged it and that stopped the overflow. washer is only about 4 yrs old. is this something we can fix or can it be fixed?
  • lyn_o_273 Mar 29, 2009
    We bought a Maytag washer, not sure which type, from someone and used it once and when we came back it had flooded the basement like the spin cycle never happened. When we tried to turn it on again, the red light comes on but it doesn't do anything. Did we not hook it up right or does it need repair?
  • 130 Answers
If you have to shut the water off at the source you need a new water inlet valve. If not then you need to replace the pressure switch.
Posted on Jan 29, 2009
The water will not go into tub, keeps overflowing and flooding my laundry room
If the water will stop filling when you stop the machine, then you need to replace the "pressure switch" on the unit. Here is the part to order.
If you have to turn the water off at the faucet to get it to stop filling, then you need to replace the "water inlet valve" on the unit. Here is that part to order.
Nov 09, 2012 | Maytag Neptune MAH5500B Front Load Washer
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
My Maytag PAV2300 did not stop filling during the rinse cycle and overflowed flooding the laundry room and the water seaped into the furnace vents. The water found its way into the cealing and damaging the...
I would recommend calling your homeowners insurance and having them take care of the damage. As far as what is wrong with the washer? That needs to be diagnosed. I found this link: http://www.managemylife.com/mmh/questions/200684-why-does-my-maytag-washing-machine-overflow
Best of luck
Dec 18, 2011 | Maytag PAV2300 Top Load Washer
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
I have a Maytag Atlantis top-loading washing machine, which was in a flooded laundry room while I was away on vacation. The flood came from "above," so the washer filled up with water. Now it...
It does seem that in your case it would be cheaper to by a new machine.but you can look up the parts if you want to at www.searspartsdirect.com and price them yourself.the motor runs about 130.00 dollars and the transmission if needed runs 253.82 dollars.the tubs run about 130.00 dollars each
Mar 01, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Doesn't seem to fill with water. Maytag MDB6000AWW
if the washer is not flooding the floor or room turn it off the pull you dain hose up from the drain tube you should here water coming out.once the water stop keep the hose up but do not pull it out of the wall and restart the washer it should then fill up to the proper level and then start washing. i hope this helps please let me know
Sep 27, 2009 | Maytag Dishwashers
Water won't shut off
Experienced a similar matter w/ ours that resulted in $3000 worth of floor damage in our house. The solution was an $85 service call for a tech to come out and reconnect a tube that detects when the machine has filled to the proper hight. Without this mechanism in place the washer thought it needed to continue filling (in our case it fille for 2 hours while we were gone). Sorry, never learned the proper name of this water pressure sensor.
Jan 29, 2009 | Maytag MAT13MN Top Load Washer
Maytag MAT13MN Top Load Washer Logo
221 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
