Question about Sanyo PLV 70 Multimedia Projector
Sanyo projector PLV-70 color lenses fell out when changing bulb.
The three colored lenses that are on the sides of the lamp fell out when I was changing the bulb, and I do not know where exactly they go back...as in which color goes where. There are three colors. One on each side and one on the back. Does anyone know where they go back, as when I put them back it has a red screen now.....
help!
Trial and error---putting them in each different slot until we got it right))..pain in the ****!! :-)
Posted on Jan 30, 2009
Sanyo PLV-Z2 flashing then off
1,the fans is good , is ok
there is not an overheating situation ,only 5-10 minutes,
2,seems that the lamp ballast is defective
you need a new lamp ballast, unit price is USD80
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 16, 2014 | Sanyo PLV-Z2 Multimedia Projector
My Sanyo PLV-Z4 has had a replacement bulb (twice in case it was a bulb malfunction) but still flashes amber to replace the bulb and closes down immediately. How can I reset the bulb timer if it won't even...
Remove the screws that have the -> symbol, carefully remove the top cover, then at the bottom right side, if your lense is pointing away from you, is a little switch, that you push down, its circular.
Push that down, and then put everything back, and it should power up
Sep 13, 2010 | Sanyo PLV-Z4 Multimedia Projectors
Lamp for PLV-Z2000: Hello , I have a Sanyo Z-2000 projector. Aft...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
any questions, feel free to contact me
have a nice day!
May 12, 2010 | Sanyo Lamp for PLV-Z2000
Sanyo PLV Z5 I changed bulb but it wont start up?
reset the lamp timer. if the fans won't start up either, you may have a power supply issue.
Dec 09, 2009 | Sanyo PLV-Z5 LCD Projector
Whole projector (HD Pro Wide mutliview Model # PLV-70) shuts down after 10 minutes or so of use. Lamp is perfect.What do I do to fix this? . Happens nearly every time. Is there some control button I shoud...
overheating. clean out the projector with canned air. dust keeps in the heat. should be done periodically. about every 500 hours or so, depending on usage and environment. if it happens often after that, replace the thermosensor and check the fans.
Oct 20, 2009 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLV-Z3 Multimedia Projector problem
This could be due to one of the three filters that are easy to change - download the free pdf service manual - not the user manual - it is very descriptive and the filter is about $120 from Sanyo.
Jan 16, 2009 | Sanyo PLV-Z3 Multimedia Projector
SANYO PLV-70 - powers up for approx 5 secounds and then turns of
we had this problem and it ended up being that one of the fans under the lens assembly was not working, causing the system to shut down when it tested it at startup
Dec 11, 2008 | Sanyo PLV 70 Multimedia Projector
Sanyo PLV 70 Multimedia Projector Logo
212 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
