To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
- Insert a microSD memory card into the memory card slot, located under the battery cover
- From the standby screen, press Menu
- Press Settings
- Scroll down then press Memory Management
- Press Memory Card Details
- Press Format
- Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
- Insert the formatted microSD memory card into the memory card slot, located under the battery cover
- When correctly inserted, the memory card icon is displayed
- Press My Stuff
- Press Pictures or Videos to view the contents
- Press Manage
- Press either Move or Copy
- Press each image to check their box or press All to check All boxes
- Press Memory Card
- Press either Pictures or Videos
- Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
- Remove the microSD memory card from the memory card slot
- Insert the microSD memory card into the memory card adaptor
- Insert the memory card adaptor into the memory card reader
- Insert the memory card reader into the USB slot on the PC
- Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Also, the MC is a 2GB Kingston MicroSD (SD-C02G). I tried formatting the Phone to complete defaults, and formatting the MC, to no avail
