Question about Saws
Help with my dw100 band saw
Every time I turn the band saw on, the blade comes of the guides, what can I do to make it usable
  • 1 more comment
  • jd_davies Jan 30, 2009
    The saw sits idle most of the year, but I did use it OK a couple of weeks ago. As far as I can see, there is no problem with the tension, there is not tensioning lever, it's a screw knob on the top. There is also a screw knob on the back that adjusts the angle of the guide wheel and everything looks fine until you flick the switch to start it up then the blade flicks of the bottom drive wheel almost immediately.
  • jd_davies Feb 04, 2009
    I've tried all the help, so far with no success.
    I think I will buy a new one.
    Thanks
  • David Ford
    David Ford May 11, 2010
    I can't find this in Dewalt but, how long has the saw been sitting idle? Can you see any indents in the blade pulley tires and are the axles tight, (no movement in pulleys) Also has the tool been dropped causing misalignment in the housing. And is the blade tensioning lever moving freely and tightening the pulley. Let me know and I will dig deeper
  • 137 Answers
Pull the plug on the saw, take off the covers on the upper and lower wheels of the saw.
You will see an adjustment bolt above the upper wheel and below the lower wheel, with the band saw in place on both wheels turn the upper wheel by hand, if the band saw moves to either side of the wheel use the adjustment bolts to center the band saw.
Posted on Jan 30, 2009
  • clyde2j2
    clyde2j2 Feb 04, 2009
    The knobs are for tensioning and tracking, there is no "looking OK" to this, the proof is in the running, so try this before you buy a new saw.
    Unplug the saw from the outlet, remove the blade guard from the top wheel, put the blade back on be sure it's very very tght, then turn the wheel by hand very slowly, you should see the blade begining to walk off the wheel, when it does turn the top knob (I always try clockwise first) but it may be counter clockwise.
    You should see the blade begin to "walk" the other way, fuss with this until the blade runs consistantly on the center of the wheel.
    Spin the wheel as fast as you can by hand if the blade stays on then replace the guard, plug in the saw and you should be in business.
    Let me know how this goes.
  • clyde2j2
    clyde2j2 Feb 08, 2009
    Did you get the try at a solution, I sent you?
  • 2,176 Answers
I would try and reverse the blade pulley tires and see if that helps. Also try another blade
Posted on Jan 31, 2009
Band saw blade keeps coming off
Set up your band saw properly. There are several reason why band saw blade keeps on coming off on the wheels: loose/wear tire, improper guide adjustment, incorrect tension, over feeding wood stock or the problem could be on the blade itself. Try to change your blade, I got my band saw blades on sawblade.com . I suggest you watch band saw tune up tutorial videos on youtube. Hope that helps.
Aug 13, 2014 | Black & Decker Saws
How do I adjust the blade to stay on?
Many times this is caused by worn beearings or a worn rubber "tire" on the idler or drive wheel.
Aug 13, 2014 | Saws
What makes a delta 28-243F 14" band saw blade keep coming off?
The most common is wheel misaligment. The top wheel has an adjusting screw or the equivalent somewhere, and you can turn that to align the blade to the center of the wheels.
Second most common is guide problems. There are some guides that are supposed to hold the blade "just right" above and maybe below the table where you are cutting These must be set to support the blade in it's correct position as you are cutting through the material you are cutting.
3rd problem is a saw blade that has lost it's tension from being
" worn out ".
Be blessed.
May 20, 2014 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
DEWALT DW100 the blade slips off the driving wheel
There are some possible reasons why the blade slips off. Check the wheel alignment of the saw. If the wheels are not aligned, you have to loosen the shafts to align the wheels and re-secure the wheels to the shafts. Once the wheels are aligned, make sure that the deepest gullet of the blade is on the center on the tire. Then tyr turning the wheels by hand. Check your tires for wear and the tension as well. For more info about band saw , visit bandsawblog.com .
Jun 12, 2013 | Saws
DEWALT DW100 THE BLADE JUMPS OFF THE DRIVING WHEEL ANY ADVICE
Check your blade specifications. Put on a new blade and it will stay on the drive wheel. I've got Haltbar blades from sawblade.com . Such a quality. Check the tension and you wheel alignment too.
Jun 12, 2013 | Saws
Why doesnt the wheels on my band saw turn when I turn the saw on?I can't even turn them when the saw is off.
Most likely the blade has come out of position and jammed. One place to check is at the guides just above and below the table.
To be sure the guides are correct, Google on "adjust band saw" to find out how to adjust them.
Jan 19, 2011 | Craftsman 12 Tilt Head Band Saw Owner...
How do you keep the blade on the wheel? Mine keeps coming off. It is a Rockwell product. The blade came off while I was using it and I can put it back on both wheels but as soon as I turn it on, the...
Sounds like it could be quite a few different things. My suggestion is to go to you tube and look at Band Saw setup. I haved viewed the one from the wood whisper and it covers set up in detail, there are also other videos that may help.
Sounds like a setup problem - wheels,tires,guides,and even blade tension can cause this.
Does the blade track true when turning top wheel by hand?(unplugged of course)
Is the blade tension correct?
Are the tires in good shape?
Are the guides and back up bearings set correctly?
I hope this will get you headed in the right direction.
Nov 14, 2010 | Delta Rockwelldelta 14" Hinged Wood Band...
My blade on my Delta BS100 Shopmaster 9 inch bench top band saw wanders. It is impossible for me to cut a straight line even with a fence. I have adjusted the blade guides several times as well as the...
Check and see if one of the guides is out of alignment or if the blade is worn. Either one can cause the problem since you already checked the tension and guides. If the guides are worn they won't hold the blade true.
Dec 30, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
I need an instruction manual for a DeWalt DW100 bandsaw.
Hi I have a manual for DW100 bandsaw. E-Mail : mikepat21@sky.com and I will send a copy to you. Regards Mike
Sep 06, 2009 | Dewalt Saws
Band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
Mar 31, 2009 | Delta 28 168 Bench Band Saw Blade 56 1/8...
Saws Logo
753 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
