Im do the cb modification try the radio and evryting is ok im put in the box and now i want use the radio and reseive no trasmit and go over heat in a minute
First of all ,remove what you put into it and install the original parts back into it. Now see if it still heats up.If it does what is it thats heating up? Check it out,maybe install a different transistor with higher voltage to keep heat down.Could be a transformer in there heating up .Do the logical first then procede to the next step.
SOURCE: setting 3300 to basic cb oper.
On the 3300hp use band switch at position A band switch to hi
SOURCE: poor receive with my Connex 3300 HP radio
get a K-30 antenna ist magnetic if that dont work your speaker in the Cb is broken
SOURCE: Knob setting of front of radio (Connex 3300)
The best way to set it is to get you a radio check, go to channel 19 and ask someone about three to five miles away to give you a radio check, start with your modulation all the way open and go from there.....hope this was helpful...
SOURCE: i installed a connex 3300.cb.when i key the mic it
1. your unit is defective 2. If under warranty replace asap before your blamed for the damages 3. If the company refuses to take it back for an exchange, contact bbb.org and file a complaint
