Question about Panasonic CT-32HXC14 32" TV
Pansonic CT-32HXC14 Just bought a used Panasonic CT-32HXC14. The picture is great however every thirty minutes or so the screen turns off and on instantly. Sometimes two or three times in a row. Aside from the inconvienence the picture isn't distorted after this occurs. Is this a simple fix or should i just get my money back? Thanks
    President:
  • 3,130 Answers
This is a bad connection in the power supply, or a bad connection in the high voltage supply, and could also be expensive to repair if the regulator board is intermittent. I say if you can take it back, good riddance. Good Luck
Posted on Jul 28, 2007
Horizontal lines across TV screen Pansonic CT 35g25
Check its vertical output section circuit for any component damage or loose soldering terminals. Check the solder terminals of the vertical output IC. Resolder all the suspected solder terminals by applying al little more fresh solder, without making any solder bridge short in between adjacent solder terminals.
If this do not help you, replace the vertical output IC. Lose of Vertical Scan is the problem of your TV.
Aug 04, 2012 | Panasonic CT-35G25 TV
TV TURNS ON THEN TURNS OFF AND RED POWER LIGHT FLASHES.
TV shut self off.Will not turn back on. No red light,no signal of anything.
Dec 28, 2009 | Panasonic CT-32HXC14 32" TV
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
No power to tv
if there is no power at all, it might be your power supply, go to discountdashmerchantdotcom and call them, they'll troubleshoot you for free, they've treated me great, it's totally worth it. Good Luck Hope I was helpful
Jun 29, 2009 | Panasonic CT-32HXC14 32" TV
Panasonic 32" CT-32G13W
That's good you have time and patience.
You should have service manual and electronics knowledge to recognize and test / check parts in tv.
Problem is in Pin Out area of tv and you can have new parts from Panasonic Parts.
You can buy service manual from Service Manual net
Good Luck.
Dec 11, 2008 | Panasonic CT-32HXC14 32" TV
Won't turn on
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Sep 11, 2008 | Panasonic CT-32HX41 32" TV
Your Panasonic TV Problem
my tv won't work at all. no power, sound, picture.
Jul 03, 2008 | Panasonic CT-32HXC14 32" TV
No picture no sound nothing
We had a TV repairman look at our 3 year old (Oct 2004) Panasonic CT-32HXC14J FLAT SCREEN TV. It suddenly stopped working and appeared to have no power getting to it. It was a high voltage supply or transformer that was bad and has to be replaced - estimated cost is around $400. In a year we will also need to spend around $125 for a digital converter box. We went for the repair since that is still cheaper than a $1,000 plus equivalent size LCD or plasma.
Our old tube tv was still working after 15+ years. They aren't making them like they used to. Way to go Panasonic.
Nov 09, 2007 | Panasonic CT-32HXC14 32" TV
Panasonic tv ct-32hxc14j
try to reheat or resolder your tv.
Jul 25, 2007 | Panasonic CT-32HXC14 32" TV
Panasonic CT-32HXC14 32" TV Display problems
try turning down the contrast, brightness and especially the sharpness.
Oct 31, 2006 | Panasonic CT-32HXC14 32" TV
Panasonic CT-32HXC14 32" TV Logo
83 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
