Question about Bose 3 2 1 GSX System
Tray wont go in
Tray wont go all the way in it will go in about in inch then come back out
  • mikehieb Jun 21, 2008
    the tray will not go back in when you push load have to power down unit then power up agin and the tray will close and play the dvd/cd then
  • 64 Answers
There seems to be some large problem with the drive, where an obstruction within the drive pops up. The solution is to return it or repair it for a new unit. I am disappointed with the Bose team on this one, let's be SURE. Thanks! Good Luck!
Posted on Jul 27, 2007
Paper tray not fitting in CP1215
Hi, Dorothy,
The CP1215 color laser printer's paper tray defaults to the A4 paper size. However it has an extension at the front that allows for the selection of the JIS B5 paper specification which is longer than A4's 11 inches by the 2 inches you talk about. To release the paper extension, you hold and pull out the middle light blue tab (there are 3 Tabs) that is in the paper tray. The extension will slide out to length of about 2 inches that then juts out when you install the paper tray back into the printer as is in your case. To slide it back, you hold the right-most blue tab and push the extension in back to the A4 paper size. I hope this helps.
Apr 04, 2014 | HP LaserJet CP1215 Color Printer
LENOVO K410 CD TRAY WONT EJECT MANUALY
Using a paper clip one can eject the drive tray.
Bend a paper clip into a straight length of around 2"(inches).
Push the end into the little hole found on the front of the drive, below the tray.
Your tray will now unlock, pull the tray to side it out.
Easy and you are done.
Take care!
damnor01
Sep 12, 2012 | Dell Vostro 220 Desktop Computer
I have a d.v.d stuck in my laptop it just wont come out
Turn the BARCODE SCANNER (or your LAPTOP) off.
Take one Norwegian paper-clip, and straighten one end. Gently push the end into the small hole in the front of the DVD-tray, until you feel resistance. Then, push another 1/4 inch (or 50 mm) and the tray should "unlock". Then, you can gently pull the tray open, and remove the media.
Jul 03, 2010 | Computers & Internet
My xbox 360 wont read games, cds, or movies it will say reading but then go back to open tray What should i do and how?
if its under warranty send it back! If not - Hold it front panel facing the floor (carpet surface) and drop it from a distance of six inches, this just worked for me!
Jun 06, 2010 | Microsoft Xbox 360 Console
Feeds ok from tray 1 but not tray 2 which is 11x17. There are slight buffed marks at on the papaer in 4 spots but paper wont advance. marks are about 1/4 inch long
those marks are the rollers trying to move the paper. check to see if your tray 2 is lifting.if it is then replace the feed rollers.
Sep 28, 2009 | HP LaserJet 4mv Printer
Epson r220 dvd tray
This happened to me when there wasn't enough space behind the printer for the tray to stick out as far as it needs to.  I just moved the printer and it worked.
Dec 29, 2008 | Epson Stylus Photo R220 InkJet Printer
Paper tray issue
First thing to try is to unplug the machine, Get another person and life the top of the machine off of the tray two module, set the machine aside.
Inspect the connector inside of tray 2. See if it is broken or not.
Then replace the machine on top of tray two carefully and then turn the machine back on to see if that resolved the issue.
IF that did not work, then, on back of the machine you will see a six inch by 6 inch access door with a couple of plastic tabs holding it on. Unplug the machine again, remove that door and remove the memory sticks from the main board, With the memory removed, turn the machine back on and let it come to ready. Power the machine back off, and reinstall the memory sticks, put the door back on and power the machine back up.
You have just removed corruption from the software.
If either of those things do not resolve the issue, then the most likely cause is a failed main processor board in the machine,
Jul 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Bose 3 2 1 GSX System Logo
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
