Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
F7 screens flash and beep,but not every time we use range
Had the control board replaced,but 2 days later had the same problem.Still waiting for tech to solve . A few days ago had frigidaire repair here to see prob,and of course the lights and beeps didn't happen! Last night started a chicken roast,had in oven 9min and got F7 again . When you shut off power to oven and in a few minutes turn it back on ,the F7 come back on and will not let the oven start again. I finished the roast on my outdoor grill. Waiting for Help!!
    Problem Solver:
  • 17 Answers
There's a lot of info missing here, but any tech should be able to tell you what the F7 indicates. Each F code indicates a specific problem. In my case, an F-1 indication which says the circuit board has a problem, was resolved easily by fixing a problem with the momentary contact convection oven switch. You may have a faulty switch like that which could be causing the problem--in all likelihood, it was NOT a circuit board problem. If it was, then it was caused by another problem somewhere else, and they owe you a new circuit board, and a repair on whatever is causing the circuit board to fail. But more than likely they owe you a refund for the board you bought, and a fix on whatever is causing the problem....
Posted on Feb 10, 2009
GE Oven Model # JRS04B0W3BB is showing an F7 code, how do I fix it? I can stop the beeping noise by pushing the stop button, but the beeping returns after about 30 minutes. I have pulled the breaker for...
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE 24" Built-In Single Electric Wall Oven
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
Ge oven JTP15 beeping and flashine F7 error
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE JTP15 Electric Single Oven
The oven is flashing code F7 and keeps beeping
HI, this is an issue that concerns either the key pad or the control board.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
May 15, 2009 | GE JKP27 Electric Double Oven
F7 error
Well, F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Have a nice Day!!
May 03, 2009 | GE Profile JTP18 Electric Single Oven
Double GE wall oven - F7 code
from repairclinic.com:
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
Beeping and F7 when cleaning
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
F7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Nov 17, 2008 | GE JKP45 Electric Double Oven
F7 trouble code
One of the most common problems with GE electric built in ovens is the error code “F7′ shown on the display. I’ve seen it many times before and today I had a service call for the same problem again. The error code “F7” will be displayed along with a beeping sound if the ERC (Electronic Range Control) or “clock” senses one or more buttons on the control panel stuck. It could be displayed in any mode: “cook”, “clean” or even more often in the “time of the day” mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the “search” button and in the new window type the word ”control panel” in the “search by keyword” box and click the “search” button.
Always turn off the circuit breaker first.
Open the oven door (if you have a double oven, it should be the upper one) and remove three screws (on some models just two on corners) from the bottom of the control panel. If the control panel on your oven is made of stainless steel, then you have to pull the oven out of the cabinet for about 2′ to 3′ to get better access. Pull the control panel forward and up to remove the tabs on the top of the frame, out of the holes in the end caps. Pull the control panel out and turn it about 90° toward yourself (the face of the control panel down). Unplug the control panel ribbon from the ERC. Remove four screws holding the ERC to the control panel. On some models you also have to remove the screw which attaches the ground wire to the control panel. Let the ERC hang on its wires, remove the old control panel and replace it with the new one. On some models before you do it, you have to remove the end caps and the bottom shield from the old control panel and install them on the new one. Do not forget to plug the new control panel ribbon into the ERS slot. Attach the new control panel to the oven and turn the circuit breaker on. Set the time of the day and you are back in business
Nov 10, 2008 | Thermador SC272T Electric Double Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
213 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
