Question about Panasonic AG-7350 VHS/S-VHS playback VCR
Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
Panasonic 7350 VCR Keeps ejecting tapes just seconds after loading. i took the lid off and when the tape is inserted it appears to go in properly, however, the tape reel is not taken to be read by the head. and then just ejects itself.
  • j_rix Feb 11, 2009
    forgive my naivity what are strings where are they?
  • ronm744 Mar 28, 2009
    I have a Model PV-M1345 and it does the same thing. Ejects the tape as soon as you insert it.
    Also can't seem to find a manual for sevice. It has been 20 years since I worked on a TV or VCR.
    Ron M
  • 52 Answers
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Posted on Feb 09, 2009
  • Dutyacx Feb 11, 2009
    I'm sorry, I mean the rubber belts. They can be strecteched out over time, causing bad or no movements of the tape reel. I'm sorry I wasn't too clear about this.
Panasonic SQPB will not load cassette
I rather suspect some damage has occured inside the VCR. You should look for plastic parts that are broken.
Nov 20, 2012 | Panasonic Televison & Video
Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Aug 31, 2009 | Sony SLV-640HF VHS VCR
JVC SR V101US won't load tape
most likely problem is defective loading motor. p/n VEM0427.
Jun 27, 2009 | Panasonic AG-1980 S-VHS VCR
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
Panasonic VCR 7350 displays error messages and cant insert tape
There is either some damage to the mechanism or the mode switch is faulty. If you know what to look for taking the top cover off might show what part of the mechanism is damaged.
If it is the mode switch then it will need to be replaced. This can't be done without the service manual as the vcr needs to be set up. And they are never set up in the eject position.
Sep 27, 2017 | Panasonic AG-7350 VHS/S-VHS playback VCR
How to time loading arm cogs on VCR?
Most Panasonic VCR use a mechanisms with a letter. For example the NV-HS900 uses a K Deck. What you need to do is type the model number into google and search for which deck it uses. Then with luck you might also find the instructions for setting the deck up correctly. I got the K-Deck one free.
Jan 03, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
TV keeps shutting off after 10 seconds
It's possible from what you described that your center LED or prisim was broken when the tape was extracted. Like many others these units depend on a series of startup checks and one being the tape path. On the play table of the VCR is a center prisim/LED and two light sensitive diodes on either side of the tape loading assembly. If these diodes do not detect the infared beam the unit will go into shutdown. I'd check there and let me know. Bill
Jun 03, 2007 | Sylvania 6319CC 19 in. TV/VCR Combo
Tape keeps ejecting - panasonic nvfj620
Is it only the Head cleaning cassette which keeps getting ejected, or is it happening with every tape you insert? Was the Head Cleaning Tape a little tight in the Cassette compartment? Did you have to put some pressure to push it in or did it come out with difficulty? From your symptoms, it looks like there is a gear timing problem with the cassette loading compartment gears. It could also be due to some obstruction inside. try shaking the VCR, and if you are hearing some noise, Open cover and check for foreign objects.
Apr 25, 2007 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VCR won't push the tape down
The tape load mechanism has a problem mybe a broken gear. If u want to repair it by yourself, removed the tape drive and look for a broken part. You should be able to come up with a part #. Go to: Check out your chassis by the model number. or like always call for service. Good luck!
Sep 25, 2005 | Panasonic PV-V4622 VHS VCR
Panasonic AG-7350 VHS/S-VHS playback VCR Logo
1,354 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
