Question about Nintendo Wii Fit for Wii
Says I'm On When I'm Not
I Keep Getting: Step Off Me And Press A
  • 3 more comments
  • big-gary Jan 29, 2009
    My Wii Fit will tell me to step off the board and press A. I was not on the board and pressing A did not help as the message simply reappears. It seems like passing the body test and going right to training may make this problem worse (not sure).
  • Anonymous Jan 30, 2009
    I have the same problem. Any idea how to fx it?
  • TSLoire Feb 03, 2009
    I have this same problem, I start it up for the body test and it tells me to step off. Sometiems if you take the silicone cover off (if you have it on) will fix the problem. However I've doen that and it still won't work right, there's a quick fix for this in my case, all you have to do is lift the wii fit board off the ground and then press a, let it do all of it's jargon then put it back down on the floor quickly when it tells you to step on it and then step on it ASAP. Works for me, not a permanent fix but I think perhaps one of the sensor pad things hsa been pushed down too much perhaps and has got stuck, who knows.
  • Oki3Girl Mar 24, 2009
    I have this same problem. I bought mine new and put brand new regular regular AA batteries in it. Almost immediately after the "Body Test" graphic is displayed, I get a white screen with "Please step off me and press A." I have yet to stand on the board for the first time. I have tried every solution on this website such as all the turning off, resynchronizing, tilting the board in odd directions, and even picking up the board and pressing A. I still got the same message "Please step off me..." every single time. I am planning on mailing it to Nintendo this evening. I was just wondering if someone could tell me something I could do if I took the board apart and looked at it myself? I'd rather not wait two more weeks to get one back from Nintendo.
  • Anonymous Mar 26, 2009
    Same as described.
    Say step off when I am not on!
    Problem Solver:
  • 6 Answers
I managed to get my board working by, removing the covers from the feet sensors then placing the board upside down on the floor, then gently pulling on one foot sensor and pressing a, i continued until i found the one with the problem,
the solution i found was if you loosen the screw connecting the plate to the sensor very slightly the board will the calibrate and function correctly,
my board is still working without problems, hope this helps
Posted on Nov 08, 2009
  • Ivy  Cada
    Ivy Cada Feb 08, 2011
    HI there.
    You need to re seat the sensors.
    I have written a great tip with video. You can find it here.
    Thank you!
    http://www.fixya.com/support/r7297346-ni...
    Sniper:
  • 80 Answers
The Wii Fit Balance Board is a very sensitive scale. There are four sensors embedded in the unit that must be calibrated every time you use it to ensure that it performs best for you. There are two sensors on the left and two sensors on the right.
When you first start up Wii Fit, it needs to ensure that the board is 'zeroed' out. It does this when you have it turned on and it says "Starting Up". If you step on the board before it says "Ok, Step On," then it will not properly initialize.
It is also very important to note that you have to go all the way out to the main Wii Fit Plaza if you decide to let someone else use the board. Each Mii is configured to a specific individual and is NOT capable of being used by any other person.
That all being said, here are some suggestions to try.
First, ensure that you have fresh batteries in the unit. Try this particularly if it's been working well and then suddenly stopped.
Second, if you have any sort of shag carpet, be sure to use the extra little foot pads that came with the Wii Fit Balance Board. If you have thick carpet (more than 3/4" thick or so), you may need to use some sort of flat board (like plywood) to place the balance board on for it to work properly.
If these suggestions do not help, please don't rate this solution a '1' as the problem exceeds the scope of what can be covered here. Please contact Nintendo through their website and open a problem ticket with them.
Good luck and thanks for using Fixya!
Posted on Feb 04, 2009
How to reset canon E600 printer
To reset Canon printer we have to follow certain steps, they are:-
STEP 1: First check that your printer is turned on.
STEP 2: Now press the power button, this will turn off your printer.
STEP 3: Once turned off, press on the STOP button for two seconds.
STEP 4: While holding on to the STOP button, press the power button at the same time for two seconds and release the STOP button. keep in mind that you have to press both buttons simultaneously.
STEP 5: After letting go of the STOP button you have to still press the power button, press the STOP button five times.
STEP 6: After pressing the STOP button for five times, release the power button.
I expect that this will resolve your problem.
Jun 27, 2017 | Canon Office Equipment & Supplies
Keep getting dial tone on my phone, unable to receive or send calls
Step 1:
try turning off the phone taking the battery out for 15 seconds then re inserting it and turn the phone back on
Step 2:
if that does not work then try to factory reset it
Step 3:
then if that does not work take it to the store and ask them to troubleshoot it
Dec 11, 2012 | HTC Cell Phones
I'm not able to add new contact on my LG GX200 mobile. Getting "Add failed" message. Please let me know the troubleshooting steps.
Try these:
step 1: type numbers, Step 2: press option,
step 3: select save, step 4:press ok,
step 5: type name, step 6: scroll down to group,
step 7: change group, step 8: press save.
I think now you are able to save a new contact.
Sep 11, 2011 | LG GX200 Cell Phone
I keep getting an error message everytime i turn it on and when i try to look at my pictures in my gallery.. it says something like andriod.proces..media isnt working and also it will knock me off the...
You did a soft reset, try master reset: Here is a step-by-step procedure on how-to perform a factory reset when the unlock pattern code has been forgotten:
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the MID7015******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Aug 27, 2011 | Coby Kyros 716829701508 Tablet PC
I have a Toshiba NB255 Notebook and I have forgotten my Logon Password. Can you please tell me how to reset log on password.
If you are using win xp try This-
Step 1: click out of your log on password space
Step 2: press ctrl+alt+del button
Step3: type user name administrator, keep password blank & press enter
Step 4: go to the user accounts, create new & delete the current accounts.
Step 5: select "keep desktop files folder" option.
Step 6: restart your pc.
Note: if you have not entered administrator password while OS installation.
Thank You
Dec 24, 2010 | Toshiba NB255N245 Mini Notebook
I keep getting a code le why?
this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting
Has the washer been overloaded?
Thank You
Sep 10, 2010 | LG WM-2277HW Front Load Washer
Hi I have acer laptop which as stopped working no boot up nothing just turn it on and fans start then keep getting bleeps any help please
Its definitely a hardware issue. U can try the following step before taking it to a tech.
Keep tapping F2 as soon as u press the power button to power up the computer. U will get a BIOS screen. Press F9 to reset to the default settings. Now press F10 to save the saettings and restart the computer.
May 28, 2010 | Acer Computers & Internet
I keep getting the same updates for Vista
If you don't want your computer to recieved updates that it's very annoying then Turn-off automatic system Updates. To do it just follow the instructions below:
Step 1 Click the "Start" button on the taskbar or press the "Windows Key" on your key board (located to the right of the Ctrl Key and left of the Alt Key)
  • Step 2 In the search box enter the words "Windows Update" without the quotes you can copy the text directly from this page to make it easier.
  • Step 3 On the left side of the window that opens it will have a list of options click on the option labeled "Change Settings".
  • Step 4 After that you will have to make some choices. If you select "Install update Automatically" then you simply pick a time that is good for you and your computer will download the updates and install them when you are not on your computer. If you select "Download updates but let me install them" then you will download updates in the background while you are using your computer and then will ask you are the files are downloaded if you are ready to install them. If you decide to select "Never Check For Updates" then your computer will never download or install updates.
  • Step 5 If you select "Never Check For Updates" then it is highly recommend that you open "Internet Explorer" and visit "http://update.microsoft.com" at least once a month and install any updates that are labeled critical.
  • Nov 15, 2009 | Microsoft Windows Vista Ultimate Edition
    I keep getting the message to "step off and press A" for the body test.
    You need to step off the pad, wait until it tells you to step on. Then you push A to conduct the body test. If your pad is turned off push the button on the front of the wii fit pad then repeat the first steps i described.
    Aug 03, 2009 | Nintendo Wii Fit for Wii
    Nintendo Wii Fit for Wii Logo
    1,466 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
