Question about Maytag Neptune MDE7500AY Electric Dryer
Replacing heating element
I called Lowes because that is where we got it from. They shipped me some cube looking part which I really suspect is some sort of relay and not the heating element I asked for. Even if I do get the right part I can find no information on how to actually replace the heating element. Our last dryer was simple. It was so old it said "Fridgidare, a product of General Motors" on the front. This... seems a bit more complicated but still all I need to do is replace the heating element. What should it look like and where can I find information on how to actually replace it.
    Problem Solver:
  • 17 Answers
The heating element is actually inside that steel tube.......I work for an Appliance Parts Company and there is not many differant types of heating elements.....the one that goes into that steel tube can be seen here http://appliancepartsonline.net/index.php?target=products&product_id=305
If you give me the model number and make of the unit, I can look it up for you to see which one is the right heating Element for your particular unit....
info@appliancepartsonline.net
Posted on Feb 16, 2009
    Problem Solver:
  • 19 Answers
Hi NoNicky. I do not own a Maytag, but did find information about it on a couple of sites I've used before for my Kenmore. I'll include an image that should be for your model (they list MDE7500AYQ and MDE7500AYW). There are also details on the steps needed to gain access to the dryer and a diagram of the heating subsystem. Kenneth P.
Posted on Jul 27, 2007
SOURCE:
Ice maker is frozen
If ice is frozen in the cube trays and does not come out, this can be caused by an open tray heater element or a cam mechanism that is not working and not turning on the heat element. Replacement of parts is in order. But lots of places ripp you for parts so when you figure in the cost of the part and shipping it is often best to just go out and get a new ice maker for about 40 bucks on ebay.
Aug 29, 2014 | Whirlpool Refrigerators
My SMEG oven will not work, when I try to turn on the oven the whole thing powers down (the clock timer dies) The only way I csn reset this is to switch the power at the isolation switch off and on several...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 20, 2013 | Smeg Ovens
Only about five minutes of hot water, both elements and thermostats are good?
A] First of all, we know your upper element is working because you have some hot water:
http://waterheatertimer.org/How-it-works.html
It says tank is not overheating.
It says tank is getting 240Volts.
It we know water heater is 240Volts because you have 2 elements.
And it says reset button is not tripped.
B] That leaves 4 suspects:
Suspect 1) Bad Upper thermostat or Bad Lower thermostat: solution replace both thermostats for about 25$. Steps shown in link below.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Suspect 2) Burned out Lower element: solution take out element, clean sediment out of tank, put in new element. Steps shown in link below
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
Suspect 3) Loose wire or connection: solution open covers and remove insulation and look for signs of burning and high heat. Tighten all screws very tight. Replace burned part. Put insulation and covers back over thermostat so thermostat not exposed to cool air which will cause thermostat to misread tank temperature.
C] Before replacing anything, you can test water heater parts and determine exact cause of problem. Testing requires $5 multimeter from Lowes or Home Depot:
Install battery in multimeter.
When test calls for testing voltage, rotate multimeter dial to 240 or 250 or 277 Volts.
When test calls for testing continuity, rotate multimeter dial to ohms (upside down horseshoe symbol is ohms)
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
After doing 30 minutes of testing, you will be expert in water heaters.
If sediment builds up inside tank, it will reach lower element and burn out the element.
That could be problem.
Restore full efficiency to tank by cleaning out sediment and replacing lower element.
E] More reading to preserve tank and save money long term
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Dec 10, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
We just recently replaced both heating elements in our water heater. Now the water is just barely getting warm and not hot. What's wrong??
Electric water heater if fully repairable by homeowner:
That says tank is not overheating.
D] You replaced elements for a reason
Did you test elements before replacing?
Was tank producing some hot water before you replaced elements?
If tank producing some hot water, then lower element was bad, and upper element was good.
And when you replaced lower element, did you also clean sediment out of tank?
That could have been original problem, and it could be same problem again.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
E} More reading to preserve tank and save money long term
Dec 10, 2010 | Rheem Water Heaters
Oven powers up but doesn't heat
When you turn the control to 350 or so the bottom heating element should heat up, if it don't, turn the control to broil if the top element heats up it is most likely the bottom element has burnt out and need replacing. You can find the elements at Home Depot or Lowes, if not in stock at the store, you can order it inside the store.
Feb 13, 2010 | Ovens
Icemaker water overflows into freezer
the condensate tube is run incorrectly on this model and goes uphill into the area above the refrigerator where there is a condensate pan. This will plug and back up and cause this problem. I have fixed ours several times but it always came back. The last time I bought a new clear plastic tube and reran the condensate out the back of the refrigerator and down through my floor. It's all downhill now and seems to have fixed the problem.
Nov 28, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Yes my dryer quit heating and i have it apart in the back and i thing i have the heating element looks like springs kinda is this correct
yes that is it, does it look bad any busted springs? have continuity if no then your element is bad if yes then change the thermal fuse on the heating element canal... whirlpoolpartssurplus.com i will give you free shipping...call
Jun 24, 2009 | Roper Dryers
My dryer does not not produce enough heat when in operation. It seems like it is just running and generating very low heat. Please help.
Really sounds like an element is burnt out or a safety has malfuctioned. Possible loss of power so check plug, recept., and breaker. Look for burnt terminals and reset breaker even if it does not look tripped. Dryer usually have 2 elements. One for low heat and both for hi heat. May want to check this out. Please keep in mind that some repairs can cost more than buying a new dryer. I got one at Lowes for about $200 and it works great. I don't think you can get a repair guy out and to the repairs for that amount. Just depends on how many whistles, buzzers, and bells you want on your machine.
Good Luck.
May 08, 2009 | Dryers
Kenmore Refrigerator 106-9557612 Ice Maker won't Eject cubes
Hi caleycatz,
It sounds like you are in need of a motor module for your icemaker. This is the motor and gear that drives the icemaker prongs. The part number is
W10190935 The price is $77.59 and $6.00 shipping
I can have one of these at your door in 1-2 days, so let me know if you need one. We take Visa Mastercard and Discover. Or you can order from sears for the same price and wait 10 days.
Good luck to you and I really hope this will FixYa. Please take the time to rate me. Thanks
Mike Anerson (Owner)
Anderson Appliance Repair
(865)945-3808
Mca0824@aol.com
Oct 27, 2008 | Refrigerators
My 7 year old Malber WD 1000 won't dry - Where to order heating element?
pete5runner back again: The check you should make is to disconnect the two wires to the heating element carefully (with unit unplugged). Then connect a 110 voltmeter to the two wires. The plug in the machine and start a dry cycle. If you see 110 volts on the voltmeter, then you know that power is getting to the heating element, and you have isolated the heating element as defective. If you need a heating element, I got one in NY by calling 718-767-7396. New element was $29, shipping included. I don't know if he will ship to where you are located. Good luck, and let me know what happens.
Mar 10, 2008 | Malber WD1000 Front Load Washer/Dryer
Maytag Neptune MDE7500AY Electric Dryer Logo
1,184 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
