Question about Network Associates McAfee Wireless Home Network Security Full Version for PC
Need to reset mcafee wireless home network
I no longer have administrative abilities on my network because my main computer died. i have reset my router, my wireless wrt54g, taken every computer out of the network and yet when i try to load everything from scratch i still see the old network and cant connect or start a new one. help
  • cafebez Feb 02, 2009
    That sounds great but I can not find a "delete network" option or anything similar anywhere... and I have tried everything that I know. Thanks for your help
  • Anonymous Feb 25, 2009
    does not allow to open the managed network feature
  • 58 Answers
You have to delete the existing network and start the setting up of new network.
Posted on Jan 31, 2009
Bridge will not find router
Setting up a wireless router with a Windows client can be complicated.
There are a number of measures and options that have to be understood, and it's all too easy to make a mistakes--but D-Link provides an easy-to-walk-through configuration system to help you set up your D-Link wireless router.
Plug one end of the Ethernet cable into the DSL modem.
Then plug the other end into the "WAN" port on the back of the D-Link wireless router.
Connect wired computers to any of the other Ethernet ports on the router using another Ethernet cable.
Access the D-Link Configuration Screen
Open your web interface and type "" into the address bar, then hit "Enter" or "Return."
Use "Admin" as the username and leave the password blank when the login screen appears.
Click "OK." You should now see the D-Link configuration screen.
Set Up General Security
Change your administrative password by clicking on the "Tools" tab and choosing the "Admin" button. Enter a new password under the "Administrator" heading.
Confirm it, and click "Apply."
Disable the wireless Local Area Network (LAN) if you don't need to use the wireless access and you want to make sure no one else is able to access your network.
Under the "Home" tab, choose "Wireless" and select the "Off" option.
Enable Wireless Encryption Protocol (WEP)
Locate the "Home" tab in the D-Link Configuration screen, and click on the "Wireless" button.
Use the "Open System" button beside "Authentication."
Select the "Enabled" button next to "WEP," and set the encryption key to "128 bit."
Set the "Key Type" to "ASCII" and choose a 13-digit password for the "Key 1" field.
Write down the password in a secure location.
Click "Apply."
Change the SSID
Change the SSID to make it more difficult for others to locate and use your network by clicking on the "Home" tab and locating the "Wireless" button.
Change the default SSID to one of your choosing, then click "Apply."
Disable SSID broadcasting.
Under the "Advanced" tab, click on "Performance" and check off the "Disabled" box. Again, click "Apply."
Filter MAC Addresses
Click the "Advanced" tab in the D-Link "Configuration" screen and select the "Filters" button.
Choose the "MAC Filters" and click on "Only Allow Computers with MAC Address Listed Below to Connect to the Network."
Enter the name and MAC address of the computers allowed to access the network, beginning with the one you are currently configuring.
Click "Apply."
Mar 18, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
How to set up wireless home network with a DSL subscription.
If you have a DSL, "Digital Suscriber Line", most companies will provide you with a modem. Usually the modem will have only one ethernet connection, meaning you can only connect one computer.
In order to connect multipule computers you will need a wireless router, ethernet HUB, or router.
Connecting with wireless Router
The only thing you really need to change is the following 3 settings on the Wireless Router. The SSID (so you know what wireless network is yours), the WPA/PSK and or WPA2/PSK, encryption method TKIP key or password. Under "administration" change the administrator password for a secure wireless connection. ( WRITE DOWN YOUR PASSWORD)
Connect to your wireless router
1. Plug in either your (1) wireless card, (2) PCMCIA wireless card, or (3) USB wireless stick.
2. Turn on your laptop or desktop computer. Select the wireless router with the strongest signal and with the name of your routers (SSID) and click connect.
3. Open your web browser and type
If this dosn't work, check your wireless router instruction manual for the correct IP address for your model.
4. Your router will ask for a password, usually (admin, admin) works or (admin, (ENTER) ) try both. If neither work try resetting the router by holding in the reset button for 3 seconds.
Once you log on to your router you can set parameters to your liking or just set the , {SSID}, {WPA/TKP} key or password, and the router administrator password to keep others from accessing your network and possibly computer.
Start at step 3 above.
More questions?
on Feb 05, 2010 | Computers & Internet
How to obtain an uninstal code for mcafee family protection.Thankyou.
Dear Iain,
Please try the solution to resolve the issue.
Double-click the Family Protection icon in your taskbar.
  1. Login to Family Protection using your Administrator credentials.
  2. Click Get Uninstall Code. Make a note of this code.
    NOTE: The uninstall code will expire at midnight.
  3. Click Done.
  4. Close all programs and disconnect your computer from the internet (you can do this by turning off your DSL or Cable modem, or unplugging your network cable from the back of your computer).
  5. Click Start, Programs, McAfee Family Protection, and select Uninstall Family Protection. In Windows Vista, click the Windows button, select All Programs, select McAfee Family Protection, and select Uninstall Family Protection. If prompted, click Allow.
  6. Select Remove.
  7. Click Next.
  8. Type your Administrator credentials.
  9. Click Next.
  10. Type your Uninstall Code and click Next.
  11. Select Yes, I want to restart my computer now.
  12. Click Finish.
Feb 22, 2011 | Network Associates Mcafee Family...
Although my Asus once recognized my home wireless router, when Comcast sent us a new wireless router to use and a new home network was set up, my computer no longer was able to connect. I can access...
To connect to your wireless router, it needs the router's wireless settings configured and also the wireless cards in all the laptops and or computers needs to be configured with the router's wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
Feb 07, 2011 | ASUS Wireless (90-c1i010-00xay)
I forgot my Mcafee password. I want to UNBLOCK a website but i cant do that without my administrator password.
Contact McAfee support - they can email you a password reset
Sep 08, 2010 | Network Associates McAfee Parental...
Antivirus for laptop still need an antivirus program running on your laptop as well.
Nov 16, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
How to set up uverse home network with 2wire gateway
To use AT&T Uverse for a home network, you need to get the AT&T "Homeview" Network Management software. AT&T provided this software in the past freely.
This software must be run on each PC on your home network, and then each PC can see the others. You then use go to My Computer, select each disk drive you want to share, right-click and select Sharing and Security, and select to share the drive. Then go on the drive to the folders you want to share and right-click and set them to be shared. Then the Homeview system will show these are shared folders. You can also share printers on the same network using the Homeview software.
Jun 13, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Can't get more than one pc to connect with linksys router
Well I'm not sure if that's correct. When you Reset your Router, you cleared all of the available Networks. Let me explain. A Router is essentially a way for one computer to get its' feed from the Main computer. So when you setup your router, you had to establish which was going to be the Main System. Generally the main computer is connected via Ethernet Cat5 cable but not necessary.
In order for a computer to talk to your Network individually it must have it's own Keycode. You Open up View Available Networks and you should be able to see all Routers within your area. You'll place the keycode in that field and then that Computer is then able to access the Internet via the Router.
Since you Reset it, you wiped out the information and will need to start over. Question : Why did you Reset it anyway? What caused you to feel the need to do that because that's never a solution for not being able to connect.
Jan 26, 2009 | Linksys Wireless-B Broadband Router Retail...
Unable to access the internet via my laptop
One of two problems. The Security Key for your wireless connection is wrong, or the McAfee is causing a problem. Most likely conflicting with any other virus software on your computer. Try removing McAfee from the computer and your solution should go away. Try another virus software such as Avast! Home edition. McAfee is known for having issues with wireless internet connections.
Jan 25, 2009 | Linksys Wireless-G WRT54G Router
Network Associates McAfee Wireless Home Network Security Full Version for PC Logo
532 people viewed this question
Top Network Associates Computers & Internet Experts
micky dee
Larry Fostano
Larry Fostano
Are you a Network Associates Computer and Internet Expert? Answer questions, earn points and help others
