I cant seem to find my portable external hardrive in "my computer" when i connect to my laptop
  • Dan rogers
    Dan rogers May 11, 2010
    how does the drive connect to the computer?
    What operating system are you running?
    What kind of drive is it?
  • ROD GANDY May 11, 2010
    NEED MORE DETAILS AND DISCRIPTION OF PROBLEMS
    CANDYMANGANDY
    Problem Solver:
  • 5 Answers
Right click on my computer and select manage, go to disk management (under storage) and see if the drive appears here. if so it's probably trying to use a letter for drive which is already in use. If youright click on the drive you can change the drive letter to one that is free.
If not appearing as above check your system devices in device manager - it should apear under USB controller as a storage device
Posted on Feb 11, 2009
I connect my seagate external hardrive to my xbox to store some data on it because my xbox does not have an internal hardrive. So i figured i can use my portable external hardrive to my xbox, and it said i...
Either you have 50 gigs of stuff on there or your hard drive space is not being properly read. U might need to reformat the drive if necessary.
Meanwhile your xbox electronics may have a limit on the size of space - so if the drive has 200 gigs of space on it and your unit will only recognize 32 gigs, then that is all it sees and can use. Capiche?
Jun 16, 2017 | Seagate Computers & Internet
I got an old laptop and I bought a new toshiba laptop I just wanna ask how do I transfer my application and files from my old laptop to a new one using external hardrive,also wat external hardrive,and also...
You can transfer the data files only from the old laptop to the new one. You cannot transfer the installed applications/software. Software are required to installed again on the new laptop afresh.
To transfer the data you can use external portable hard disk, which can be connected to the PC using any USB port (just like pen drive) and you can copy - paste the required data to the external disk just like you copy data from one partition to another. After copying the required data, you can connect the external drive to new laptop and copy the data to the new laptop. You can use external drive of any brand/ capacity. However, it is better to have an external drive with larger capacity, so that you can transfer the data in one go.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Toshiba Computers & Internet
My passport 500gb external just stopped working. It froze up so I removed it and plugged it back in. When I plugged it back into my computer it starts spinning but then makes a click sound and stops.
The clicking sound is caused by the spindle inside the hardrive, because it was not removed properly. Just connect you external hardrive to your computer, if it makes the clicking sound again dont remove it yet, just restart your computer properly. In that way all the devices connected to the computer will be refreshed and properly shut down. If it is not detected still, unplug the haardrive then try another USB port. Recommended ports are at the back of the CPU if your using a desktop. These USB ports have higher voltage output that can power up all external hardrives properly.
Jan 13, 2011 | Western Digital My Passport Essential...
My hardrive "simpledrive" model 96300-41001-156
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 03, 2010 | SimpleTech SimpleDrive Portable USB 2.0...
When I connect it to my laptop (or ANY other computer/laptop) the blue light on the external hardrive turns on and I can feel that it is working, but it simply doesnt get read, the computers dont recognise...
Open the enclosure.
Separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a 'slave' disk-drive in a desktop computer, and see if you can read the files.
If not, search online for a professional 'data recovery service' -- for a FEE, they can repair a disk-drive just long-enough to copy your files onto a new disk-drive.
Oct 26, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
Verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
Jun 09, 2009 | Verbatim 160GB USB FireLite: The "drive...
External Hardrive crashed
Try reading this post........http://forums.macosxhints.com/archive/index.php/t-32880.html
Jul 18, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
