Unit scans ok, but I am unable to move the photo to a folder.
There doesn't seem to be a pathway from the initial scans to a photo program or a folder. How do I transfer the scans?
I called the local geek and he figured it out. Thanks
Posted on Jan 30, 2009
Unable to write the file to "Destination Folder"
A recent (Dec 2015) Windows 10 update seems to have removed the access required for the service account used by Brother to write to the hard drive. This fixed the scan function for me...
  1. Navigate to the directory where you write the files (C:\Users\YourID\Pictures\ControlCenter3)
  2. Right click on the Scan directory and open Properties.
  3. Click Security tab.
  4. Click Edit
  5. Select WMPNetworkSvc
  6. Allow Full Control
  7. Click OK
Nov 11, 2011 | Brother MFC-6890CDW Printer
''Error 1706''
My colleague says that when Error 1706 occurs during an attempt to install an MSI file from removable media, the first thing you should try to do is check the Media Package Pathway and determine if the pathway does in fact track to the right folder. If it does not, scan the removable media and locate the file where the MSI file is housed. In some cases, you may find that the MSI file is found in a folder that is named App1. Once you have determined where to find the right file, it is a matter of resetting the Media Package Pathway so that the system will find and activate the MSI file. This will require you to make some changes to the command line or possibly make a permanent change in the registry.
It is important to note that making changes in the command line and especially in the registry are functions that someone who is familiar with writing code and general information system functions should perform.
If you are not knowledgeable about these sorts of functions, there is every possibility that the modification will not result in resolving the issue regarding the MSI file. Further, the change may create additional problems with the media package.
May 28, 2010 | Computers & Internet
Epson Stylus Photo RX500.
hi there.. seems, a hard job huh? transfering it from 1 folder to other.
try this , open epson scan program, goto home mode. click preview, click scan, it will open file save settings window where you can select where to save your picture, under location , look for the folder where you want to save it, if its not on the list, select other then look for the folder or for your appleworks, once you found it, click ok, it will scan and save directly to the appleworks.
i hope this one works for your.
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Feb 06, 2010 | Epson Stylus RX500 All-In-One InkJet...
I cant seem to find a scan option on my epson
Once all of the drivers are downloaded and the printer is connected to your computer, you can initiate a scan of a document two ways.
First, you can select Copy on the printer and it will copy the document placed on the scanner.
Second, you can scan a document to your computer by going to: Start > All Programs > Accessories > Paint.
When the Paint program opens, (in the upper toolbar) click: 'File' and scroll to 'From Scanner or Camera'. Then, select your device (Epson scanner) and click, 'OK'.
Continue with the prompts and your scan will be imported into the Paint Program. To save your scan, Click, File > Save As > (name your document) and select a folder for your scan to be sent to.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks.
Feb 03, 2010 | Epson Office Equipment & Supplies
Can you scan photos on the Epson DX6000 and save the image to the computor? If possible how do I go about it?
Starting a Scan With EPSON Scan If you want to scan an image and save it directly to a file, you can start EPSON Scan as a “standalone” program.
step_1.gif Place your document or photo on the scanner. See Placing Documents or Photos for instructions.
step_2.gif Do one of the following to start EPSON Scan:
    Windows:
    Double-click the EPSON Scan icon on your desktop.
    Or select Start > All Programs or Programs > EPSON Scan > EPSON Scan.
    Mac OS X:
    Open the Applications folder and click the EPSON Scan icon.
    The EPSON Scan window appears.
step_3.gif If the Mode setting in the upper right corner of the window is set to Full Auto Mode, click the Scan button. For instructions on selecting optional settings, see Using Full Auto Mode.
01.gif mark_no.gif Note: 01.gif 01.gif To change scan modes, see Changing the Scan Mode.
step_4.gif The File Save Settings window appears. For instructions on selecting options, see Selecting File Save Settings.
cj35003e.gif step_5.gif When you are finished selecting File Save Settings, click OK. EPSON Scan starts scanning in Full Auto Mode.
step_6.gif The scanned image is automatically saved in the specified location.
    If the Open image folder after scanning checkbox is selected in the File Save Settings window, Windows Explorer or the Macintosh Finder automatically opens to the folder where the scanned image was saved.
Please follow this link for same manual with screenshots:
http://support.epson-europe.com/onlineguides/en/dx6000/html_s/scan1_1.htm
Hope it helped.
Nov 22, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Diamge Scan II, Error = 5 Windows 2000, Error = 1 on Windows XP
Before you install try this.
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this helps you to make your computer faster..
Sep 14, 2009 | Minolta Dimage Scan Dual II Film Scanner
Unable to scan photos
it worked for me when i pointed it at the windows photo gallery in the program files folder. if you dont have windows photo gallery you can get it here:
http://download.live.com/photogallery
hope this helps :)
on a side note the validation software used to check these posts are genuine is useless, i nearly gave up which hardly seems like a good design to me. anyway.....
Jan 21, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Unable to view the pictures folder
Hi, I got the solution for myself. Initially I have enabled to view the hidden folder option and even then I was not able to see the folder, then later I have disabled the options Hide Extensions for Known file types and Hide Protected Operating system files. Then I could see the folder and able to retrieve the photos. Once I have taken my photos I have formatted my MMC card and it is working normally.
May 19, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Unable to uninstall
click start there you will see run click on this ? look for files & folders?there you will see all files and folders click on it then a white box will come up tipe the programe you wish to move and then scan when it brings it up high lite then remove
Feb 07, 2008 | Computers & Internet
Which program do i use to transfer the scanned image too?
Sounds like the CanoScan is looking for a photo enhancing/utility program. Programs for this purpose are Adobe PhotoShop, PaintShop Pro, ACDSee, or even the simple Windows Paint.
Additionally, the CanoScan Toolbox might have a basic photo utility program. Normally basic photo utility programs like this are included in the CD installer of a scanner, a digicam or even most color printers.
Hope this be of some idea/help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 01, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
