Question about DE-1788 Radar Detector
My whistler 1788 fail to initialize properly
When I turn it on,initialization slows down and freezes.During initialization,it is beeping instead of making clear sounds.
Can you please tell me what is wrong with it and what should I do?????
  • Whistler Expert
  • 347 Answers
Make sure that the batteries are fully charged. Does it act the same when no batteries are installed and running from the power cord?
Posted on Jan 07, 2010
Fail to initializing
The fail to initialize is typically a problem with the document scanner...but not always. here is a quick test you can try. Turn the unit off then power it on again. Slightly lift the copy lid as the unit goes through warm up attention to the light color emitting form the scammer. it starts to blink red, then changes to a bright white IF the scanner is working properly. IF the scanner is NOT working properly the scanner stays RED during the warm up.
Nov 26, 2013 | HP LaserJet Pro M1212nf MFP -...
Need maunaul for whistler xcs800
you can call Whistler at 800-531-0004. The XCS 800 is the same as the 1788 model, just newer.
May 22, 2012 | XCS800 Radar Detector
Error c1038
The system fails in checking initial engine connection. When the Power Switch is turned ON. #2 The system succeeded in checking initial connection when the Power Switch was turned ON; then it
fails in rechecking initial connection through the execution of a software reset when a communications error occurs during operation.
1. Check the connection between Master Board and MFB2 Board.
2. Reset the malfunction and turn OFF and ON the Power Switch.
3. Change MFB2 Board. Change Master Board.
So will check each connector to each board, one at a time check for a bent pin pins are on the board connector. then re-seat each connector properly, worse case bad control board, doubt you can find a board a very old legacy Minolta Machine, try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jul 18, 2011 | Minolta DiALTA Di350 Laser Printer
Maxdata tower computer : - when switched on bleeps 2/3 times and doesn't engage the mouse or the keyboard and the monitor shows " no video input ".Just no response and doesn't turn itself on...
BIOS Beep Codes
Whenever a recoverable error occurs during POST, the BIOS displays an error message describing the problem. The BIOS also issues a beep code (one long tone followed by two short tones) during POST if the video configuration fails (a faulty video card or no card installed) or if an external ROM module does not properly checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors, usually consisting of one long tone followed by a series of short tones. For more information on the beep codes issued, check the documentation for that external device.
There are several POST routines that issue a POST terminal error and shut down the system if they fail. Before shutting down the system, the terminal-error handler issues a beep code signifying the test point error, writes the error to I/O port 80h, attempts to initialize the video and writes the error in the upper left corner of the screen (using both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to the operating system.
I hope this helps.
Mar 14, 2011 | Computers & Internet
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
May 14, 2010 | Yahoo Messenger
What type plug operate a whistler 680 radar det. Is it a 1.3 size plug.
Take the unit to your local Radio Shack and they will hook you up with the right equipment.
Jul 27, 2009 | DE-1788 Radar Detector
I received a Whistler 1788 and I dont know how to use it
You can download a manual from Whsitler's website.
Jul 17, 2009 | DE-1788 Radar Detector
I just received a whistler 1788 laser radar dectector. how do i use it? set it?
install the windshield bracket, install the batteries, slide the unit onto the bracket and turn it on. For using the other features, it is very detailed in the owner's manual.
Dec 26, 2008 | DE-1788 Radar Detector
DE-1788 Radar Detector Logo
96 people viewed this question
Top Whistler Vehicle Parts & Accessories Experts
John Nolan
Greg Cann
Greg Cann
Are you a Whistler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
