Question about Lexmark X7350 All-In-One InkJet Printer
Lexmark X5650 4 in 1 printer, scanner, fax, copier
I want to know how to use the scanner to make photos larger Thanks Eugene
  • Anonymous May 21, 2009
    The scanner dont scan the whole piece of paper
ginko
  • 19396 Answers
SOURCE: i lost the Lexmark X5650 Printer, Scanner, Copier
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Posted on Mar 05, 2009
  • 111 Answers
SOURCE: lost disk to install printer scanner fax for the
goto http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0 and search for X7350
Posted on Mar 18, 2009
abain9608
  • 28 Answers
SOURCE: Have a lexmark all-in-one, but lost disc need to install it
Here's a link to the driver download:
Posted on Jun 25, 2009
  • 108 Answers
SOURCE: I just bought a new lexmark copier, scanner, fax,
OCR stands for Optical Character Recogniton.
It's a program that can take images of scanned documents, (text), and recognize each character, then retype it as a text document that can be edited or reformated as you wish.
Chances are you tried the OCR function, and haven't installe the option for OCR.
It's one of several software programs that would have come with the Installation CD which would also have included, the Drivers for the printer and scanner, a copy utility, diagnostic utility and other stuff.
In the opening menu, perhaps an extras menu will have the option to install OCR.
Try the installation again to see if there is the option.
Other than that, you should be able to "Aquire" images through the scanner via an immage utility (File / Aquire / Scanner), or Microsoft Office program (Insert / Image / From scanner or camera).
Also there is a PhotoCopy function on the device that takes a Scan from the scanner and prints it directly to the printer.
Posted on Jul 07, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: how do I change baud rate on Lexmark X5650 in
    Just to set your expectation, MagicJack phone service may work but Lexmark does not recommend the printer to be connected to a digital phone signal (e.g. MagicJack, Vonage, etc.) since there are lots of jitter and packet loss in the transmission signal resulting to fax failures. The Lexmark fax machine will have its optimum performance when connected to an analog signal(regular telephone line). But here's how to configure the printer's baud rate. From the Control Panel, press Settings(wrench icon)> Fax Setup, hit Ok > Dialing and Sending, hit Ok > Max Send Speed, hit Ok > set down the speed to 9600 bps. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
    Posted on May 06, 2010
    I can send but not recieve a fax on my Lexmark X7170
    This article in the Lexmark website on How to Configure the Lexmark X7170 to Receive Faxes might help resolve your problem receiving faxes. Thanks.
    Feb 17, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
    How do you know and find the cartridge number in a x 4270 lexmark printer?
    The Lexmark X4270 printer uses cartridge number 70, 71 and 75 for the Mono Ink Cartridge. For the Color Ink Cartridge it uses 19,20 and 25. You can check this link - http://bit.ly/d2bbwm if you want to purchase these cartridges. Thanks.
    Aug 15, 2010 | Lexmark X4270 All-in-One Multifunction...
    Error 2200 on 7170 lexmark
    The error indicates that the scanner has stalled or jammed. Here's an article on 2200 Error on the Lexmark X7100 Series All-In-One. Just click on this link: http://bit.ly/aBUoJK. Just follow the troubleshooting steps on the page. If all else fails, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
    Jul 27, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
    What is a scanner and how do i use it on my lexmark 5650 copier?
    Hello. The scanner enables you to scan and print photos, text documents, magazine articles, newspapers, and other publications. You can also scan a document for faxing. The scan software must be installed in your computer. Use the installation cd that came with the printer to install the software. Here's an article in the Lexmark website that will show you how to use the scanner. Just click on this link: http://bit.ly/9ShAN7 . Hope this helps.
    Mar 25, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
    Connector cable
    I get many from Rite-Aid.
    Best Buy and Staples are expensive. You need a USB A/B cable.
    Jul 13, 2008 | Lexmark All-in-One Printer, Scanner &...
    LEXMARK X4270 PRINTER SCANNER COPIER
    When trying to retrieve a fax, the screen said "Error 1203". Since I misplaced the instructions, I do not know how to correct this. Please advise. Thanks
    Apr 18, 2008 | Lexmark X4270 All-In-One InkJet Printer
    Scanner problems
    try to change cableof scanner to pc.
    Apr 01, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
    Can't connect printer
    Hi kyla, Lexmark has at least some of the software posted on their site. Assuming your operating system is Windows XP here are the links to the downloads: Driver link: http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:463:0:0&searchLang=en&os_group=WinXP&target Fax/scanner software: http://downloads.lexmark.com/cgi-perl/downloads.cgi?category=Software&ccs=229:1:0:463:0:0&os_group=WinXP&searchLang=en Let us know if you have any more questions and please don?t forget to rate the posting.
    Jan 19, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
    Lexmark X7350 All-In-One InkJet Printer Logo
    252 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
