Question about Maytag MSD2732GR Side by Side Refrigerator
Ice maker over flow now water wont fill back up
I have a side by side frig with the ice maker. We have recently been having trouble with the water to the ice maker getting stuck and running out into the freezer and sometimes into the floor. THis last time we got all the water and ice cleaned up, which was on Monday night and as of today, Thurs. it has yet to make any ice or even fill the ice trays up. Could this be a simple fix or does it sound like it could have blowed up?
  • 1,314 Answers
No its not blown up low water pressure will cause also sticking water valves if it has worked properly for a while then change the water valves
Posted on Jan 29, 2009
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
We have a Frigidaire Gallery side by side frig. We have had many problems, but yesterday it froze up with icicles hanging and big chunks of ice. My husband cleaned it out and thought it was OK. We woke...
First thing to check is where the ice maker actually fills up to make sure that its not full of ice and causing an over spray of water into the machine. You can actually take the tube out from the back of the machine. If there is no ice in the tube, next thing to do is make sure that the ice maker isn't over flowing and calling for to much water when its filling,. You can do this by either removing the ice maker and visually looking or by reaching in and feeling to see if the ice maker is completely full of water. If it is then either your ice maker is going back or the water valve is not closing when the ice maker is done calling for water.
Nov 07, 2010 | Frigidaire Refrigerators
Water line from house supply sprung a leak just before going into the ice maker control unit in the lower right cornor of the frig. After replacint the water line the water did not flow into the control...
What once was a leak is now no flow and no response when trying to turn on ice maker? Is the valve where the ice maker line taps into turned back on? If it's back on, first turn it off, take loose water line as close to ice maker as possible, then have someone else turn valve at tap slightly on while you watch for water flow. If no flow, start back-tracing your connections until you find the blockage. Most water connections of this type have a in-line filter. Is it clogged? If you have water pressure as close to the ice maker as you can test, next you may need to troubleshoot the ice maker it's self. Let me know?
Jan 02, 2010 | KitchenAid Superba Architect KSCS25INSS...
I have a kenmore side by side refigator and with built in ice and water in front door. The water does not fill ice maker or dispence out the door. The water stoped first at door then about one year later...
you might need to open the water pip and clean the volve on the bottom of your fridg. its get clug some time but if its not working then your valve need to be replace..get me your model # i get you the part#...
911servicetoday . com
Jan 01, 2010 | Kenmore 21.7 cu. ft. Side-by-Side...
Ice maker quit working on GE refrigerator
Sometimes on a ice maker what will happen is the water line that fills the ice maker will freeze. You can use a large syringe filled with hot water and from the rear of the frig remove the water line where the hose goes into the rear of the frig and force some hot water into the tube to see if it is clear.
If the line is clear fill the ice maker manually and see if it goes through a cycle.
If it goes through a cycle you have to check to see if the ice maker is calling for water by putting a multi meter across the contacts of the water inlet valve located behind the panel on the back of the frig. Advance the ice maker to run through a cycle and see if it is calling for water. If you have current going to the valve and no water momming in, replace the valve.
If you do not have current going to the valve after the ice maker has gone through a cycle. Replace the ice maker.
Dec 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker working sporadically
The ice maker is probably ok. It is most likely the temperature of the freezer. Remove items that block air flow up the back of the freezer. Make sure the door can close securely. You may have water pressure that is too low to fill the ice tray, take time to confirm water pressure to the back of frig. Remove the line and run water into a bucket for several gallons then secure it back to the frig. Make sure the line is tight and does not leak before and AFTER you roll it back into place..
Apr 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker Problem
Ceck the water valve on the back of frig. It could be the solinoid for the ice maker side of the valve is bad and requires replacement.
Jul 19, 2008 | Whirlpool ED5FTGX Side by Side...
Amana water fill and ice maker
check the flow from the water line of the house to the water valve of the frig not connected to the valve it should fill a large container fairly quickly
if it does the problem is with the water valve of the frig
if it does not fill the container fairlly quickly then the problem is the plumbing of the house to the frig valve
May 08, 2008 | Refrigerators
Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Apr 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Maytag MSD2732GR Side by Side Refrigerator Logo
142 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
