Question about Lakewood Oil-Filled Electric Radiator Heater
Defond 2415-3 switch how many poles?
Switch is for my tig welder. switch has no lug on number 3 terminal. i can't figure out the wiring dia. can you help. thanks
3 Suggested Answers
  • 4 Answers
SOURCE: lAKEWOOD OIL FILLED HEATER
If it looks like this you can find one here
Defond DRH-2415 15A 125VAC Lighted Dual Heater Switch
Posted on Jan 14, 2009
SOURCE: Lakewood 7096
i went all over town looking for a switch. finally found two lighted switches at grainger carling technology part no. 1A824. ground down the outsides glued both together jumped across top and bottom terminal with copper wire and it seems to work fine now.only time will tell. i hate our throw away society which the junk imported in from china seems to foster.
Posted on Oct 08, 2009
  • 123 Answers
SOURCE: Where can I buy a
Here you go... http://www.1sourcecomponents.com/partinfo/DRH-2415.htm
Hope this helps. Please leave feedback!
Posted on Jan 28, 2011
Installing tig torch to water cooler
You can directly connect your water cooling argon torch to the tank, but the pump electric wires must be connected in accordance to the switch, when you press the switch you start to weld and the pump is on, release you stop welding and the pump is off, rather an electrician to do the connection for you
Aug 28, 2014 | Miller COOLMATE 3 115V TIG TORCH WATER...
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
Millerbig blue 400 d welder wontstart keep kicking breaker help
1. Make sure a qualified electrician specifically selected and installed your wiring and breaker for this unit.
2. Carefully examine all of your power supply connections, wiring, grounding connections (clamps, lugs, and nuts) and cable.
3. Be sure you don't have a steel washer between the grounding lug and the machine power base.
4. You must have a minimum of 4 gauge wiring on your power supply and 2 gauge grounding cable.
5.Take a 3/8" socket and open up the machine and thoroughly examine with a bright flashlight for any electrical burns.
6. If the machine is too dirty to see the components, then disconnect it from the electrical service, lock-out / tag-out the electrical breaker, take the machine outside and wash it down with a hose -- preferably a light duty pressure sprayer and some Simple Green.
7. Let it air dry for 24 hours. Then re-examine.
Jan 31, 2012 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Need power input wiring diagram for 230V use
you can get the manual here:
http://www.millerwelds.com/service/locate_om.php
Jul 23, 2010 | Miller Electric Manufacturing Electric...
Changing from 480v 3 phase to 220v single phase need diagram on a Miller Dynasty DX tig welder Serial # KH577649 stock 903519-01-1
i have a old miller thunderbolt CC*AC/DC welder its wire single phase 480 can it be switched to 220 single phase
Dec 02, 2009 | Miller Welding Tools
I have a miller dynasty inverter tig welder   It has a help code that comes on when I turn it on the code is p-2
From the user manual for a generic dynasty model welder:
2 Help 2 Display
Indicates an open in the thermal protection
circuitry located on the left side of the unit.
Contact a Factory Authorized Service
Agent if this display is shown.
So you could have anything from a broken or disconnected wire to a bad thermal switch.
You can get user manuals specific to your welder at www.millerwelds.com
Rank this answer please,
Carl
Nov 26, 2008 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
TIG welder tips
Go to your local welding supply store. A TIG welder is a specialized welder that cannot be found at a building supply store. Stores like Maine Oxy-Acetylene Supply or Grainger Industrial Supply will carry them. Look in the classifieds of publications like Uncle Henry's. There you might find a TIG welder that someone is selling—and it may be at a good price. Be sure to ask the owner questions and take a look at the TIG welder before buying it. Explore eBay. Yes, even eBay has TIG welders. You'll need to ask the buyer questions about the welder's history and more. Perhaps, if the seller is near enough, you might be able to pick up the TIG welder yourself and save on shipping. Visit online retailers. Retailers like Welders Direct or Welding Mart carry TIG welders and would be able to answer any questions you might have (see Resources below). Consider the manufacturer of the TIG welders themselves. Lincoln, Miller, Hobart and others have their own websites. Call the companies directly and ask a lot of questions. These vendors are the best product source for welders (see Resources below).
Aug 27, 2008 | Miller COOLMATE 3 115V TIG TORCH WATER...
Lakewood 7096
Jan 07, 2008 | Lakewood Oil-Filled Electric Radiator...
Lakewood Oil-Filled Electric Radiator Heater Logo
185 people viewed this question
Top Lakewood Heating & Cooling Experts
Mack Baxter
paulcarew
Jay Finke
Jay Finke
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
