Question about Haier HVH025A Wine Cooler
Punched inside panel.
Someone gave me a Haier wine cellar HVH025ABB. The panel inside at the back of the refrigerator was punched with a knife. It drain all the refrigerant. How I can fix it or where I can find that panel?
Thanks !
ERC form Puerto Rico
  • 410 Answers
Sounds like some one tried to defrost it with an knife. you can order the evaporator thru haier but unless you know how to do sealed system work you will need a qualifed refrigeration company to repair it for you if you provide the part approximate cost in the states is around 300-400 dollars. good luck peyton
Posted on Jan 29, 2009
How do i set the temperature on my haier model number hvdw20abb
Thanks for including the make and model number.
Without these, an answer is impossible.
Here is a link to the manual, which describes in detail how to adjust the temperature.
Haier HVF020A User Manual Wine Cooler Features And Use Initial Set Up...
If you found my answer helpful, please rate. Otherwise, feel free to ask for any further info if needed.
Oct 30, 2014 | Haier HVDW20ABB 20 Bottle Display Window...
I need the Haier 18 bottle wine cooler instruction manual.
Hi There,
I was able to find two 18 bottle wine coolers on the Haier site.
The first is model number HVTM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtm18dabb
The second is model number HVTSM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtsm18dabb
On either product page the manual can be downloaded from the "product support & downloads" tab
Have a great day!
Jul 18, 2012 | Refrigerators
My wine cellar won't start when plugged and switched on
My Kenmore mini refrigerator has the same problem. One of the capacitors on the control board is bulging its top.
Apr 23, 2011 | Haier HVW12A Wine Cooler
Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
May 04, 2010 | Haier BC112G Wine Cooler
I have an Haier 8 bottle counter top wine cellar. No electricity to digital display, rear fan is not on and does not cool. Looking for schematic for possible fuse location.
look down of the wine celllar and take off the plastic cap and clean the electrics contact. After that use use the 4 screwed support to give it the right inclination._400.jpg
Apr 10, 2010 | Haier HVUE08A Wine Cooler
Frig won't chill. can hear it click off & on when plugged in.
HAVE YOU CHECKED THE SWITCH ON THE COMPRESSOR OR THE FUSE ? AND IF THE COMPRESSOR IS KICKING ON CAN YOU HEAR THE BLOWER FAN KICK ON ? IF ALL IS GOOD THEN YOU HAVE A BAD CONDENSOR THAT WILL BE THE NEXT THING TO CHECK
Apr 11, 2009 | Haier HVA052ALL-8S 52 Bottle Aficionado...
Haier Dual Zone Wine Chiller - One Fan wont run
I have the same problem. When I first discovered this, both fans had stopped working and the temp for both zones was over 80. So much for the wine that had been stored there. After leaving the unit unplugged for a few days, the fan for the lower section started working again but the upper fan is still overheating. Haier customer service says too bad, so sad (I discovered this problem in the 13th month of ownership). I'm sure it is not worthwhile to fix this so it is going out with the trash and I'll look for a different brand for the next wine cellar that I purchase. Any ideas?
Mar 01, 2009 | Refrigerators
Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Dec 30, 2008 | Oster 12-Bottle Wine Cellar - Black
Haier HVH025A Wine Cooler Logo
78 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
