Question about iLO XM-MP3-CD Car Stereo
Illumination? I am trying to put my sony xplod into my 04 aveo. There are illumination + and - wires but my harness doesn't and I'm not getting any lights or anything. All it will do is eject if the ignition is on.
  • thescarlet_b Jan 30, 2009
    thanks, that gave it power, but only when the headlights were on. In addition the clock will not hold memory. Not getting constant 12v?
    Sergeant:
  • 152 Answers
You need to splice the + wire into the Acc wire. the with power only when you turn the key. and the - wire into the black ground wire. hope this helps
Posted on Jan 29, 2009
  • lee r
    lee r Jan 30, 2009
    right, try splicing it with the power wire that gets a constent 12v. i belive its the yellow wire. and see if that works. some of the wireing harnesses dont match up all the way and its a pain.
I just installed a Sony xplode in my '05 Aveo, and had similar problem. With the illumination wires not hooked up, only problem was no memory to dash clock. I wired it to the power lead, now my dash lights are always on when the ignition is on, and only one side of daytime driving lights working. Apparently, the dash light illumination and clock memory circuits are completed in the factory stereo, but the aftermarket head unit is wired differently. The instructions say the Sony unit will not work in some Japanese cars, but the Aveo is Korean (Daiwoo). Stereo works great, but I haven't figured out how to make everything else work right. If I don't power the dash clock memory, everything else works right, but the clock resets every time it is powered through the ignition.
Posted on Nov 17, 2009
  • ohnodraco Nov 17, 2009
    RE: headlight problem
    It's probably easier to hook the power lead (yellow) directly to the battery with an inline fuse. If you have power only when headlights are on, you have wired into the headlight circuit between the switch and lights rather than a constantly hot.
    The + and - illumination leads light the stereo face when dash lights are on, but stereo is off, allowing you to see it in the dark when it's turned off, but the Sony is wired differently from the factory unit, so there are no corresponding wires on the Sony.
    Anybody actually done this install and made everything work correctly?
Need help installing xplod mex bt39uw
You have to invest in separate cables to the booster amplifier. Be careful that you have the proper relays and fuse for these or you might end up losing your car because of fire.
Mar 17, 2014 | Sony Xplod Mex-bt39uw In Car Audio...
I just hooked up a new pioneer stereo in my 04 chevy aveo and was left with 2 illumination wires without a home....then my battery died and now my check engine light is on...where do we need to splice...
The illumiation wires can just be capped off they aren't always used on aftermarket radios. It could be fluke instance that your battery died and you got the check engine light. I would take it to your closest autoparts store and have them read the codes most will do it free of charge and go from there.
Jan 05, 2011 | 2004 Chevrolet Aveo
Im trying to install a sony xplod radio in my 1995 Nissan Maxima. im using scorsche wiring harness A/B. i did all necessary installation procedures and the radio works but im not getting any sound out of...
Maxima Wiring Diagram
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Diagram for any aftermarket head unit
Black: ground
Red: switched 12volt (accessory)
Yellow: 12v Constant
Orange: Illumination (Dimmer)
Blue: Remote
White & White/Black: +/- Front Left
Gray & Gray/Black: +/- Front Right
Green & Green/Black: +/- Rear Left
Purple & Purple/Black: +/- Rear Right
Dec 23, 2010 | Car Audio & Video
I have a sony xplod l550x and i think its missing a wire because it says the illumiation wire is orange white and it dosent have one
PAGE 27 of THIS MANUAL does not show an illumination OR dimmer wire. This simply means the unit will have a bright display all the time - regardless of the headlights being on or off.
All radios do not have this feature.
Terminate the orange wires on the wiring harness so they do not touch metal (tape them off). They are not necessary to the proper function of the radio.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 24, 2010 | Car Audio & Video
Need a wiring diagram for a 99 hyundai accent tape deck
1999 Hyundai Accent Car Stereo Radio Wiring Diagram Car Radio Constant 12V+ Wire: Red/Yellow Car Radio Ignition Switched 12V+ Wire: Blue/White Car Radio Ground Wire: Black Car Stereo Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): White/Red Left Front Speaker Wire (-): Black/Red Right Front Speaker Wire (+): White/Blue Right Front Speaker Wire (-): Black/Blue Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): White/Red Left Rear Speaker Wire (-): Black/Red Right Rear Speaker Wire (+): White/Blue Right Rear Speaker Wire (-): Black/Blue
Jan 02, 2010 | 1999 Hyundai Accent
My sony sub isnt working, i checked the wires
do you have a power on signal wire hooked up?
Jun 08, 2009 | Sony Xplod (P589) Car Subwoofer
Wiring color meaning
did you buy a factory radio connector to connect the old harness to the new radio wiring if not you can get one at wall mart for 20 dollars and it will be color coded
Mar 08, 2009 | Sony XPLOD CDX-GT200 CD Player
iLO XM-MP3-CD Car Stereo Logo
503 people viewed this question
Top iLO Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Libran Moreno
Are you an iLO Car Audio and Video Expert? Answer questions, earn points and help others
