Question about Maytag Neptune MAH5500B Front Load Washer
Pedistal We have one we are going to put under the dryer. Any suggestions or guidelines since we do not have the directions? Jim
  • 51 Answers
Make sure the dryer is mounted high enough for you to open the lid and it is not too high that you can't get clothes in & out. Apart from that enjoy the extra space :)
Posted on Jul 27, 2007
Want to know if I can stack a kenmore elit gas dryer on a kenmore elite washer and on top of a 10 inch pedistal or will it be too tall?
The appliances were not designed to be stacked so I would not attempt it if anything I would build a shelf (ledge) to put the dryer on, then bracket it to the wall but be careful of the height especially with a gas dryer and be sure to have plenty of space for airflow. Good luck
Mar 27, 2014 | Kenmore 3.2 cu. ft. Plus Top Load Washer
How do you lower the height on a LG washer and pedestal? It's too high by 1" to fit under my wall cabinets.
The pedistal has 4 leveling legs on the bottom of it you can adjust to a certain point. You may have to take the lefts off completely and if it still doesn't fit, you unfortunately didn't measure properly.
Mar 16, 2013 | LG WDP4W 14 inch Pedestal White
I have a Toshaba 3HL 67U I can-not get the pedistal stand off it. Can you help me please. I want to hang this tv on the wall.
Don't know why u have that much problems to take out the tv pedistal stand off it.Just check make sure u take out all the screws around tv back of the pedistal,make sure u take it all out.Used one hand hold the tv bazel frame tight and the other hand and jusy wiggle and push it in the pedistal and put it out.The pedistal should came right out.
Jul 31, 2011 | Toshiba REGZA 47HL167 TV
How do I connect the dryer to the pedastool?
Hello- The Pedestal (depending on the make and model) usually connects to the dryer by unscrewing the dryer legs and using the bolts that came with the pedestal to screw through the pedistal into where the dryer legs, feet, were. This should be done with the dryer laying on its side. If you didn't get instructions with the pedestal then I would contact the manufacturer and they can email them to you (different brands have different systems). Good luck and best regards.
Sep 27, 2010 | Dryers
LG front loaded washing machine vibrates during
If its on a pedistal then that will raise your center of gravity and cause the unit to be less sturdy during a spin. It could also be due to a weak floor. You may want to try a product called "shake away pads". The probably sell them at like home depot or lowes. They will run you about 40 bucks but they just go under the legs and help absorb some shock. Good luck _MJ_
Apr 27, 2010 | LG WM2487H Front Load Washer
I want to clean the pump filter on a Kitchenaid washing machine. Where is it located?
unplug washer remove screws under lower panel down by feet, above pedistal (if you have one) look for large hose coming out of bottom of tub there is a handle on the filter it unscrews, if you have it on a stand or pedistal put the drain hose in a pan on floor or even better if you have a wet vac you can **** out the water you wont get all of it so some a couple of towels handy would be good. put a little vasalene or greese on the o ring before put ing back together you can buy me a dounut with the change you find, enjoy
Dec 08, 2009 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
I have a fixer upper house and put in a vinyl dryer vent to the outside and now i am told that it has to be metal. I have vinyl siding. Does it really have to be metal? where can I find Laws verses...
You can find these "guidelines" at your local municipality's or county's building department.
Psst: Don't go there, just take the suggestion and replace the vent with metal, which will last longer than
the vinyl, and can be painted, if you wish, with vinyl paint to match your siding.
PS: Don't go to the zoning board or building department or you will have to thank me after much expense.
Apr 17, 2009 | Dryers
Installing pedestals for washer and dryer
its not but it is a 2 person job, the washer is in excess of 200 lbs and must be lifted onto the pedistal, after that its just a few brackets and philips screew to secure it.
Feb 07, 2009 | Kenmore 15.5 in. Pedestal
How to remove pedistal from machines
lay the machine on its back. unbolt the base. 4 bolts. then set the duet back up. Its pretty easy to do but it takes two people to man handle the unit because it is so heavy. Please leave feedback if this helped.
David
Jan 14, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
We just installed a new whirlpool front loading duiet sport washer and dryer , It keeps going off balance it was installed by the store . we have had the service man out twice now , he is no help at all....
floor may not be as solid as you think.remove pedistal drawers make sure the screws holding pedistal to washer are tight 2 front and 2 back going into bottom of washer frame next adj legs so bottom of pedistal is as close to the floor as possible you may have to lossen the lock nuts to do this next try rocking the unit by hand and adj front legs as needed to stop motion and and give washer a solid feel retighten lock nuts up to bottom of pedistal
May 05, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
21 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
