Relocate the Documents and Settings Folder to a New Partition
I recently had a HD crash and have the opportunity to reinstall my OS, APPs and Data, I would like to Install the OS in its own partition.
I'm running XP Pro, 4GB RAM and a 120GB HD.
The Documents and Settings and Program Files Folders are automatically set up in the Root Directory.
The only idea that seems worth pursuing is getting the Document and Settings folder into a separate partition. To me, putting the Document and Settings in the root directory by default was and is a really bad idea on Microsofts part.
Think about it, a lot of applications put something useful and needed in there. Email, data, application data and databases, etc. Should the OS crash that's all gone. That's why backups are necessary. A lot of people, for whatever reason, can't, don't or won't create backups. Users are, therefore, cursed by their 'stupidity'.
I've read, on many boards, about how to solve this problem with some approaches that suggest that all one has to do is 'move' the D and S Folder over to the new partition which neglects the D and S hierachy tree in the Registry.
Other approaches involve the method put forth by MS to copy the contents of the D and S folder to a new folder, rename it and move it to the new partition. After that they suggest that the user access the registry and do a line by line replacement of the new path for the old Document and Settings path. This doesn't work, but I won't go into that now.
Lastly there is the method of moving the default location of the D and S Folder at OS installation using the 'Unattended' install method. This seems to hold some promise and I'll look into it more. Has anyone ever tried this?
Lots of thanks in advance for all help and suggestions
  • 36 Answers
Greetings.
The default installation procedure works best. In my experience at internet cafe, my documents, desktop and program files are set up in the "other" drives. Drive c is freeze(deepfreeze) with this config, we could at least have piece of mind.
Posted on Jan 30, 2009
Scanner fails to format image
Turn off your scanner. Exit the Smart Touch program.
If XP, navigate to this path: C:\Documents and Settings\[User Name]\Local Settings\Application Data\Smart Touch\[Scanner Model]
Windows 7 or 8: C:\Users\[User Name]\AppData\Local\Smart Touch\[Scanner Model]
Delete the "Sys" folder. Turn on the scanner. Re-open Smart Touch. You will see the Sys folder repopulate in the root folder.
Mar 27, 2014 | Kodak i1220 Pass-Through Scanner
Tip
An error message informs you that you cannot move or rename the Documents and...
To specify a different folder for the Documents and Settings folder during installation, follow these steps: 1. Run Winnt.exe or Winnt32.exe by using the /unattend option, and then insert the following entry into the Unattend.txt file, where z:\foldername is the path and folder name you want: [GuiUNattended]
ProfilesDir = z:\foldername 2. Install Windows. The path that you included in the Unattend.txt file is used instead of the default Documents and Settings folder.NOTE: This method does not relocate any key Windows components. Use this method if you require only user-specific data to be moved.
After you install Windows XP, to specify a folder other than the Documents and Settings folder for a particular user's data, follow these steps: 1. Identify the user's profile path. You can identify the profile path either by user security ID (SID) or by user path settings. The user SID method is preferred. To identify the user's profile path by the user SID loadTOCNode(3, 'moreinformation'); a. Use the Getsid tool from the Windows Server Resource Kit to obtain the SID. At a command prompt, use the following syntax: getsid \\ComputerName UserName \\ComputerName UserNameFor example: getsid \\windowsxp joedoe \\windowsxp joedoeThe results look something like this: = The SID for account WINDOWSXP\joedoe is S-1-5-21-1708537768-1993962763-1957994488-1003 b. After you obtain the user SID, start Registry Editor (Regedit.exe or Regedt32.exe), and then select the user SID under the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList To identify the profile path by the user's path settings loadTOCNode(3, 'moreinformation'); a. Log on to the computer as the user, and then type set at a command prompt. Note the setting for UserProfile, and then quit the command prompt. b. Log on to the computer as an administrator. c. Use Registry Editor to add the UserProfile setting to the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList d. Click the registry key, and then click Find on the Edit menu. e. In the Find box, type the value of the UserProfile setting, and then click Find Next. 2. In the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList registry key, change the ProfileImagePath value to reflect the new path that you want to use, and then quit Registry Editor. 3. Log on to the computer as the user, type set at a command prompt, and then verify that the path has changed.
Moving the entire folder loadTOCNode(2, 'moreinformation'); NOTE: This method does relocate key Windows components. Use this method only if you require the Documents and Settings folder to be moved or renamed and you cannot use the Unattend.txt file to change the name during installation.
To specify a different folder for the entire Documents and Settings folder, including key system components, follow these steps: 1. Log on to the computer as an administrator, and then create a new folder. 2. In the current Documents and Settings folder, on the Tools menu, click Folder Options, and then click the View tab. 3. Under Advanced settings, click Show hidden files and folders, and then click to clear the Hide extensions for known file types and Hide protected operating system files (Recommended) check boxes. 4. Click OK. 5. Click and drag all the folders in the Documents and Settings folder to copy them to the new folder, except for the folder for the currently logged-on administrator. 6. Log off and then log back on, using a different administrator account from the one that you just logged off from. 7. Open the Documents and Settings folder again, and then copy the profile of the administrator that you just logged off from to the new folder. This extra step is needed because you cannot copy the profile of the account that is currently logged on. 8. Log off the computer, and then again log on to the computer as an administrator. 9. Start Registry Editor, and then click Find on the Edit menu. 10. Type documents and settings, and then click Find Next. 11. For every registry key or value that contains the original path, replace the value data or rename the value or registry key to the new path.IMPORTANT: You must complete this change in the registry for every instance of the original path, or your computer may not start. It is imperative that you update all registry keys and values with the new path.
12. Restart the computer. You can now safely remove the original Documents and Settings folder.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Computer Crash
If your OS is Windows XP or Vista, you can try using the System Restore. Back up to a date prior to your having trouble.
If that doesn't work, then be sure to back-up all of your data and then try a repair/restore.
To do this start your PC with the OS disk installed in the CD drive. Start the OS instaqllation. Ignore the first repair opportunity that you have, but do use the second one taht comes up. That will perform a reinstallation of your OS without overwriting your personal data and settings. BACK-UP YOUR DATA B4 YOU TRY ANTHING!!!!
Rich
Dec 15, 2009 | HP Pavilion G60-249wm Notebook
I recently reinstalled my OS (Windows XP Media center edition). Ever since i reloaded the OS my WD My Book Home edition 1TB external HDD stopped showing up in the windows explorer as a drive letter. The...
I can't diagnose the drive issue... but I can offer a reliable and trustworthy data recovery solution that I had to use a year ago. It's Seagate's do it yourself data recovery and will work on your WD drive. So if you can't resolve the issue otherwise, consider this as a recovery option...
https://services.seagate.com/diysoftware.aspx
Sep 24, 2009 | Western Digital MY BOOK HOME 1TB EXT...
How to open without format when i open my drive it displayed do u want to format if i foramt my drive i will lose my data pls tell me how to open it without format
Windows has found a problem with the F.A.T. (File allocation table), thus windows wants to format the drive. Other Dos mode commands like FIXMBR, (fix master boot record) may make retrieving your data impossible.
There is a way to get around this with out loosing all your data.
Before we get started I need you to check the data cable & power cable connected to the drive. Unplug the power cord from the PC. Open your case. Disconnect the power cable & data cable from the drive. Than re-connect the power cable & data cable, follow the data cable to the motherboard & check it's connection.
(By doing this you are making sure the cables are fully connected, sometimes they come loose but you can't tell just by looking at them). Put your case back together & plug in the power cord.
Load your windows CD into CD-ROM. Start up your system & at the same time press the F8 key on your keyboard every two seconds. A screen like the one below will load;
Choose your CD-ROM with windows in it.
Windows will see you have a version installed & it will give you other options. Read the screen prompts. You want to create a partition within the free space of your drive. Follow windows instructions. Windows will creating a new partition . Install windows into that new partition. (This will be a full install). Your old windows will not load.
The data within your old partition will not be deleted!
When you have finished installing windows update it. Install motherboard drivers, printer drivers & programs ect. When finished you can now copy folder & data to the new windows. (All this will take time). Most data will be located in folder shown below. You can copy & past the data / folders from the old partition to the new windows;
C:Documents and Settings User nameApplication DataMicrosoftAddress Book
C:Documents and Settings User nameDesktop
C:Documents and Settings User nameFavorites
C:Documents and Settings User nameLocal SettingsIdentities
C:Documents and Settings User nameMy Documents
Data from any program you may have installed.
When you are 100% sure you have recovered all your data, you can delete the old partition through windows disk management. How to run disk management?
Click the start button & click Run. Type, diskmgmt.msc into the run window & click ok. Within in disk management you'll see all partitions on your hard drive, you'll also see your CD-ROM & any other drives What was once your C: drive will most likely be labeled to another letter. To find your old windows right click on a drive within disk management & click open. (Make sure you do not delete the wrong partition / Windows).
To delete the old partition right click on the old partition & click, Delete Partition. Close all opened windows & restart. Windows will automatically add the drive space to your new partition.
Operation complete.
Mike
May 06, 2009 | Maxtor Hard Drive
I upgraded my pc with foxconn when i boot up the set menu won't
The information you have provided is lacking detail. From what you have posted I'll take a guess about your issue. You upgraded your motherboard to a Foxconn motherboard. (Include the model number).
When you boot the system windows will not load because your new board is different from the old. You will need to load the windows CD into your CD-ROM drive & do a fresh install. Windows does not like to install over it's self. (Windows registry can not load because the motherboard is too different).
The best thing to do is format the drive & than install windows.
If you have data on your hard disk drive & you do not want to loose your data there is another option. If your hard disk drive is large enough you can tell windows to create a partition within the free space of your drive. (Following windows prompts).
Once the windows CD has created a new partition for you. Install windows onto that new partition. By doing this all your data will not be deleted. Install window & your Foxconn driver's. Update window through windows update. When everything is finished you can now copy your data to the new windows. Here is a small list of folder you should copy to your new windows;
C:\Documents and Settings\ User name\Application Data\Microsoft\Address Book
C:\Documents and Settings\ User name\Desktop
C:\Documents and Settings\ User name\Favorites
C:\Documents and Settings\ User name\Local Settings\Identities
C:\Documents and Settings\ User name\My Documents
When your 100% sure you have copied all your data to the new windows you can delete the old window. Use windows disk manager program to delete the old windows partition.
How to use window, diskmgmt.msc. Click the start button & than click Run. Type, diskmgmt.msc into the run window & click OK.
Delete the old window partition.
Mike
May 03, 2009 | Foxconn Computers & Internet
Uninstallation of Windows Vista ultimate Edition
Just boot from the installation cd. when prompted to repair or don't repair choose don't repair on the next step you'll asked to format the hardisk or leave the current partition. if you dont have any important data I recommend to format your hardisk. Backup yaour data before installing
Mar 21, 2009 | Microsoft Windows Vista Ultimate Edition
Wont come on
First, locate the Windows CD that shipped with your PC, along with the CDs for your application software. If you downloaded your antivirus, firewall, or other programs, copy those downloads to a CD or to some other type of removable media. (If your system didn't ship with a Windows CD, your reinstallation files are situated on your hard drive; I'll describe how to access them in just a minute.) Also, dig up the instructions that your ISP sent you for configuring your network settings, and keep them close at hand.
Copy the contents of your 'C:\Documents and Settings' folder (or whichever folder you store your personal files on) to a CD or other removable medium. Then grab any other critical data and back it up. It helps to collect the installers for the latest drivers for your PC's graphics card and other hardware, too.
Ready to Reinstall Now insert the Windows CD that came with your PC, and reboot your system. If you didn't receive a Windows disc with your machine, the files you need are sitting in a hidden partition on your hard drive. To access them, press the keys indicated on your screen when you reboot, but before Windows loads. The keys differ from vendor to vendor, so contact your PC's manufacturer if you don't see the prompt.
In many instances, the only available option is 'Return the drive to its factory condition', which destroys all documents, photos, and other data files on your PC. That's why you made a copy of your data folders.
You get more options--including the ability to preserve your files and settings--when you use Microsoft's own Windows XP installation disc. Make your selection, and follow the on-screen prompts to complete the reinstallation.
Starting Over Regardless of which option you choose, you'll have to reconfigure your network connections, reinstall some of your device drivers, and update XP and your applications manually.
To configure your Internet connection, right-click My Network Places, click Create a new connection, and follow the prompts, entering the appropriate information you received from your ISP.
Once you've re-established your Internet link, you must reinstall and update your firewall, antivirus, and antispyware programs.
Next, check to see which of your device drivers need updates: Rght-click My Computer and select Properties, Hardware, Device Manager. Look for entries with yellow question marks or red exclamation points. A question mark indicates that Windows is using a generic driver for that device instead of one specifically designed for it; an exclamation point means that the device is not working.
The drivers for graphics boards, sound cards, and printers are most likely to need an update. If you haven't already done so, visit the vendors' Web sites to download updated drivers to your PC. Run the installer for each updated driver, allowing XP to reboot when needed, or right-click the entry in Device Manager, choose Update Driver, and step through the wizard, selecting No, not this time to the Windows Update question, and choosing the specified location option when it appears. When you can navigate to the driver file, select it and click OK to install it. When you finish updating your drivers, close all open windows.
Updates Galore Your next stop is Microsoft's Windows Update site. Click Start, Windows Update, and follow the prompts. Since you'll probably be downloading many megabytes of updates, you might want to find yourself a good book or seek some other diversion while you wait.
When the downloading is complete, you'll be ready to reinstall and update your applications. Don't forget to update your critical apps as well. Microsoft Office, in particular has some important updates. Download them at the Microsoft Office Online Downloads page.
Once you've restored your applications, begin replacing your data. The first priorities are the My Documents and Application Data folders, which you'll find in the folder with your logon name inside 'C:\Documents and Settings'. To bring back your Internet Explorer favorites, restore the contents of the Favorites folder. Also restore the Shared Data and Application Data folders inside 'C:\Documents and Settings\Shared Documents'. Once you've reintroduced all of your data, your Windows refresh will be complete.
Jan 12, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
Problem with the drive
Hi pravin,
One must pay close attention to the display screen when performing a new instillation of windows. Windows will show you the drive partitions. In your case windows will show there are two partitions. One C:\ & a second partition F:\. Perform a 3rd installation of windows. When you get to the screen where you can see both partitions (C: & F:) have windows delete the F: partition. Than have windows format the C: partition. Once C: has been formatted have windows install its self onto C:\
Install your driver software for your board. Than update windows through windows update service.
If you wish to back up your personal data to a CD/DVD writer, suggest you do this before formatting the system. Suggested folders to back-up.
Once windows has been updated & you install anti-virus software you can copy & past each folder over the new folder in windows.
How to install windows XP. http://support.microsoft.com/kb/316941
Good luck pravin!
Mike
Sep 23, 2008 | Microsoft Windows Xp Home Edition Sp2...
Password
There are programs to hack windows xp password. But often they do not work or cause more trouble to your system. The solution is doing a new windows setup without formatting the HD and without deleting all system file and user setting. To do this reinstall win using a different folder or try using recovery cd with partial recovery (be careful not to delete all data if you use recovery cd. Generally in this case is better to use a generic windows cd for a temporary installation, to recover your data. after a new system is installed you may get your data back from folder C:\Documents And Settings\......
good luck
Feb 21, 2008 | Computers & Internet
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
