Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Any belts that can sub. for the RR
I have a Eurka Boss Smart 4870. I am having the problem with the roller bhrush not spinning, when it is put on the carpet. I already read here that others are having the same problem because Eureka wonderful plastic belt is to slippery against the shaft and it dosen't get enough friction to catch the belt. People here suggested putting contact cement or electircal tape on the belt/shaft to gain friction and this dose work.....but I am wondering if there is another belt from any other manufacturer that is the same size that would work??????Any ideas, where can I get the size of the belt anyway????
  • bdjjmj Jan 29, 2009
    Thanks I will give that a try!!
  • Frank
    Frank May 11, 2010
    yo can do that same as the belt in the car.
    take the belt off the vacuum, take it to any of appliance store or repair shop, have them match the size of the belt.
Applied the electrical tape to the motor shaft as suggested by another poster. The tape ripped off, but the sticky residue left provides enough friction to grab the belt and cause the beter brush to turn correctly. Thanks
Posted on Jan 31, 2009
Vacuum squeals when running. Big boss smart vac 4870
most likely you have something trap in the blower fan. if not chech for some obtruction in the tube. a piece of paper or the like. also check you belt.
Feb 06, 2011 | Eureka Smartvac 4870 Bagged Upright Vacuum
I need to know the correct belt for my Eurecka Boss 4870 Refurbished. Every time i put the belt on it brakes.
the correct belt for this machine comes in a package. It should be Eureka Style R belt. (61110-A)
Pic attached.
This is the correct belt. Anything else will just snap right away.
Good luck.
Nov 13, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Eureka The boss Smartvac Model #4870 roller brush won't turn even on the highest setting and the belt smells hot. we took the belt off. How can you tell if it needs replaced?
Just by what you explained I can tell that it needs to be replaced. The belt doesn't have to be broken to need replacing, if it is stretched and worn then it will slip on the motor shaft and not turn the brush roll and get hot. Here is a link to the belts you need and the manual which has instructions:
Bissell 4870 Belts
Owner's Guide (3,666K download)
Dec 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Brush roller spins until it touches the carpet, then stops.
That means that the belt is stretched or worn. Here is a link to the replacement belts you need and a manual which has instructions:
Eureka Smartvac 4870 Belts
Dec 06, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
Jan 18, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Euerka Smart Boss upright
Price of Belt: $ 7.49 from www3.sears.com
Part No. 61110A
Price of Bag: $7.99 for a pack of 3.
Part No. 61115A or Eureka Bag Type RR
Estimated Repair Cost: $75-90 pending parts and labor rates
The likely possibility is that the belt was installed wrong. Without seeing the unit myself, I cannot say if the pulleys are mis-aligned. I will get back to you if I find any new information.
Mar 14, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
153 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
