Question about HHP TT8810 Signature Capture Pad - (30104-0088)
I have a T8810 signature capture pad, and all it says is uninitializing.
Need part number for power pack for a VeriFone MX830?
hello
p/n for 12v, 1A power pack CPS11212D-1B-R and it is worth about $15
please send me 4 thumbs up
Aug 03, 2011 | VeriFone MX830 Signature Capture Pad PN...
UnsatisfiedLnkError
Seems a JAVA problem.Can i have more info. about when and how you get the error?
Mar 08, 2011 | Interlink ePad E-Signature (VP9801)...
I have 2 ing@nico i6780's that need repair, the back light is out where can i have it fixed or how do i fix it
the only way that i know to get this fix is calling directly to Ingenico or you merchant provider if you have any warranty on it.here is the website. I hope this work for you.
http://www.ingenico-us.com/ingenico-customer-services_96.html?lg=US
Dec 10, 2010 | Ingenico i6780 Signature Capture Pad -...
Blank screens on ingenico i6780
hardware issues, they need to go back to ingenico or someother repair depo for repair.
or so I have seen. If anyone else or you have a different suggestion, please post.
May 07, 2010 | Ingenico i6780 Signature Capture Pad -...
Error code 106
do this
The error "ComponentMoveData...Error Number: -106..." indicates that the installer cannot decompress a file. This can happen if the CD-ROM is dirty or damaged, if hard disk space is insufficient, or if the installer conflicts with an application or device driver.
You could try copying the contents of your CD-ROM (or the essential folders) to your HDD or a network drive. You will soon find out of there is dirt or damage on the CD, and if not, you can easily then install from your HDD or network drive.
Dec 01, 2009 | Ingenico 6770 Capture Pad Signature...
How do you capture signature
To capture signatures you must have a graphic tablet that has a pen mouse with it. Procure and install the tablet and then use the pen mouse to capture your signatures. It is an electronic slate that is attached to the USB port and use to trace drawings, maps and such non linear graphics. Basically for outlines.
Nov 18, 2009 | ACECAD 3" x 2.25" Flair GT-302 Graphic...
Signature pad writes straight line instead of signature
you can either try to unplug the pad for a minute. or uninstall the pad and then reinstall it again. and if that doesnt work then someone watered or damaged your pad some how.so you would have to buy a new
Dec 01, 2008 | Computers & Internet
I INSTALLED MODEL T-S461-HSB TO MY WINDOWS XP AND IT STILL DON'T WRITE OR SHOW THE SIGNATURE THATS BEING WRITTEN DOWN. CAN YOU PLEASE TELL ME WHAT I'M DOING WRONG.
you download the software eapp for using the signature pads here is the minimum requirements of install eapp software
The eApp software was designed to function on both laptop and tablet PC computers.
Below are the hardware/software requirements for each configuration.
Note: eApp should run under Windows 2000, Windows XP Home and Media Center versions but Windows XP Professional (32 bit) and Windows Vista (32 bit) are the only 2 operating systems that the eApp help desk currently support. Use of an unsupported operating system can inhibit your ability to use eApp as it was intended and cause extra 3rd party support expenses.
Laptop -
Minimum Requirements:
1.2 GHz CPU or faster
512 MB Ram
20 GB Hard drive
Windows Vista
Recommended Requirements:
1.7 GHz CPU or faster
1 GB Ram
60 GB Hard drive
512MB USB Flash
Firewall and Virus protection software -
Any third-party protection software will do. Firewall and virus protection software should be running at all times to insure that your computer is not compromised and that customer information is not stolen. In the event of a system error you may be asked to provide the help desk with the results of a current virus scan to insure your machine is functioning properly. Failure to provide the scan results may result in a delay in resolving the problem.
Signature Capture Pad - Topaz SigLite Slim 1x5
Tablet PC -
512 MB Ram
20 GB Hard drive
Windows Vista
1.5 GHz CPU or faster
1 GB Ram
60 GB Hard drive
512MB USB Flash Drive
Tablet PC Signature Capture Software -
Topaz Tablet PC Software $100.00 USD
A signature capture pad is NOT required but special software is needed for the Tablet PC.
Mar 14, 2008 | Computers & Internet
HHP TT8810 Signature Capture Pad - (30104-0088) Logo
82 people viewed this question
Top HHP Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Don A
Don A
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
