Question about HP LaserJet 1020 Printer
Docs in queue won't cancel so I can print another document
Hp photosmart C4580, Cancel documents in queue, but documents won't delete and then unable to print anything else.
    Genius:
  • 1,605 Answers
Turn of the printer and unlug the data cable.
go to start>>printer and faxes, open the printer queue and deleted the job.
plug in the data cable and turn on the printer
Posted on Jan 29, 2009
How do I cancel documents in a queue
Cheers james heron
To cancel a queued document, there are several ways, it is best to go to printing devices and open what is printing the printer you want to cancel, click Cancel and disappear the document.
In many cases this does not help then you click cancel, the document continues to appear, that's when it works best to turn off the computer and turn it on again.
Another thing you can do to disappear a file from the print queue, disconnect the printer's USB cable and connect it again, for it can do so from your computer or from the same printer.
Another way that can work is, turn the printer off and turn it on again, you should always look the team to lose the memory of what is printed, in order to begin again.
How to delete documents in my printing queue en Rellenado
Nov 23, 2015 | Office Equipment & Supplies
HO C4200 DOCUMENT STUCK IN QUE CAN'T DELETE
First You Need to Open the Print Queue, follow the below steps on how to open a Print queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double click on the appropriate printer to open up the Print queue,Check whether you have any pending or the queued jobs, try to cancel the jobs by following the below steps.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
• To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
• To cancel all print jobs, click Cancel All Documents on the Printer menu.
If you are using an HP printer and a windows vista operating system then you are lucky to automaticlly fix the issue with the HP Print Diagnostic UtilityClick Here For How to cancel printing or to delete a print job that is stuck in the print queue in Windows XP.
Alternatively You can check the below steps.
Delete Pending Jobs
How To Restart Spooler restart In Windows Vista
Click the Start button.
Click Control Panel.
Click System and Maintenance.
NOTE: This step is not required when using Classic view in Windows Vista.
Click Administrative Tools.
Double-click Services.
On the User Account Control window, click Continue.
Click Print Spooler.
Click Stop to stop the Print Spooler.
Click Start to restart the Print Spooler. Then click Restart
Click OK
Hope this helps!
Thanks!! - See more at: http://hpanswers.blogspot.com/2008/10/cancel-and-delete-stuck-print-jobs-in.html#sthash.QD3KNI9q.dpuf
Jul 01, 2014 | HP LaserJet 4200 Printer
HP Photosmart Plus 209a-m doc in queue won't delete
using windows explorer, go into windows/system/spool/printers and erase contents in last item
Sep 14, 2017 | HP PHOTOSMART PLUS B209A All-In-One...
I have a document stuck in the print queue, which won't cancel or restart, help!
Turn off printer for 2 minutes @ least, turn back on, or delete printer and re-install printer. Go to HPsupport website enter your printer model info update drivers.
Jan 28, 2012 | HP PSC 1510 All-In-One InkJet Printer
GOT 33 PRINT JOBS IN QUEUE L IKE TO DELETE THEM FRO HP OFFICEJET PRINTER4680
Hi hunter707515
under Win XP :
go to start \ settings \ printers and faxes , select the jobs , clic on documents and cancel .
under Win 7 :
go to start \ devices and printers . Right clic on the printer , select open \ documents in queue \ select documents and cancel
Best regards ,
fanaudi .
Feb 27, 2011 | HP J4680 Office Jet All-In-One Printer
Unable to print because there's a document in the queue that could not be deleted or cancelled
Unplug the USB cable , than delete the printer icon, then restart the computer, once the computer is restarted, then connect the USB cable, after few seconds printer icon will appear again, than try to print.
Aug 12, 2009 | HP PhotoSmart C4280 Laser Printer
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
Cannot cancel copy process keeps on printing even when I press cancel button prints the same document over and over I want to print a picture from my computer can I download a picture from my camera...
Try doing this
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Nov 18, 2008 | HP Office Equipment & Supplies
Unable to Cancel Documents in a Print Run
if you want to stop a print run simply press the stop button on the printer
next go to the control panel and get to the add a printer section
click on the printer and open up see what is printing
highlight all in the print queue and delete it there no print queue , nothing to print
to be sure and not waste paper remove all but 1 sheet and press the start button
keep using that paper until what is spooled in the printer memory has been used
Mar 24, 2017 | Canon BJC 4400 InkJet Printer
HP LaserJet 1020 Printer Logo
813 people viewed this question
Ben Johnson
