Question about Dryers
Thermostat have to chamnge the thermostats and dont no which is th hot 1 is it the one with the dot on?
  • 135 Answers
Different makes have different coloured dots but mainly blue dot is low temp and red is high.
The high temp will be to the left as you look at them.
Hope this helps & thanks for using Fixya.
Posted on Jan 29, 2009
Does the black single wire go onthe right pole with th dot?
Hi Holly:
The black wire would typically be the supply or "hot".
Putting this through a switch will result in power coming out of the switch, and would still be connected to a black wire which would go to the fixture.
The dot on the switch really does not serve a function that I am aware of.
NEVER connect a neutral (white) wire to a black through a switch as you will create a short circuit.
Hope this helps.
Feb 29, 2016 | Electrical Supplies
Lexus lx470 on the left bank cam which dot do i line up 1 dot or th 2 dots
here's a u-tube link for a very detailed demonstration of the whole procedure, the actual vehicle in the video is a lexus lx 470
How To Change The Timing Belt In Toyota V8 2UZ FE 3UZ FE Tundra Sequoia...
Jul 24, 2014 | 1999 Lexus LX470
We have a reliance 600 about 4 years old. Recently when you turn on the hot water you get a lot of air out of the line. Also the other day we had scorching hot water and then no hot water. We reset the...
1) Reliance 606 Electric water heater, AO Smith subsidiary.
Good brand.
Copy following links:
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) First: Test elements using cheap multimeter from hardware store.
Next: If elements test OK, then replace both thermostats.
3) If that doesn't solve problem, then add comment Jan 2013 and report what you find.
Jan 26, 2013 | Water Heaters
Instructions on how to use holts wondarwald
Holts Wondarweld
Flush engine.
EXTERNAL CRACKS
1 Run engine until hot,drain off enough coolant to remove thermostat.
2 Remove thermostat.
3 Mix contents of can thoughoughly! and pour contents into thermostat opening.
4 Replace thermostat cover.& fill radiator with hot water,replace radiator cap.
5 Run engine at a fast idle for 15 mins,dont allow to boil.Top up if necessary.
6 Leave Wondarweld in system for 2-3 days then drain off,flush system replace thermostat and refill.
HAIRLINE CRACKS
1 MIX thoroughly and pour into cold engine (radiator if it has a cap)
2 Run engine until hot.
3 Allow engine to cool then run again until hot.
4 Follow procedure 6 above.
INTERNAL CRACKS
1 Follow external crack instructions except after pouring Wondarweld into engine remove spark plug from
affected cylinder and run engine for 20 mins. If more than one cylinder affected run for 5 minute intervals.
2 Allow engine to cool then drain cooling system and refill with clean water.
3 Drain sump & flush,refill with fresh oil.
Note:- 1/2 pint of Wondarweld for every 6 pints of water,DO NOT add antifreeze for at least 3 days after process.
Aug 05, 2012 | Cars & Trucks
My 02 buick century keeps popping the cooling fan fuse and my fans dont turn on is it my pcm ??
I just replaced a set of cooling fan motors for this problem, and the connectors on the motors were even melted, had to replace connector pigtails as well, th fans also cools the a/c condenser so if the fans quit then your a/c will not be very cool unless your driving and the air flow will aid like a fan would..
Jun 10, 2012 | 2002 Buick Century
Overheating cant feel water passing through upper hose on radiator
Wait for th engine to cool off then remove th radiator cap and let the engine run until it shows signs of getting hot. If you can't see the coolant flowing in the radiator then the thermostat is not opening or there is no coolant in the radiator. Make sure the radiator is full. If that doesn't help then replace the thermostat.
Dec 24, 2010 | 2000 Dodge Neon
Th unit is turning off on its' own. It smells
Please check your thermostat, it could be defective and
needs to be replaced. It is overheating at the moment,
and may bogged down anytime. That is why it is unusually hot. Please check the thermostat, before your
unit gets damage. Hope this will help you.
Jan 10, 2010 | Essick Air 4D7 800 13 Gallon Humidifier
Need schematics for honeywell s861ou3009
Those terminals are the power to the module. The tr should be the 24v (hot) line coming from the transformer. The tr/th is the common from the transformer and the th is the 24v line coming back from the t-stat. So tr stands for transformer. the th stands for thermostat. And the th/tr is the common.
I know you ask for schematics but I felt that I could easily explain it to you. It really isn't all that hard. In some cases the tr does not need to be hookup. if you only have two wires there than just hookup the th/tr and the th and it will work.
Nov 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I'have a equator washer n dryer///ez3710v// have a wiring problem at the thermostat i have a block with two red dot an two with black dot, dont know which wire going where suppost to go on that thermostat...
if you are still waiting for a solution on this here it is:
Each and every wire in this unit are labelled and so if you can see the labels on the four wires they would be labelled as FD, FDX, FE & FEX, FD & FDX should be connected to the two black dots and FE & FEX should be connected to the two red dots.
Aug 31, 2009 | Equator EZ 3710 Front Load Washer / Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
