Question about HP Photosmart 635 Digital Camera
I can view pictures that were taken on my camera but when I go to take pictures the screen is black
My memory card still holds my pictures and I can view old pictures taken before the incident. My camera turns on and functions fine but all I can see if Blackness. The camera has hardly been used so I can't think it is an overuse issue. None of the pictures turn out at all. Let me know what you think...I have changed the batteries and done a few other things but nothing seems to work.
  • Bronchobuck May 11, 2010
    Have you used the camera before ie:
    have you used the four buttons (in a column to the right of the LCD screen)?
    When the camera is first turned on this is what happens:
    1. Hewlett Packard logo
    2. screen that briefly display how many shots still to be taken and the camera settings e.g. flash.
    3. Blank screen.
    To turn on the screen: press the top button described above and marked with a camera icon.
    Please forgive me if I have offended your intelligence by describing the basic operations of the camera.
    Genius:
  • 2,985 Answers
Does the screen deliver anything such as menu. Or can you see ghost images if looked at from the side? If you see nothing then this is a connector issue of a circuit board failure. If you see ghost images then it a back light failure. Either way this is a return to HP situation. If under warranty via the seller if not under warranty contact HP customer support. If they are quoting money- you may find it more economic to write it off and get a new camera.
Posted on Jul 27, 2007
SOURCE:
My nikon coolpix s6300 won't let me view the pictures i have taken on the camera.
I can only offer this: (sorry if it does not help)
When the micro USB Cable is plugged into the camera you MAY be able to take photos. The camera MAY work normally EXCEPT for the MONITOR or Screen. The screen is TURNED off when you plug in the cord.
Nov 01, 2017 | Nikon Coolpix S6300 Hd Digital Camera
The display is black through the viewfinder and the screen. The menu displays and pictures taken previously on the memory card can be viewed, but in camera mode, the screen is black and pictures taken are...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Sep 05, 2010 | Canon PowerShot S2 IS Digital Camera
Can not view pictures
No this camera does not have any internal memory. All images should be written to the memory card if the memory card is inserted properly. If the memory card is not inserted correctly the camera screen will show a message of No card. Do you see that message?
Apr 27, 2009 | Olympus E-520 Digital Camera
Distorted/damaged pictures
Please check the image size (pixels x pixels) setting or the resolution (MP). Seems like the camera is shooting in low resolution. Have you used this memory card on a mobile phone or another camera? Format the memory card and try again.
Feb 14, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
A95 LCD screen black and unable to take photos
Its common problem in canon cameras and I have solution. please let me know if you didn't find in chat.
Sep 02, 2008 | Canon PowerShot A95 Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
Image not visible on monitor screen
My viewing screen is black. I had successfully taken a picture, viewed it, and turned the camera off. When I turned it back on about 30 seconds later, the viewing sceen was black. I can 'take' a picure, but it comes out black. Help!
Nov 12, 2007 | Casio Exilim EX-V7 Digital Camera
Black screen when viewing photos taken
When the picture does not display - do you see the normal text and icons that you would expect to see? Or, is the screen completely blank?
Feb 22, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
HP Photosmart 635 Digital Camera Logo
70 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
