Question about Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
Pro 115 manual
I need a service manual for a pro 115 portable heater. How do you adjust the fuel pump pressure/ 443-350-1199 Dave
Dave go to www.desatech.com you can down load and print off a copy of this manual, you will need Adolby 6.0.
Posted on Mar 14, 2009
Replaced rotor on my 115 ready heater now it puts out way to many fumes,it burns my eys.any suggestions
The fuel/air mixture is not right.
  • Start by setting the pump pressure to factory specs.
  • Stop all air/vacuum leaks between the air pump & nozzle
  • If the problem persists, replace the nozzle. Desa recommended annual replacement. Simply stated- the nozzle wears out to a point that the fuel is a spray rather than a fog and the fuel can't burn completely.
  • You don't state the type being burned. Diesel smells more than kerosene.
Feb 05, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
100,000 btu reddy heater runs but smokes alot and you can smell raw fuel what's wrong
It sounds like the fuel is contaminated,if it is not k 1 kerosene ,or grade A diesel fuel,this could be the problem,clean the tank,and start with a k 1 kerosene,and see if it clears up,then go back to the grade A diesel fuel,if this does not work,replace the filter in the tank,and check the intake air filter,make sure it is not cloded up,or behind the filter,last thing ,only after checking and doing all of this,the pump pressure may need adjusting,but do not try this with out a pressure gauge,and a manual .You can break the pump easy.I have a manual for the ready heater,just let me no if you need it,please rate,thank yopu,> roniecon@gmail.com
Jan 05, 2011 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
My reddy heater 115 pro starts, but shuts off after about 5 seconds of running , i replaced the filters and nozzle about 2 years ago
Here is a service manual:
http://www.desaparts.com/service_manuals.html
If the flames actually starts but the unit shuts off after 5 seconds you need to check the pump cover on your heater to make sure you have no cracks in the rear cover.
This could be from low pump pressure but most often this problem is caused from a defective control board.
Oct 03, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
RM 115 NO Fire
Hi
Read this from Reddy
http://www.reddyparts.com/pressure.htm
Feb 14, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heating & Cooling Logo
531 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
