Question about Canon S520 InkJet Photo Printer
Canon S520 printer won't print
When I turn on printer the carridge bangs on the end and the orange light flashes one time between green flashes
  • Anonymous May 26, 2009
    my printer would not prin anything whit black
    Sergeant:
  • 250 Answers
There is a encoder strip in the printer to which the cartridge head carriage reads .if this encoder strip is dusty or loose the carriage cannot read so it bangs from left to right.and due to this printer cannot get set to its position.and the orange error light blinks.that transperant long strip with blacl vertical lines on it has to be checked.
Posted on Jan 29, 2009
Flashing green orange lights
The Canon service info is:
B200/P10 - Orange and green light blinking 10 times Description: A service error has occurred. Resolution: 1. Turn off the printer. 2. Disconnect the power cable. 3. Open the printer cover. 4. Check for any orange protective tape or white polystyrene and remove if necessary. 5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary. 6. Close the cover. 7. Reconnect and turn on. If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
The error code is usually given for a foreign object present in the print head carriage path, so check at both ends for a crumpled up wedge of paper. If nothing is found, it is most likely that your print head has an over-heating problem and is dying
Dec 10, 2017 | Canon PIXMA iP4600 Color InkJet Photo...
Canon S520 Printer
try powering it down for a couple of hours for a full reset.
Mar 03, 2008 | Canon S520 InkJet Photo Printer
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Cannot get my canon to respond. Has worked fine in the past. I push to bring online and the light still blinks yellow.
Your machine does a longer green flash and then a series of orange flashes and then green again. I need to know how many orange flashes between the greens to tell you the problem..
Aug 03, 2009 | Canon S520 InkJet Photo Printer
Printer is not responding
This is the error light page from the S520. Not sure about this, but probably the same on the S530. 8 Blinks means replace the ink absorber and reset the counter. I think the ink absorber can be gotten at from the bottom, BUT NOT SURE. Try this at your own risk!
7.1 Service Mode Operation
1) With the printer turned off, hold down the RESUME button and press the POWER
button (the green indicator lights and the desired service function can be selected).
2) While holding down the POWER button, let go of the RESUME button before pressing
the RESUME button again twice in succession. Then let go of both RESUME and
POWER buttons.
(At each press of the RESUME button, the indicator toggles between orange and
green.)
3) During printer initialization, the green indicator blinks. When the green indicator
stops blinking and remains on, press the RESUME button the specified number of
times to execute the desired service function, as listed below.
green.)
Press Indicator Function
0 times Green Power off (Even if there is no print head mounted, the
carriage will return to the home position and lock.)
1 time Orange Service/factory test printout (Including ink sensor check)
2 times Green EEPROM information printout
3 times Orange EEPROM initialization
4 times Green Clears the waste-ink counter (S750/S520)
Waste-ink counter settings (S900/820) (See page 2-34)
5 times Orange Destination (model) setting
After reaching this service function, press the RESUME
button the number of times specified below to set the
destination.
Setting
0 times BJ F900 BJ F890
1 times S900 S820 BJ F700 BJ F500
2 times BJ F890PD S750 S520
3 times S820D
Note: pressing more than 3 times has no effect.
6 times Returns to the function select stage (S750/520)
6~9 times Not used for servicing (S900/820)
More than Green Returns to the function select stage (S900/820)
10 times
4) After selecting a service function, press the POWER button. The green indicator
lights and the service function will be executed. (After each function is executed, the
printer returns to the service function select stage.)
READ THIS CAREFULLY !
Larry
Nov 30, 2008 | Canon S 530D InkJet Printer
Canon S520 blinks 7 times yellow then once green over and over, won't print
Read the info on the link below:
Solutions for flashing lights Issue: Alarm / Power light flashes orange 7 times consecutively (Print head error)
1. Reseat the print head S520 / S750 2. The Print Head may need replacing - S520 3. The S520 may require repair
spacer.gif http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=231&modelid=6611
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | Office Equipment & Supplies
Canon S520 Won't Re-Set after installation of new Canon waste ink absorbers
plz check the website
http://www.fixyourownprinter.com/forums/inkjet/50418#1
Jun 30, 2008 | Canon S520 InkJet Photo Printer
Canon s520 problem
I solve mine (4 Yellow Flash + 1 Green) by pushing on the white gear, located at the end right inside, where the cartridges are cleaning. This help the movement of the gear, it was stuck or gem. Do this when you just turning on the printer, then you ear the cycle noise, Your fingers will sense the movement of the gear. Tips: Push the cartridges block to the left to let you enough space to put your hand inside.Now it work normally.
Feb 12, 2008 | Canon S520 InkJet Photo Printer
My canon s520
The user guide for that product says that 7 flashes means the printhead is defective and that you should contact Canon's customer care. If you've recently replaced the print cartridge(s), try putting the old one(s) back in. If the printhead is truly defective, there may be no choice but to contact Canon or replace the printer.
Aug 21, 2007 | Canon S520 InkJet Photo Printer
Canon S520 InkJet Photo Printer Logo
270 people viewed this question
old marine
old marine
