Question about ViewSonic VA902 19" LCD Monitor
Vertical Vs Horizontial display, no VGA rotate icon to change it
I followed the direction in order to change the display but there is no icon as direct on bottom RH corner for windows XP to rotate the monitor display.
THe display is fine in my laptop only when I dock with the monitor
  • 585 Answers
On some systems I have seen "Ctrl, Alt + arrow" change the orientation. That works on the XP's at work, but not here at home. But it's worth a try.
Posted on Jan 29, 2009
There are two adjusting screws on the buick century headlights, which is the horizontial screw
ADJUSTMENT PROCEDURE
Complete the following steps and refer to the accompanying illustrations in order to adjust the headlamp aim:
1. Ensure that the headlamps are a distance of 7.6 m (25 ft) away from the wall.
2. Mark a vertical line on the wall. Align the vertical line with the center line of the vehicle.
3. Mark a horizontal line on the wall. Ensure that the distance of the line to the floor is equal to the distance from the center of the headlamp aim dot to the floor.
4. Using the following components, ensure that the following specifications match the specifications in the illustrations:
^ The headlamp aim adjusters (1).
^ The zero set access hole (10).
^ The zero set meter (11).
Feb 21, 2015 | 2001 Buick Century
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 15, 2013 | Samsung N120-12GW Netbook
HP (Altec Lansing) monitor is displaying sideways, my friend lent me her laptop
Some graphics cards have rotation "hot keys" enabled by default and this is probably the most common cause of this problem. The exact procedure for rectifying the display may depend on the particular brand and configuration of the graphics card in the problem computer. One of the following options may help resolve the issue.
Option One:
Try using the keyboard combination, "Control + Alt + Up Arrow Key". Control + Alt along with one of the arrow keys is a fairly common rotation hot-key configuration and may just do the trick.
Option Two:
If Option One doesn't work, see if there is a graphics card icon displayed in the Notification Area (near the Windows Clock). Clicking (or right-clicking) the icon may reveal a "Rotation Settings" option that will allow you to revert to "normal" display.
Option Three:
If neither of the previous options help, try the following procedure.
  1. Right-click an open area of the desktop and click "Properties" to open the "Display Properties" window.
  2. Click the "Settings" tab and then click the "Advanced" button to open the monitor settings window.
  3. Click the tab corresponding to your graphics card. You may need to click one or more buttons within the tab to reveal a rotation settings option. Exactly where rotation settings are located will depend on the brand of graphics card installed.
  4. Once you locate the rotation settings, choose the "0 degrees" or "normal" option to change the display to upright. The rotations settings may also give you the option of disabling rotation hot keys so that the problem does not happen again.
  5. Click "OK" to save changes and exit out of any open properties windows
Jan 30, 2011 | HP Computers & Internet
My computer monitor display changed from being horizontal to vertical how can I change it back?
If you have an Nvidia Graphics card then on the bottom right hand side of your task bar, next to the time, it's a green icon. A Nvidia logo is displayed. Left click on it and move your mouse over rotation settings, should be set to rotate 0 degrees.
Can also access through control panel, then Nvidia control panel, then on the left menu rotate display, set it to no rotation 0 degrees.
Please take the time to rate my expertise.
Thanks
Oct 31, 2010 | Computers & Internet
Vertical thin blue line in center of my Toshiba screen
The screen would have to be replaced in order to resolve the problem. Avg cost of screens are around $140. If under warranty contact manufacture.
Apr 20, 2010 | Computers & Internet
No VGA icon to rotate Horizontal position
Stephen,
Right click on your destop, in the middle you should see what types of VGA Card you had.( for example Nvidia Display or ATI Display) Next to right double click to open. You should see a list of informations, look for rotation and click on it. The rest you know what to do... Have a nice day!
Jan 29, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor is vertical display instead of horizontal display
Hi...there! Kazz,
Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
Oct 10, 2008 | ViewSonic VA902 19" LCD Monitor
Monitor display is vertical instead of horizontal
What Video card are you using?
WIN XP
Right click Desktop>>>Graphics Options or
Right Click Desktop>>>Properties>>Settings>>>Advance
and change the rotation to NORMAL
For Intel Video card go to GRAPHICS Properties
For ATI Video card go to CATALYST
For NVIDIA Video card go to PHYSx
Oct 09, 2008 | Dell Computers & Internet
Whats a quick solution
The problem may be related to bad capacitors on the PIP module. This is a commom fault as vertical sync runs through the PIP board and this is the symptom of the pip board having bad capacitors the TV rolls.
Mar 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
ViewSonic VA902 19" LCD Monitor Logo
240 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
