Question about Kenmore 92320 / 92321 / 92322 / 92324 Electric Kitchen Range
My kenmore kitchen range has a glass top w/4 burners; 2 oven racks w/ 1 extra in the bottom (3) total; black top,front and top control area w/lcd display. i found it off and when i tested the circuit breaker it came back on showing the blinking time but beeped several times and then displayed f1 and beeped continuously until i turned it off at the breaker box. whats going on and what can i do abou it please?
  • 360 Answers
First you will need to check for proper voltage at the plug (behind the range) ensure you have 120/240 volt available.
F1 generally indicates a control board fault/failure. If you have attempted to reset the unit by unplugging it for about a min. or more and plugging it back in and the F1 error code returns, you will most likely need to replace the EOC (electronic oven control) board. Parts for your unit are available through Sears or other aftermarket parts suppliers.
Please take the time to rate this solution
Posted on Jan 29, 2009
    Sergeant:
    Champion:
  • 318 Answers
It sounds like your little Computer has lost its settings, and needs to be reprogrammed, you need your manual which came with this Range to do it yourself, or you need to call in a service technician.
It wont be too expensive,because it can be re sett pretty fast.
I have a GLEF379DQA glass to stove and I want to know how to lift the top to replace the burner.
1) Unplug unit 2) Remove back plate covering controls on back of oven 3) Notice 2 brackets, 1 on each end holding 2 screws-remove the screws 4) On front remove 3 screws underneath front ledge directly above where oven door closes 5) lift top up about an inch, and pull forward towards front of oven 6) You can now lift it to service - beware wires are still connected - dont pull too far forward and up
Nov 29, 2010 | Frigidaire GLEF379D Electric Kitchen Range
The large two size burner is not working correctly. The large size will come on but the small inner burner will not
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Jun 24, 2010 | GE Profile JB968 Electric Kitchen Range
Kenmore free standing gas oven. Burners will
It sounds like the erc electronic range control has failed. Try this link it will walk you thru checking and replacing the erc http://appliancehelponline.com/ovenerc.html
Jul 16, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
GE Elec Range - front left burner will not turn on
Dec 26, 2008 | GE Profile JB968SHSS Electric Kitchen...
Kenmore Range
Try just unplugging the unit for about 5 minutes. That will reset the clock and hopefully fix the problem. If not you probably need to replace the clock.
Nov 15, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
Kenmore 92320 / 92321 / 92322 / 92324 Electric Kitchen Range Logo
150 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
