Question about LG KC910 Renoir Cell Phone
LG KC 910 Renoir how do I set up for GPS working
Do I need to download google maps first
  • 5 more comments
  • Anonymous Feb 27, 2009
    How do i get GPS to work I have google maps.
  • bmuri7 Mar 04, 2009
    I need to know how to get the GPS to work on the Renoir ASAP....I downloaded google maps onto it, but thats not really what I want or indeed working very well. Maybe its just me!
  • 1Wynner Mar 06, 2009
    I bought my LG 910 from Ebay as a pay as you go. Obviously the previous owner has deleted certain Applications. How do I get them back?
  • Anonymous Mar 12, 2009
    I had the same problem. When I spoke to 3 they informed me the LG Renoir, while GPS enabled doesn't ship with the APP/Maps. You need to call LG customer care!!! In Australia that's 1800 638 080. However when I called them I discovered that the APP is not true GPS. It's a text based map system that uses Google Maps. I have reported them to the Department Of Fair Trading for using misleading branding.
  • Anonymous Mar 31, 2009
    cant use the GPS.........
  • Anonymous Apr 01, 2009
    the problem is, that GPS doesn't work at all.
    you can try to test it in the service menu, dial 3845*#910#
    there you can find gpsmenu and get location. It will not work.
    However for some applications, and more widgets you can flash your firmware with that one:
    http://www.mygreatphone.com/forum/lg-ren...
  • luiz_loures May 02, 2009
    I have the same problem. The GPs doesn work!!!!
The Kc 910 does not have a GPS! It takes a bearing from phone towers, it requires several towers within range to get a bearing. Be careful you are not using the assisted GPS, as you may be charged for logging on or data downloads.
Posted on Jun 21, 2010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
The gps on my renoir works fine with orange maps , couldnt get it to work for a while though but seemed to sort itself out, does take a fairly long time to get the positioning but once it found the satellites it worked no problem at all gave me directions to my house... havent used it since but it did take about maybe 15 minutes to find the signal u have to be patient
Posted on May 21, 2009
Google Maps should be located in the "Games & Apps" section - I would like to have a look at other GPS solutions and will post if I find any useful ones...
Posted on Jan 30, 2009
Je inscrire moi dans gps
Posted on Aug 14, 2012
Hi! I Have a LG KC 910 black Renoir and the problem is, a choose a key but the phone selects other diferent and goes directly to make a phone call!
sensitivity of your mobile must be down its the problem with the old resistive touch phones.. try a service !
Jun 13, 2011 | LG KC910 Renoir Cell Phone
Can GPS be instaled in LG KC 910?
yes u can
You'll need to pre-install maps onto it first. Be aware that you should do this at a PC, then use the USB connection to copy them across to avoid costly data charges.
In terms of charges for GPS the Renoir has 2 settings - Stand alone GPS and AGPS (assisted GPS). Basically, stand alone works exactly like a Tom Tom - link is made directly to GPS satellites with no data charges but it takes time to link up and refresh details.
AGPS uses your network's towers to link directly with GPS satalites through your mobile network. It differs from network to network but you will incur data charges using it this way. I'd recommend a data bolt on if you plan on using AGPS as it can be pricey.
To switch between modes, go to Settings, Connectivity, GPS type and select the one you want to use.
In terms of map software, you're best off googling Java GPS applications - Way Finder is good and Google maps isn't too bad either, but it all comes down to personal preference.
Sep 13, 2010 | LG KC910 Renoir Cell Phone
How do i conect my lg renoir to my i speakers via a 3mm jack plug
usually renoir (kc 910) comes with a 3.5mm adaptor, it's a part of the 'headset' (handsfee). It's not clear if you are thinking of purchasing a 910 or already have one. It should come with one, otherwise contact lg, you will probably need to buy the whole headset though. hope this helps
Aug 13, 2009 | LG KC910 Renoir Cell Phone
LG KC910 is locked - How to unlock it?
call your company and they can provide you with a code
Jun 30, 2009 | LG KC910 Renoir Cell Phone
LG Renoir KC910 Manual and Updates
visit this website<www.lgmobile.com
May 28, 2009 | LG KC910 Renoir Cell Phone
How does gps operate
Hi. The GPRS(56kbs) is used to connect your device to internet to browse and retrieve emails. It's the 1st generation of "high speed" connection. Then there's a EDGE (238kbs) often called 2.5G network.Renoir should support 3G (speed 384kbs) with HSDPA(3.6MBs). Basically it's to same as GPRS just up/download speed is different. To have it in working order you'll need correct settings includes :APN,password etc. In most cases thei are preinstalled on your device.
Rate me if helped.Thanks.
Apr 14, 2009 | Cell Phones
Lg kc 910 security key
the default setting for security code on the renoir isnt listed in the manual but is 0000 (four zeroes) which youll need to change the code or access some of the features
Mar 09, 2009 | LG KC910 Renoir Cell Phone
LG KC910 Renoir Cell Phone Logo
9,839 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
