Question about Compaq Armada E500 Notebook
It dont work
When i turn it on my window dont load in the bottom right coner of the screen says f12 network servie boot but when i hit f12 nothing happens and some times on the left side of the sreen it says 1780-disk 0 failure what is my problem
  • 624 Answers
First off you need to get into your systems BIOS like sawhand suggested and see what the primary boot device is. Start your laptop and hit the F10 button after a couple of seconds. Once you find the boot priority make sure it start off with either the optical (CD) drive or the hard drive. If the CD is first make sure the hard drive follows after. Let us know what you find and we?ll pickup from there.
Posted on Jul 27, 2007
It sounds like the hard drive is faulty. Maybe someone dropped the laptop? I would suggest running whatever BIOS utilities it has, and/or booting up a recovery CD, like Hiren's boot cd. If I were you, I'd look into having a new hard drive put in it, reinstalling Windows.
If it says disk o failure then your primary drive is down. Get into your bios find out what key enables you to get into setup and then make sure your autodetect for drives is enabled. Sometimes, I have no idea why the settings will change.
I have an asus eeepc seashell series and i turned it on and it says reboot and select proper boot device and i dont know what that means or how to do it
Power laptop, when asus logo is seen, look down bottom right, press F12 or the number assigned for your model, use the arrows up down keys on the laptop keyboard, highlight hard drive and press enter, this will set the boot order for your hardware to start.
Jun 15, 2012 | ASUS Eee PC Seashell 1005HAMU17PI PC...
My dell notebook stoped working it shows only curser on the screen and there are some lines on the screen nothing wrong with the power supply
If it does boot to windows and only does not shows the icons..than you have to click right on the desktop and choose to show icons ..and will be ok ..If the screen you wrote about is just a start screen and it never started windows..than I think it is a windows fault and need to be reinstalled .Do that by entering the recovery partition and go with the total installation of the operation system ..
to do that choose the key indicated on screen and select the action ..
usually on start screen it is written to press F2 for the set-up and f12 for the boot menu and probably F11 for teh recovery ..if it is so ..just press f11 on start ..go to recovery ..choose complete recovery ..and will get it to the factory stage .
If the recovery do not work and you do have a disk for it ..insert the disk and boot from it ..try to boot to recovery with the disk on ..and see if ti works..if it dopes its ok ..if not ..restart . and press F12 to go to boot menu .and choose to boot from CD /DVD drive ..and hit enter .. this will force it to boot from disk and load the recovery .
same procedure with a boot-able disk with operation system, ..in case you do not have any recovery ..or just have recovery for drivers..and you will be forced to use a standard boot-able disk to load the operation system again
have a nice day ..and please rate my answer ..1
Dec 22, 2011 | Computers & Internet
Windows 7 laptop won't boot to OS , only has a black screen with a blinking cursor
Insert your system recovery disc to repair your startup.
1. Change your Bios to boot from disc:
When your computer powers on, hit F2 (on some computers, F8 on others). Use your arrow keys and move to the right to your BOOT option. Hit the down arrow until you select your CD/DVD drive. Look at the bottom of your screen, and it should say to change the option hit F7 or F8. Use the specified keys, and move your CD/DVD drive above your hard-drive. Save your settings.
2. Boot from your disc. Insert your system recovery disc and restart your computer. Let the recovery disc load. If the option comes up to hit any button to boot from CD/DVD, then hit any button. Once it loads, it should come to a spot where it wants your language. Select your language, then select the option "Startup Repair". Click on it, and let it repair the startup. If it automatically starts correcting your startup then great! If not, then select your operating system from the list and click the Repair Startup option. Restart your computer, and hopefully it will boot from your hard-drive correctly.
Hope this works.
P.S. If it continues to boot from your recovery disc, then using the same method in step 1, go to your bios, and move your CD/DVD drive below your hard-drive.
Mar 01, 2011 | Computers & Internet
My Dell monitor goes to sleep right after windows xp starts to load and it won't come on after that. my computer is still running but the monitor is a sleep. I have hit f8 and f12 with nothing happening....
Go into safe mode
Under settings, control panel, power options set "turn off monitor to never
reboot
I think this is not a sleep problem but the incorrect monitor settings were set. This will cause the screen to go black when the OS comes up. Boot in safe mode and change the display settings
to 640x480
OR
in safe mode, delete your monitor. When you reboot it will load a default monitor and you should be OK
Oct 13, 2010 | Dell XPS 410 PC Desktop
When I turned it on, it goes to the screen that has start windows
sounds like your boot record on hard drive is bad or hard drive turn on computer and hit like f10 or f12 it will tell you right after asus screen what key to hit for restore, if this doesn,t work hard drive is bad. hope this was helpful
Apr 15, 2010 | ASUS Eee PC 1000H Laptop
DESKTOP COMPAQ WONT BOOT UP
try hitting the F12 key when u turn on com. dont stop till it come up a screen or turn back off and try hitting all the keys the same like F8 works for me...
riversidehood@yahoo.com
May 06, 2009 | Computers & Internet
Toshiba satellite pro 600 won't boot up
If you get this error in a black screen before windows xp can boot up....
CLIENT MAC ADDR: xxxxxxx GUID: xxxxxxxxxx
PXE-E53: no boot filename recived
PXE-MOF: exiting intel PXE Rom
Your network card's settings in bios have somehow been changed. PXE means Pre-Execution Enviroment. In other words, it allows your network card to connect to a network server to pull operating system images off the network and other files without having an operating system installed.
The Fix,
Go into BIOS press F2 or F12 whatever your PC's screen at bootup says. In Bios, reset your bios settings to the default bios settings, or original settings. If nothing else fixed it. Windows Recovery cd will not fix it, because you cannot boot windows if this error is still occuring, Your network card will keep prompting DHCP to search for a network. Its a bios function not a windows function. Reset your bios settings to the default.
Dec 16, 2008 | Toshiba Satellite Pro 6000 Notebook
Acer Aspire 5315
Shut the notebook completely down. Now turn it back on, and as soon as the Acer screen comes up, hit the “F2′ key to enter the BIOS. Navigate to the second page of the BIOS (titled “Main”) by pressing the right arrow key.
You may wish to turn of “Network Boot” by selecting it with your arrow keys and hitting enter, then changing it to disabled. This is often used in a cluster-lab environment, and for normal users only slows down your boot process.
You must now turn on the F12 Boot Menu by selecting it with your arrow keys, hitting Enter, and changing it to “Enabled”
Now switch to the “Exit” page, and hit Enter to “Exit Saving Changes”. The BIOS will ask you to confirm, tell it “Yes”.
Now the notebook will reboot, and you must hit F12 to boot from your CD.
On the “Boot Manager” screen, chose the second option which should be an ATAPI drive, such as a DVD-RW or CD-RW, highlight it with your arrow keys and press Enter.thank u,,,,,,,,,,,,,,,,,,,,,
Sep 11, 2008 | Computers & Internet
Computer Still Down (Bad PBR)
the reason why you didnt receive any back up discs because your computer has a recovery partition. To access it,restart your pc,tap ctrl+f11, select "restore".It will format your hard drive and will load factory imag that has your windows and dell apps..if that didnt work,you can request back up disc here, support.dell.com/xpscd
Jun 26, 2008 | Dell Dimension 8250 PC Desktop
Acer Aspire T180-UB72 does not boot
I have the same model and had the same problem. Fortunately there is a simple fix - unplug all your USB devices (mouses, printers etc). It should now boot!
Assuming that fixed it, it was trying to boot from a USB drive for some unknown reason. I think it was due to the latest windows XP update. Wierd. Hit F12 next time you reboot and make sure it is booting from hard disk first.
Jan 09, 2008 | Acer Aspire™ T180 PC Desktop
Compaq Armada E500 Notebook Logo
61 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
