Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Windows xp crashes frequently after inserting new RAM.
MotherBoard-D101GGC, new RAM installed is transcend 1gb 400Mhz. initially was kept alongwith 256Mb dynet ram which was initially on the PC now two rams of same frequency create a problem or whether the new Ram itself is a problem dont understand.
  • Peter Steiert
    Peter Steiert May 11, 2010
    The new RAM, is it SDRAM, DDR, DDR2, or DDR3? The old ram, is it SDRAM, DDR, DDR2, or DDR3? Most likely you have an incompatibility issue or dual-channel issue. If so, one of the two sticks will have to go.
    As a test, try removing the old RAM and see if the computer will run fine with the one stick. If so, we know it was an incompatibility issue and not an issue with your new stick of RAM.
    Problem Solver:
  • 17 Answers
Try to use one ram at a time if the 1gb ram does not gve any error thn the 256 mb ram is the culprit and if the opposite happens than 1 gb is culprit yur ram slot also may ve got damaged somehow if the ram is culprit and ti is under warranty get it replced with the same memory clock one
Posted on Mar 07, 2009
Emachines t3516a memory upgrade
The eMachines T3516 uses an Intel D101GGC motherboard,
http://www.ascendtech.us/intel-d101ggc-lga775-800fsb-motherboard_i_mb4intd101ggc.aspx
Two Ram Memory slots.
Maximum Amount for EACH ram memory slot is 1GB.
Maximum TOTAL Amount for the motherboard is 2GB.
Ram Memory used is DDR Sdram at 333MegaHertz, or 400MHz.
That is PC-2700 and PC-3200 respectively.
Uses Non-ECC, low density, Unbuffered, CAS Latency of 2.5, and 2.5 Volt.
Regards,
joecoolvette
Oct 01, 2012 | E-Machines T5082 PC Desktop
I have a Intel D102GGC2 motherboard with Intel Pentium D 805 processor having core speed of 2.667 GHz. I was using a 1GB of Dynet RAM (DDR2-667 MHz) earlier. Recently, I got a Transcend 2GB DDR2-667 MHz...
specs on that board from Intel is 2 gig max. when you install the 2 gig alone does it show you 2 gig in windows or only 1?......with a 2 gig max I would think that would max each slot at 1 gig...
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Jul 04, 2011 | Intel D102GGC2 Motherboard
Hello! I have a D101GGC motherboard and I want to upgrade my memory, I mean now i have two RAMs at 250MB and i bought one DDR 1GB PC3200 400MHZ CL3 KINGMAX MPXD4. The problem is that the PC doesn't...
Please check the speed in MHZ of old RAM and New 1GB RAM.
Some times if speed wont match this problem occur.
Remove old RAMs and add only 1GB RAM and start the system.
I hope it will help you.
Thanks for using FixYa.
May 31, 2011 | Intel D101GGC Motherboard
Is it possible to add 1GB DDR1 RAM 333 MHZ to INTEl D101 GGC
u can use the 1gb ddr1 ram,if the sound is coming then may there is two problem
1.may be the ram is damage
2.your motherboard is not supporting 333mhz bus support
try to find 400mhz ram instead of 333mhz
Feb 27, 2010 | Intel D101GGC Motherboard
Motherboard ESC k8m800-m2 (v1.0A) 2x1Gb RAM
You have to verify the in the motherboard book if the brand name or vendor of your merory stick is compatible with your computer's motherboard, there all written : Kingston, Samsung, micron etc... Check all details if meets your motherboard's model requirements and make the change if necessary.
If all details are correct, check in your motherboard's manual if there is a special configuration to respect (in withc bank you should place your memory stick and witch order etc)
Sep 02, 2009 | Computers & Internet
Vista compatiable
intel doesnt list any vista drivers for that motherboard on there site so you might run into problems with the intergraded devices such as the ethernet,audio,chipset, & any intergraded video
You might be able to use the xp drivers but if theres problems it wouldnt be supported by intel
Nov 26, 2008 | Intel D101GGC Motherboard
P4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
Memory Upgrade
ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
thanks.
Sep 18, 2008 | Intel D101GGC Motherboard
System crashes frequently after got the board repaired
hi dude,
          better format d old windows and install new windows...my frend had a similar shut down problem, by formatting and installing new windows, solved it...dis can solve ur problem
                                                good luck,
                                                trendsetter
Jul 03, 2008 | Intel D845GVSR Motherboard
Intel 845 GVSR drivers for windows vista
change to Windows XP,
windows vista will not support with *********** board
it will support more then 865 chipset
May 17, 2008 | Intel 845GE Motherboard
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
264 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
