Question about Dell Inspiron 1501 Notebook
DELL XPS 1210 i purchased a replacement battery not recognised
I purchased my laptop in sept 2006 and have been using the same battery since. Five days ago the battery started to only hold a charge for1 hr and Three days ago it stopped holding a charge.
I purchased a replacement battery, but my computer is not showing it installed when I plugged it in to charge.
  • 3,940 Answers
If the battery is not detected in the BIOS (F2 at boot) and doesn't show as charging, then return the battery and get a replacement.
If neither the original battery or the new replacement battery are not detected in the bios a problem with the motherboard may exist. If still under warranty, contact Dell Support for a repair, if not, then you may be investing in a new motherboard
Posted on Jan 29, 2009
My dell xps 1210 laptop wont show image on viewsonic pj588d projector. it works on another laptop but not on xps 1210
Try F1 or Fn and F1 or connect up the projector, power up the projector select VGA input (or whichever input is connected to the laptop) power on the laptop.
Dec 27, 2014 | Dell XPS Computers & Internet
How do I change the battery?
on the bottom of the computer, use this pic to remove and replace.3_8_2013_3_37_59_am.jpg
Mar 08, 2013 | Dell XPS M1210 Notebook
Hi I have Dell XPS M1210 laptop. When I turn on the screen nblinks for a second and then goes real dark. at first it look like its gone blank but if you look closly, the screen is on but very dark. I...
farooq473, replace the Inverter.
1) An LCD screen cannot produce enough light by itself. A Backlight is used to help provide the needed light.
2) An Inverter is used to provide power for the LCD screen, and the Backlight.
An Inverter boosts power up for the LCD screen, and lowers it for the Backlight.
90 percent of the time a bad Inverter is the problem.
A Backlight usually goes out all at once, Inverters slowly 'die'.
Dell Support > XPS 1210 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/xpsM1210/en/SM/index.htm
In the list click on > Display
Now click on Display Panel.
Dell doesn't show, and describe how to replace the Inverter.
When you click on Display Panel, you are looking at an exploded photo showing the Display Panel removed.
Scroll down to the next small illustration.
Has 1, 2, 3, 4, and 5 pointing to the Display Panel.
5 shows you a pull tab to release a flat cable from the Inverter. The Inverter is the small circuit board to the left of the pull tab.
This is not advertising for this website. Just an example to show you what the Inverter circuit board looks like.
(Screen Inverter)
http://www.battery-adapter.com/product_info.php/products_id/3450
This is Not a Dell XPS 1210 Notebook PC. It is a guide for replacing an Inverter in a Dell Inspiron 1525 Notebook PC, but I wanted you to have photos, and instructions for the basic procedure.
After you have repaired over 100 laptops, you'll realize that they all have the same basic procedures.
Just different parts.
http://www.insidemylaptop.com/replace-lcd-screen-inverter-dell-inspiron-1525-laptop/
3) Be SURE ALL power is removed from the laptop before you start.
Remove the AC adapter (Charger) and Battery.
4) You should follow Anti-Static Precautions implicitly. It would be best if you bought, and wore an ESD wrist strap. (Electro Static Discharge) Connect the alligator clip to a good ground source.
(For example, I connect to the metal frame of an empty desktop computer case)
The cost averages from $3 to $12.
A $3 ESD wrist strap will do just fine.
This is an example of an ESD wrist strap,
http://www.amazon.com/Cables-Unlimited-ACC-1400-Static-Grounding/dp/B000EDMPQK
5) Use a multi-compartment container for the various screws you will remove.
Label each container for the area the screws came out of.
You DO NOT want to mix them up!
You can use a clean egg carton in a pinch. Label each egg holder.
Have questions post in a Comment.
Regards joecoolvette
Nov 10, 2010 | Dell XPS M1210 Notebook
Hi I just purchased a new screen back cover for my dell xps 1210 to replace one that was broken. It seemed simple but when I attempted to replace it i realized the wires on the new back cover are not long...
replace with the same number couse some came in lcd and the news come in led but some come left side and others rigth side te conector this is the problem check the number of sceen ans then change it for the remplace or original
Jul 25, 2010 | Dell XPS M1210 Notebook
Base system device in dell xps1210
Base system device is normally the chipset utility
Sep 02, 2009 | Dell XPS M1210 Notebook
DELL XPS 1210 i purchased a replacement battery and the computer does not recognise it
Is the battery you purchased an actual DELL OEM battery or an aftermarket "other brand" battery?
If it is not an actual DELL brand battery you might want to return it and possible buy a "DELL" battery on ebay or something. since I have seen this type of issue with customers before in my everyday work as a certified DELL field technician.
Also if the old battery is less than one year old then you might want to check your warranty status since you might be able to get a replacement battery from DELL but they are rather strict on batteries and will not replace batteries that are over one year old.
Also you might want to press F2 on startup to access the bios and then under "Battery info" page it should say at the bottom of the page the adapter type and if it says "unknown adapter" then that means your ac adapter is not putting out the required amount of wattage and needs to be replaced.
Hope this info helps
Jan 29, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
330 people viewed this question
Alun Cox
