Question about Nintendo DS Lite Console
Touch screen wont respond
Changed the shell on my kids ds lite put it back together powered it back up both screens came on alright but the touchscreen wont respond touching it with the ds pen
  • 4 Answers
Double check that both cable/ribbons are connected properly to the motherboard, the small thin ribbon which curls over the top of the motherboard is the one which powers and reads the touch screen so double check this!!
if this is all in fine then im sorry to say your touch screen is broken and will need replacing!
Posted on Jan 29, 2009
I am replacing the shell on my ds lite and when after puting it back together the touch screen lights and works the the touch pad doesnt respond
It sounds like when you replaced the shell, you may have not reconnected the touch screen's membrane sensor. I'd open the system back up and make sure there aren't any loose or disconnected wires.
Mar 15, 2011 | Nintendo DS Lite Console
Changed bottom screen tested before putting back
Happens sometimes it is one of two things:
1) When you put the DS back together is the ribbon from the top screen wound to tightly as this can cause the ribbon to pull out slightly from the socket on the motherbaord causing the blackout.
2) I have seen this happen only once before! The plsatic of the shell had a small chip where the battery connectors from the motherboard stick through into the battery compartment. THis tiny piece of plastic was stopping the final connection between battery and DS. Drove me mad, did all the usuals checked battery connections etc. Worht a look.
Nov 19, 2009 | Nintendo DS Lite Console
Most of my ds lite touch screen is not responding
try getting to the calibration menu with the buttons and calibrate if u can if not send it in to nintendo for repairs
Sep 21, 2009 | Nintendo DS Lite Console
Replaced the shell and now the touch screen isn't responding!
I have actually done this same thing attempting to repair my old gray DS. Had to replace the screen to screen cable and touch pad, but that is another matter.
When the DS screen to screen cables are out of place, the DS will act exactly like this. The screens will flash once and the DS won't even attempt a charge. This is a safety feature of sorts in the DS design to prevent a possible short.
I'm assuming you had to remove the screen to screen communication cable when replacing the shells so you most likely didn't put the cable in all the way into the correct ports.
Sometimes even if they are off just a bit the machien just won't use it and act like its outright dead.
Best thing to do is to go back and reinsert the cables again.
There should be a small line on the board just under where the cable should be. You need to try and aling the cable with this line as best as you can.
Push the cable as far back into the port as you can without forcing it in. You should never need to use much force at all.
Press the plastic tab down and lock the cable in place with the port and do the same with the second one.
Once thats done, plug it in and turn it on.
It should normally go into the settings as these are usually erased when the battery is removed.
If it continues the odd dead like behavior. Simply attempt the precedure over again until you ahve it right.
Commonly you may see odd colorisation and the like if the cable is in enough but not in just right.
Take your time with it and be paient. Its not always easy but isn't too hard once you figure it out on your own.
The same info should help with other cable problems like this aswell.
Good luck with the rerpairs.
May 09, 2009 | Nintendo DS Lite Console
Broken in half got new shell don't know how to put together
much of it is pretty straight forward, the only hard part is putting the ribbon cable thru the hinge for the top screen, without ripping it, best thing to say is put the ribbon cable in first, then the wifi and mic cables (black and white), rest is pretty straightforward.
Apr 17, 2009 | Nintendo DS Lite Console
Nintendo DS lite; changed touch screen and it won't start
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
Mar 14, 2009 | Nintendo DS Lite
Ds lite
sorry to say that your top screen needs completely replacing if it is doing as described!!
the bottom screen and the touch screen are seperate, jus mounted on top of each other, so if the picture works on the bottom then the bottom screen is fine just the touch screen is broken. again i think if the cables/ribbons are in correctly and it isn't responding then it will need replacing!!
Jan 29, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Flickering screen
hey i think i got a solution, read the link i gave below credits to votahuan, its for adjusting screen flickers in both top and lower screen of ndsl, however i need you to do me a favor in return, hope you do not mind posting up the pics for me at once you found the two hidden screw at ndsl, im just having hard time finding it in fat nds, so i need a rough i dea of where it mite be located. Heere's the link anyways :-
Jun 15, 2008 | Nintendo DS Lite Console
Onceturned on, the green light goes on, the touch screen flashes white, then it all turns off.
You might only have a loosen screen ribbon cable.
If not careful while taking out the top screen ribbon you can damage it causing blank screens and finally the DS wont work.
The solution to a broken top screen ribbon is to replace the whole screen in DS lite or buy the ribbon cable in the DS fat and replace.
If the broken top screen ribbon is caused by broken hinge then you should replace the shell also to avoid other broken screen.
May 22, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
185 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
