Question about Pitney Bowes 9920 Plain Paper Fax
PITNEY BOWSE 9820
NEED TO CLEAR ERROR CODE 041
    Genius:
  • 2,120 Answers
Out of toner.
Posted on Feb 07, 2009
Xerox 7435 machin error 041340 plz advice for solutions
I found a reference to this for you in a Xerox service forum from one of the forum admins, who said:".....try reseating the Transfer Unit and see if that will clear the code. If not please consider contacting your support centre for further assistance."
You can find the message in her forum complete with links on how to do the above at the link below. Good luck! --Mark
http://forum.support.xerox.com/t5/Hardware/6280-gives-error-041-340-MCU-VRAM-error/td-p/22376
6280 gives error 041 340 MCU VRAM error
Oct 25, 2016 | Xerox Workcentre 7435 Color Multifunction...
Getting error code 956 on a monarch 9820 label printer. Any idea what this error code means?
Are you sure it's not a 756 error? 756 is a supply error, basically saying that you ave no supplies loaded. A 956 is an unspecific generic error code, saying you have a mother board failure.
The display on the 9820 is difficult to read. I'd say you have a 756 error.
Double check your dip switch settings and make sure they match the type of supplies you have loaded.
Sep 15, 2011 | Monarch Paxar? 9855 Label Printer
Pitney bowes 9820 fax machine is popping up error 50 check printer what might be the problem
Error 50 is a service error and you will need to contact your local computer repair or go to their site and talk to customer service to get someone to fix this for you.
Hope this helped
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowse every time show this messages
We need your model number.
Also check your toner cartridge carefully. A toner that is not fully locked in can cause this error.
Oct 30, 2009 | Pitney Bowes Office Equipment & Supplies
Error code 050 what is this? PITNY BOWES 9820
This is a defective laser code. The lubrication in the laser has hardened and the laser cannot turn as fast as it needs to.
Oce is the repair people for PB faxes now. 1 800 243 5556
Oct 05, 2009 | Pitney Bowes 9920 Plain Paper Fax
My Pitney Bowes 9820 fax machine says check printer service due. When I hit the help key it asks for a password which I entered 9820, but no other key after that seems to work
Service due and check printer may be two different problems
check printer may be a fuser or laser problem
service due may be a counter for a ozone filter that needs to be changed to make the EPA ha[[y. If you wait too long to reset the filter counter, it can go to a check printer and cease printing
To reset the counter, press function 99, yes,access code is ***1.yes
press 146, yes, then press 1 to reset, press yes. press stop to exit
Sep 14, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
9720 Pitney Bowes Fax - access code has mysteriously been placed
Function 9, access code is 9720, press yes, press no until you get to set access code? press yes, delete code, press yes, press stop. I don't think this manual in online any more, but you can go to www.oceusa.com, go to drivers and support, and look for 9820 or 9800 series. The programming instructions are the same as this model
Jan 06, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney Bowes 9920 Plain Paper Fax Logo
270 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Victorman
Victorman
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
