Question about SanDisk Sansa e250 MP3 Player
Picture Issues I just recently added photos to my sansa e250 and when I went to view them, they were no where to be found and it ate up my valuable memory please help me :)
  • Anthony Garcia Jul 27, 2007
    yeah i knew i could not find em in regular view, and even after turning on show hidden files i still could not find them :(
  • 64 Answers
Yeah... Go to "My Computer," and select the player by right clicking and then hitting explore. You then need to hunt around in those folders till you find your pics and then just highlight them and hit delete. If you can't find them, try starting over, then after you "explore," go to tools-->folder options-->view--> then turn on "view hidden folders" Hope this helps!
Posted on Jul 27, 2007
  • Leo Bas
    Leo Bas Jul 30, 2007
    There must be something wrong, that isn't plausible. Simply go to Sansa's website and look for a "firmware refresh." This will restore to factory settings and reformat the player.
    Hope this helps! Please change to solved or Almost there, I will continue trying to assist you! Thanks!
SOURCE:
I have many types video and picture fomat but i face some technical problem when i run this file on my sansa e250 there are some file format problem.i don't know which type of files are run in sansa e250...
Use the supplied Sansa Media Converter program to convert and transfer your photos and videos. If you don't have the SMC, you can download the Windows version from
http://www.megaupload.com/?d=3IPZO6Q0
Nov 17, 2010 | SanDisk Sansa e250 MP3 Player
I added some photos to my Sansa Fuze. When I try
wrong picture format. convert the picture format with sansa media converter
Jan 25, 2010 | SanDisk Sansa Fuze MP3 Player
I uploaded pictures, songs and videos into 1GB micro SD card. But in Sansa e250 am able to see only songs in it. am unable to view pictures or vidoes stored in SD card. please help me.
The Sansa will only show photos and play videos from its internal memory, not the microSD card. You can put music on the card, but not photos or videos.
Dec 15, 2008 | SanDisk Sansa e250 MP3 Player
Sansa E250 Media Player
Try to reformat the card. Go to My Computer then right click the drive corresponding to your sd card and select format. Put some music back on, and try again. When your Sansa boots you should get a message stating it's refreshing the database. Good luck.
Jan 06, 2008 | SanDisk Sansa e250 MP3 Player
Adding photos
you can add via computer by getting more pictures into ur digital cam or else
Dec 15, 2007 | SanDisk Sansa e250 MP3 Player
Adding photos
Sansa media converter
Nov 07, 2007 | SanDisk Sansa e250 MP3 Player
Sansa® e250 MP3 Player 2GB
Mikey25
Once you connect your Sansa® e250, a pop-up should appear on your computer that asks what you want to do with the device. Choose View with Microsoft explorer, it should be the second to last option. From there you should see some folders and some other stuff. choose the PHOTO folder and delete the pictures inside. You should be able to do the opposite to add them. You can simply drag-and-drop the photos into this folder from another as long as they are the same format.
Aug 22, 2007 | SanDisk Sansa e250 MP3 Player
I accidentaly sinc music to my sansa e250 from windows media player and it wont come off!!!
Mp3 files can be loaded using either WMP or Windows file manager (Explorer) but a different USB setting is required by each. WMP uses the MTP setting while Explorer uses MSC. If you used the wrong setting this may have caused your problem. Also for some reason MP3 files loaded using a file manager will not appear when trying to view them using WMP. To solve the issue I used the MSC setting to view all of my MP3's using file manager. I then deleted the ones I had recently added, changed the setting back to MTP and reloaded them using WMP. Worked like a charm. Hope that helps.
Aug 13, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
