Question about Gateway MT6730 Notebook PC
Installin Memory card into MT6730 laptop
Hello I bought a memory card compatable with 533MHz and I believe it's compatible with my computer! Now how do I install it?
    Novelist:
  • 210 Answers
1) Find the panel for the memory, unscrew and remove it.
2) Insert memory in the same fashion the existing memory is inserted.
3) Charge customer modest fee for knowing how to do it.
Posted on Jan 29, 2009
I have problems with card reader is not compatible with w in 8.1 pro
Hello
Probably you need to download Driver for it to use.
Hope this Helped
Apr 10, 2014 | Sony VAIO Computers & Internet
Hi , I have recently removed the windows vista and installed the Windows 7 Os in my Sony Vaio laptop.But now the laptop can not read the memory stick of my camera. could you please...
Hello. Most probably you need the driver for your card reader. If you give me the model number of your computer I can point you to the download link. Or also you can try fetching the driver from windows update within Windows 7.
Regards
Rob.
Mar 16, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
I tried to upgrade the memory of my 450 sx4 pc from 512mb to 1 GB
You may have installed a memory card or stick (unit) that is not compatible with your computer. Make sure the unit is compatible, as you cannot add just any brand of memory upgrade units to any computer. They have to be compatible.
I suggest visiting the store of where it was purchased or a computer store, or possibly the manufacturer of the computer to find out what memory units are compatible.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 22, 2010 | Gateway 450SX4 Notebook
Computer won't read my memory card
Hello. Regarding your problem first you have to consider the compatibility of your memory card in your computer cause not all memory card supported by computer. Other memory card need to install their device driver in order to recognize by the system that you are currently using. Therefore my recommendation, try to check first if the your memory card reader evice is recognize by the system/computer then check also the memory card itself maybe their something wrong with your memory card and if you find out that the memory card of your's have the problem then return it to the supplier.
Jun 15, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
Make different frequency memory modules working together
if the memory not the same bus speed. it now compatible each other. if you want to put together one of two not show or not work even change in bios but actualy you can't change in bios setting...
Jun 11, 2009 | Toshiba Sattelite A105-S2071 Notebook
Having a problen installing 1gb ram. unit is 1gb ddr2 dimm 533mhz. computer turns on, shows that it has updated the memory, but does not boot
if the computer states that the memory has been recognised. but fails to boot. it may not be compatable memory for your CPU/Processor. Or system bus. check your previous memory stick, to ensure it,s the same running speed 533mhz. Failing this if your computer does not support this.
check the manufacturers website, to see further details:- Maximum supported memory/Speed et,c.
Systems bios date, and whether an update is available. your only other alternative is to install 2 x 512mb sticks of Ram.
Mike @ compurepair.
Jun 11, 2009 | HP Compaq dc7600 Small Form Factor PC...
Changing memory cards
Easiest way to check would be to physically look. There should be labels on the memory to verify the type. It doesnt have to be the same brand or size just the same type and frequency. Example DDR2 4200 and DDR2 533MHZ are the same.
Jan 10, 2009 | Toshiba Satellite A75-S2112 Notebook
Error message after installing memory ram upgrade.....
The memory appears to be the right kind.
Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
Dec 20, 2008 | Dell Inspiron E1505 Notebook
HI!
the speed readings on your memory are the maximum speed that that memory can preform at. When you have different speed memory put in your computer it will run at the speed of the memory which is the slowest. i.e. you might have a pc800 but that baby's only running at 400 mhz or 533mhz.
Dec 03, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
Problem installing ram
You have the wrong memory chip. The beep code you hear indicates that there is no memory or incompatible memory. The memory you need is PC4200, Which is a 533mhz chip. Memory has a frequency rating that is matched to the processor and motherboard. Not just any DDR 200 pin memory that fits will work, the frequency has to match or it won't work. The new chip should be labeled, make sure it reads PC4200 or 533mhz, if it reads anything else it's the wrong chip. If it is the right frequency chip, then you may have a bad memory slot, the chip is bad, or mislabeled. Here's a link to a memory configurator that gives the memory specs for your machine.
http://patriotmem.com/configurator/modelp.jsp
Jul 31, 2008 | IBM ThinkPad R52 Notebook
Gateway MT6730 Notebook PC Logo
114 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
