Question about Garmin Nuvi 660 GPS Receiver
No satellite signal from garmin nuvi 350 i have the same problem that my garmin nuvi 660 lost satellite signal and i tried to download new software and master reset ..but no result..can anyone help me ..my e mail is fogsky66@yahoo.com
  • Anonymous Mar 04, 2009
    I also had the "Lost Satellite Signal" with my
    Flip Up Antenna Nuvi 350 after 18 Months.
    Garmin Supports only response: "Out of warranty, send $175 to repair".
    For $175 I could buy a brand new Wide Screen unit.
    Poor antenna design, poor customer support, buy Garmin at your
    own risk.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Your flip-up antenna/receiver assembly needs to be replaced. I can help you with that.
    - Jim
    SHARCNET-USA
5 Suggested Answers
SOURCE: Garmin NUVI 660 - can not locate satellite
The nuiv 660 is the worse product Ihave ever purchased. For those whoe are thinking of buying a GPS research this product. It is the most unstable device I know. Considering I purchased it new and only less then 1 month down the track it starts crashing and doing completely what its not suppose to do it is not a good GPS to have. It is unreliable and you cant trust a system which freezes frequently and leave you helpless.
Posted on Nov 17, 2007
  • 504 Answers
SOURCE: garmin nuvi 660 forget my pin
The only options you have when it comes to a locked unit is to enter the correct PIN, go to the location where the PIN was set, or send the unit back to Garmin. There is no way to unlock a PIN locked unit without the correct PIN or location.
Posted on Feb 26, 2008
SOURCE: Dont Aquire Satellites
Ditto.. even after updating FW...
Posted on Sep 29, 2008
SOURCE: No satellite signal from garmin
i had the same problem with my gps its the 660 i drop it from a 2 story house when i was working yhea i know im not suposed to take my gps up there oh well i did LOL well i was so upset at my self cause believe it or not where i droped it there was water where it felt so i was so upset i got home left it siting there for 2 days with out messing with it cause i was looking for the yellow pinkslip to get help from garmin couldnt find it any where so i decided to mess with it so i did and just for my luck i got it to work again it picks up the satelitle signal alot quicker now and all i need it was a flat xcrew driver and a Credit card what i did it stuck the screw driver on the litle crack thats close to the power button ok when that crack open up just enough room to get the credit card there i slided the credit card to open that one side of the nuvi and waaala i had the nuvi picking up the signal again that worked for me hope it will work for other people
Posted on Jan 12, 2009
SQUIRESXX
  • 486 Answers
SOURCE: Garmin Nuvi 1300 couldn't reach satellite!
THERE ARE A NUMBER OF SOFTWARE UPDATES IN THE LAST FEW MONTHS CAUSING PROBLEMS GO TO WWW.GARMIN.COM/SUPPORT
DOWN LOAD NEW SOFTWARE UPDATES
Posted on Dec 12, 2009
I don't have Satellite signal! I tried to acquiere satellite signal with my Garmin Nuvi 1350! The screen always says locating satellites but nothin happens! The satellite bars are not green!What can I do...
Try fully charging the unit and leaving it stationary for about 20-30 minutes if you still dont lock satellites try giving the unit a firmware updates using Garmins WebUpdater software here is a link.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Hope this helps!
Feb 24, 2011 | Garmin nuvi 350 GPS Receiver
Will not acquire satellite signal and continously updates firmare
I can help you fix your Garmin Nuvi 200W. I am going to recommend a HARD RESET for you, to try and break the firmware update cycle you said you are locked into. Once you have successfully completed the WebUpdate, satellite acquisition will be vastly improved with the new system software.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites (if your pc will still recognize it or you have a memory chip you can pop into a card reader).
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Apr 10, 2010 | Garmin nuvi 200W GPS Receiver
There is no signal in the sat
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
  1. Back up your Favorites.
I hope that helps.
___________________
Feb 22, 2010 | Garmin nuvi 200W GPS Receiver
Dec 12, 2009 | Garmin nuvi 1300 Car GPS Receiver
Lost satilite reseption
I hope that helps.
___________________
Oct 12, 2009 | Garmin nuvi 200W GPS Receiver
Voice activation capabilities locked and none functioning after driving for 2 hours or so. Satellite reception getting lost even on a sunny day
I can help you reset and fix your Garmin Nuvi 265W.
Erratic behavior and improved satellite reception has been addressed in new system software / firmware update.
There are three steps to take to get your Nuvi 265W running like new:
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Sep 22, 2009 | Garmin Nuvi 265W GPS Receiver
My 265 wt was working fine until 2 days ago
I can help you reset and fix your Garmin Nuvi 265WT.
Erratic behavior is an indication that the firmware / system software inside your GPS has been corrupted.
Satellite reception is one of the issues addressed in Garmin Nuvi 265WT firmware updates.
There are three steps to take to get your Nuvi 265WT running like new:
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
Nuvi 265WT Manuals here.
Aug 08, 2009 | Garmin nuvi 350 GPS Receiver
Loosing satellite signal
Acquisition of satellites has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I hope that helps.
___________________
Aug 08, 2009 | Garmin nuvi 200W GPS Receiver
My garmin nuvi has trouble locating satellites and losing signals. What happened? It used to be much more reliable.
I hope that helps.
___________________
Jul 18, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
Try performing a reset of the unit. Hold down the bottom right of the touchscreen and turn the unit on. It will ask you whether you want to reset allk data. Choose yes and try again. This should solve your problem. Hope this helps.
Feb 20, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
561 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
