Question about Samsung TSK2792F 27" TV
Black Message Window
I am getting a black message window that reads "this is a string to test Text mode startup message function". What can I do to fix this? I was able to just press any button on the remote and it would go away, now it only goes away for 30 to 45 seconds.
Go into menu and change from text mode to closed caption and turn off display also.
Posted on Jan 15, 2011
    Genius:
  • 1,074 Answers
Have a tech take out the eeprom and change it for a new one.this will solve your problem.good luck.
Posted on Aug 04, 2007
I'm want to remove text mode startup message function?
You have to go into the bios and change it in there.
Feb 19, 2013 | Televison & Video
I'd say that your processing board is on a downhill slide, with memory telling you it's almost over the edge.
Mar 16, 2008 | Hitachi 50DX01B 50" Rear Projection...
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
Tip
Creating a Logon Banner
If you want to create a Logon Banner: A message box to appear below your logon on.
1.Open RegEdit
2.Go To
For Windows 9x and ME -
HKEY_LOCAL_MACHINE\SOFTWARE\ Microsoft\ Windows\ CurrentVersion\ Winlogon
For Windows 2000 XP 2003 Vista -
3.Create a new String value"LegalNoticeCaption "
4. Enter the Title of the window. What is displayed in the Title Bar.
5. Create a new string value "LegalNoticeText"
6. Enter the text for your message box that will appear even before the Logon window.
on Feb 13, 2010 | Computers & Internet
Brother MC420CN- Black ink cartidge 'near empty' message persists
At 1 of the end sides of the cartage you will see a little window, a beam of light hits that window to determine if you need Ink..Place a small piece of Electric tape over that window and.wallah print,fax and copy away. Brother is a ripoff-A cheap printer that auto-cleans(wastes ink) and locks the whole system claiming your out of Ink or low>>>But this is sure to work! ;)
Nov 01, 2009 | Brother MFC 420CN All-In-One InkJet...
Tv screen goes black and says string to test text mode?
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 02, 2009 | Hitachi 60EX01B 60" Rear Projection...
When sending e-mails from yahoo, no text, dup e-mails
Follow this steps to solve the problem:
1. When you type in your message or text in the compose window, can you see the message you are typing?
If you cant see the message then check your font colour and change it to black.
Secondly send a message to your self to test if the text is readable in your inbox
if the the message you sent to yourself is readable then the problem is not from your end.
Contact yahoo support team with this link to reset or reconfigure your email account to permanently solve your issue:
Link 1: http://answers.yahoo.com/question/index?qid=20070920062652AAZG4KC
or
Link 2 (preferable): http://answers.yahoo.com/question/index?qid=20090512032954AAaW8O4
May 21, 2009 | Yahoo Computers & Internet
When i try an open system restore the window appears blank, an my laptop doesnt no what the internet is when i try an open internet explorer it asks me what program to use, all this started after i ran i...
You might want to print this out:
1) Turn off your laptop.
2) Press the "on" button on your laptop, and *immediately* start tapping on the F8 key on your keyboard. This should bring up a black screen with white text on it.
NOTE: You may get a message saying "keyboard error, press F1 to continue." If this happens, press F1 and then keep tapping on the F8 key.
NOTE: If the Windows screen comes up, turn off the computer and try again until you get to a black screen with different startup choices on it.
3) Once you have reached the startup choices screen, use the arrow keys on your keyboard to highlight "safe mode." Press the Enter key. If you are asked to choose your operating system, just press Enter again.
This will start a lot of text scrolling on your screen. Just be patient. When it stops, you will see a login screen. Log in under your name (sometimes this is "owner").
4) You will now be logged in to you computer in Safe Mode. A message will pop up asking if you want to use Safe Mode or System Restore. Click on System Restore.
5) You should now have the option to undo your last System Restore. Choose this option and follow the instructions on your screen to get back to where you were before you tried to restore your laptop.
If you need further help after that, please reply with the name and model number of your laptop. For example, "Dell Inspiron 530," or "Compaq Presario 3000." Also let me know what version of Windows you are using, for example "XP" or "Vista."
Jan 08, 2009 | Computers & Internet
String test
Possibly the closed caption feature on this set has been turned on. There is a button on the remote control that says Caption. Press it until you turn the caption off. This will not be on a universal remote, only the original remote. You can also turn this off through the caption section on your on-screen menu.
Jan 22, 2007 | Samsung PCJ522R 52" Rear Projection...
Samsung TSK2792F 27" TV Logo
199 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
