Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
Purge pump removal
How is the purge pump removed from an Echo CS-341 saw without breaking it?
  • 3 Answers
By studying an exploded parts diagram found online, I determined that it snapped out the top before the bracket slid out the front.
Posted on Jan 30, 2009
Purge bulb not working on echo pb-500t,gas leaf blower
get a new primer bulb and diaghram and rebuild your carb or buy a new carb,same price,gas and ethanol and oil kill carbs, echo A021000781
Echo PB 230LN 05001001 05020818 Handheld Parts
May 26, 2015 | Echo Garden
Is it ok to use 87 octane in my echo cs-341 chainsaw
you should always us at least 89 octane for all small engines try and mix smaller batches if nec thin it out with more gas a burn it threw your mower
Jun 20, 2012 | Echo Garden
What octane should i use for my echo cs-341
high octane is no good for valves in older cars you should try to run 89 i8it will burn cleaner yet 87 is not a major difference would only soote up over time at worst yet if you can run 89 do it. Better safe than sorry or talk to a workshop about an octane booster addidtive.
Jun 20, 2012 | Echo Chainsaw Cs-341 With 14 Inch Bar
Code p0440 code p0441 code p0446on toy echo 2000 what is the diagnosis?
P0440 Evaporative Emission Control System Malfunction P0441 Evaporative Emission Control System Incorrect Purge Flow P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
  • Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
  • Inspect the EVAP system for cuts/holes in tubes/hoses
  • Inspect for damaged or disconnected hoses around the Evap purge solenoid
  • Check and/or replace the sensor
  • Check and/or replace the purge valve
  • Have a professional use a smoke machine to detect leaks
Aug 19, 2011 | 2004 Toyota ECHO
Have codes P0441, P0442, and P0446. What could be the problem?
this obd2 trouble code table can help you understand the meaning of code.
and for p0441, you can try:
Repair damaged EVAP lines or canister.
Repair open or short in voltage feed circuit to Purge Solenoid.
Repair open in PCM purge command circuit.
Replace purge Solenoid.
Replace vacuum switch.
Repair restriction in Evap line or canister or soleniod.
Repair resistance in purge connector.
Replace PCM.
for p0442
Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
Otherwise, replace the gas cap, or
Inspect the EVAP system for cuts/holes in tubes/hoses.
Aug 15, 2011 | 2003 Toyota ECHO
How do I replace the purge pump on thr Echo chain saw model CS 3000
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Jun 12, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How to replace primer bulb on small echo gas chain saw.
I just replaced the primer bulb on my Echo cs-305.
I didn't find the parts list too helpful.
It's easy. All you have to do is remove the air filter and look at the existing bulb from the bottom-- you can reach in with a screwdriver and pop the 'feet' holding it in place off their catches. When I put the new one in, I attached the tubes using a pair of needlenose pliers.
Apr 04, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo cs3450, how to replace purge pump
The IPL (exploded parts list) for your saw can be found here:
EchoUSA
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
Page 8 is the fuel system detail. Compared to most manufacturers’ this is a novel, a good one. Use it as a guide, it doesn't look to difficult. Take extensive notes and digital photo or two may pay huge dividends. HTH
Lou
Sep 28, 2009 | Echo Garden
Echo cs-341 stalls out when cutting sideways
Make sure the fuel filter is indeed attached to the fuel line in the tank and pushed down to the bottom of the tank.
Mar 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
509 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
