Question about Dell 3100cn Laser Printer
We have a dell 3115cn, the automatic feeder on the top of the all-in-one sticks and sometimes pulls more than one page thru the feeder at a time. what can i do to fix the problem?
  • aickes Jan 29, 2009
    printer is less than 1 year old! - should the rollers wear out already?
    printer is only a little under a year old - should they wear out already??
    Sergeant:
  • 250 Answers
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Posted on Jan 29, 2009
How can reset all setting dell 3115 cn
"Here is what I did to reset the Dell 3115cn Laser Printer. In the users manual for the 3115cn in section 6 "Changing System Settings" "Resetting Defaults" refers to page 64 where it says, " For more information, see "Reset Defaults" in the User's Guide. Only I did not get a User Guide with my Dell. So I Googled "3115cn user guide" and downloaded it to my desktop and then went to Resetting Defaults. In the attachment "Initializing NVRAM for Network Settings" is what I did. Hope this helps someone else."
May 07, 2014 | Dell 3115cn Multifunction Color Laser...
My Dell 3115cn MFP prints 3 blank pages between prints or copies if I print more than 1 copy how do I fix this? What is causing it?
I will do first a full printer cleaning, that mean take off all dust and anything can that can be inside the printer (ex.bugs and dirt accumulation).
Second try to locate the printer rollers and check if they are in good condition.Printer rollers need to be in good condition because those are the parts that move the paper inside the printer.
Also when you feed the papers into the feeder make sure you air the paper so they don,t stick together.
May 07, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
Have a dell 3115cn when copying from tray a line appears in the center how to remove line
lift document feeder cover, you will see the large glass surface, to the left of it there is a strip of glass about 2 cm wide. This is where the scanning from document feeder occurs. Clean glass with alcohol or glass cleaner
Apr 16, 2013 | Dell 3115CN
ADF on model 3050 is jammed, how do you unjam it?
Automatic Document Feeder (ADF) jams are usually caused by a worn separation pad. This small parts keeps the printer from pulling more than one page thru the feeder. When the pad gets worn the pages slip and the printer gets several pages at one time and this is where the jam comes from. The parts you need is HP RM1-0890 it is available on the web at places such as here: http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_52&products_id=139
I hope this helps, if so please rate our solution.
BuddyMc
Jun 09, 2010 | HP LaserJet 3050 All-In-One Printer
I have a dell mfp 3115cn copier, fax, scanner. Th...
the fault is a mark on the glass over which the paper passes when being copied. it is the rectangular glass that is probably only 1cm wide but the full A4 length across the screen. Clean the mark off this thoroughly and voila, fixed.
Bristolprinters Ltd - with compliments!
May 21, 2010 | Office Equipment & Supplies
Dell 1815dn jam in automatic document feeder on last page.
Message saying document Jam but can't find any paper stuck anywhere. Do you have any suggestions?
Feb 06, 2010 | Dell 1815dn All-In-One Laser Printer
Scanner excludes front page
This is not the only solution, but this might help.
Put a blank page in as the first page and see if all of your documents scan completely.
You may need to clean the ADF. Try the following:
Cleaning the Automatic Document Feeder
You may need to clean the ADF feed mechanism if your
documents do not feed easily into the ADF, or several feed in at the
same time.
To clean the ADF:
1. Dampen a soft cloth with some isopropyl rubbing alcohol
(95%).
2. Press the ADF cover release on the top left of the scanner body
to open the Automatic Document Feeder cover.
3. Wipe the feed roller from side to side. Rotate the roller to clean
its entire surface.
4. Wipe the pad from top to bottom. Be careful not to snag the
cloth on the springs on either side of the pad.
5. Close the cover when you’re finished.
NOTE: Please be careful when cleaning the roller. The roller is
designed to rotate in one direction only. As you’re cleaning the
roller, make sure it rotates easily, and continue rotating it in that
direction while wiping it clean. Do NOT force the roller to rotate
in the opposite direction. Forcing the roller to rotate will damage
it, and may cause the scanner to feed pages incorrectly.
Please let me know if this has helped and thank you. Binary Bob
Dec 05, 2007 | Xerox DocuMate 252 Path-Through Scanner
Dell 3100cn Laser Printer Logo
245 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
