Question about Amana DK25 Dehumidifier
Should I clean or replace the air filter?
Is there an easy way to clean the detachable air filter on the dehumidifier, or is it supposed to be replaced periodically? I've tried to clean it by picking off the dust by hand but that takes forever. I'm afraid washing it with water will ruin it.
You can wash the filter with water, no problem. However, I would recommend replacing the filter every 3 to 4 months depending on how much you use the dehumidifier. The exposure to constant moisture will cause the filter to grow mold over time.
Posted on Jul 27, 2007
SOURCE:
How do you clean the air filter?
Here's a link to an article written by a service technician with more than 30 years of experience. It gives details on How to Clean Dehumidifier
Feb 20, 2016 | LG Dehumidifiers
Why is my dri-eaz drizair 1200 dehumidifier freezing over?
There are two major causes of a dehumidifier or air conditioner to freeze up the evaporator coil. First is lack of air flow try cleaning or replacing the air filter if it has one; make sure the fan is running and the coils are clean. Second is a low charge of refrigerant requiring a refrigerant leak check; repair and recharge. A slight overcharge will keep a dehumidifier from freezing in cooler ambient temperatures.
Sep 25, 2014 | Dehumidifiers
What should I do when the air filter light comes on?
Good Afternoon Friend, that's a great question!
Typically the FILTER RESET light will illuminate after 250 hours of operation. To locate the filter, remove the bucket and the pull filter downwards. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions. Hope this helps! - Z
Sep 11, 2014 | Frigidaire FDL50R1 Dehumidifier
When turned off, makes a humming sound which it never did before. Can I ignore or do I need to fix some?
I understand your Frigidaire dehumidifier, model# FAD704TDP, is making a humming sound, when it is turned off. I also see that you have tried cleaning the filter and grill already, and want to know if there you should be concerned about this. You should not be alarmed by this. Providing, your dehumidifier is doing what it is supposed to do, and is taking moisture from the air, your appliance sounds like it is working fine. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire FAD704TDP Dehumidifier
Hello , I have goldstar dehumidifier model #DH40 . It's freezing from back grill? Can you please give me some solution to it? Thanks for you're help
It sounds like not enough air flow. clean the filter. I would suggest unplugging it and let it set for a day to dry out then replace filter and clean the air path including coils.
Jan 10, 2014 | Frigidaire FAD704DUD Dehumidifier
Dehumidifier doesn't turn on
possible bucket full switch is actuated??
Aug 11, 2017 | Danby Dehumidifiers
My Danby DDR583R dehumidifier no longer dehumidifies unless I set the humidistat to the lowest, constant run setting--then the compressor kicks on. The humidity reading says 14% which I know to be...
There are a several things that can mimic a faulty humidity sensor.
1. The air intake filter is clogged and needs to be removed and cleaned.
2. The coiling coils need to be cleaned.
3. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If the above fails to help solve the problem, replacing the Humidity Sensor is certainly an option. But, before you jump into it, make sure you have an accurate wiring diagram, so you know which sensor is which. As the part does not come with installation instructions.
I hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | Danby DDR583R Dehumidifier
Esco Oasis 2700L dehumidifier ices up. Is there a filter to be cleaned and if so, how to I get to it?
The most common cause of frost and ice buildup on a dehumidifier is because the unit is operating in temperatures that are too cold. Many dehumidifiers are not equipped to run at temperatures below 65 degrees Fahrenheit.
To fix this problem, Position the dehumidifier in an area where there is at least one foot of clearance around the unit in order to allow for proper air circulation during its operation. Close all windows, doors and other outside openings to make sure your unit isn't attempting to remove moisture from areas outside of the immediate room. Determine the temperature of the room by checking a nearby thermostat or by using a hand-held thermometer.
Check the filter for dirt and buildup. Unplug the unit from the electrical source and check the filter by opening the filter compartment. If the filter is dirty, it will restrict airflow through the unit and lead to freezing. Soleus recommends lightly vacuuming the surface of the filter to remove dirt. The filter also can be washed in warm water if it is extremely dirty. Once clean, place the filter back in its compartment. Allow for the ice to melt and then restart your dehumidifier.
Jul 03, 2011 | Dehumidifiers
I am getting a 01n code on display..is this an easy fix?
Yes, it's easy to fix. Turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the air intake filter and clean it. You can vacuum it or wash it. If you wash it, use warm water and dish washing liquid. Rinse and allow it to thoroughly dry before reinstalling it. DO NOT operate the dehumidifier without the filter installed.
The above should take care of the O1N Error Code.
Jun 26, 2011 | LG LHD459EL Dehumidifier
Hi Fixya: The Filter on my Danby DDR7009REE Room dehumidifier never seems to accumulate any dust. It is supposed to need to be cleaned every two weeks by vacuuming or soaking, but the filter is always...
How often does the unit run? Does the fan run when the unit is suppose to be running(as the fan pulls the air thru the filter). If every thing operates correctly and the filter is in the right location on the unit then all I can say is that you keep a clean house. Personally I only need to clean the air filter on my dehumidifier about once a summer. I wouldn't be overly concerned if it isn't getting very dirty.
Nov 10, 2009 | Dehumidifiers
Amana DK25 Dehumidifier Logo
420 people viewed this question
Top Amana Dehumidifiers Experts
jasbo
jasbo
Gil Shultz
DryDog
Level 1 Expert
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
