Question about One For All URC-3021 Remote Control
I need codes and instructions for programming two oneforall remotes. One for a Magnavox TV and the other one is for a Hitachi. Can't find a setup button.
  • ravinloonati May 04, 2009
    need code for magnavox tv have urc-8811B00 ONEFORALL REMOTE
  • Anonymous Mar 22, 2014
    Oneforall remote older Sony tv codes and instructions on how to program on remote
I don't know how to use the ONE FOR ALL remote control URC3021BOO. So I need setting up instruction.
Posted on Jan 29, 2009
I need instructions on how to program my oneforall TV remote
Posted on Feb 21, 2009
I need the code for my oneforall urc3220 for my philips/magnavox tv please
003,004,026,038,019,083. Check these codes. If you wish to get more setup codes, check this link. Pull up older posts there. Setup code list, and setup proceedings to some popular model remote controls are given.
Mar 02, 2013 | Televison & Video
NEED set up CODES FOR MAGNAVOX TV
Many One-for-All remote manuals and code lists are available here: http://www.oneforall.com/support/manual . Fill in Universal Remote Control and then the model number in the drop-down menus. Then click on the link to the manual. (It's a pdf so you'll need Adobe Reader or a similar program.) The direct link to the URC-6131N manual (English version) is http://www.oneforall.com/uploads/support/9e15c67cf9731f8b8e9b376352f23493.pdf .
Try the following codes: 0054, 0030, 0179, 0024, 0186, 0187, 0386, 1254, 1454 for Magnavox TVs. Please note that universal remotes usually only have codes for devices released at least 6 months before the remote was programmed. If your TV is newer than your remote, you may need a newer universal remote. The URC-6131 gives it a date of Feb 2003.
I hope this helps.
Sep 22, 2011 | Universal Remote Control URC-6131N Remote...
Codes for oneforall
It is my pleasure to guide you.
Look through these. I hope what you need is here.
Manufacturer's Codes
Setup Codes For Cable Boxes
Setup Codes For Cable Box/PVR (or DVR) Combos
Setup Codes For DVD Players
Setup Codes For DVD Player/VCR Combos
Setup Codes For PVRs (or DVRs)
Setup Codes For Satellite Receivers
Setup Codes For Satellite Receiver/PVR (or DVR) Combos
Setup Codes For TVs
Setup Codes For TV/DVD Player Combos
Setup Codes For TV/VCR Combos
Setup Codes For TV/VCR/DVD Player Combos
Setup Codes For VCRs
Please post back which one is yours with Serial number and Mfg.
Setup Codes for DVD Players such as Magnavox 0503, 0539, 0646, 0675, 0821,1268
Jun 05, 2011 | One For All URC4220 Remote Control
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
Need remote code for urc-3220 remote for phillips-magnavox tv
Here are the codes for the Tv.
Magnavox 0054 0030 0179 0187 1254
Philips 0054 1354
Or you can get the manual and codes on this link below.
http://www.oneforall-na.com/remote.php?type=URC3220
Good luck
Nov 14, 2010 | Televison & Video
How do i program a oneforall remote control to a magnavox tv and the code for it?
Here is a link to the programing instructions for your One For All URC-4021 remote control. The file is in .zip format and will need to be extracted after downloading. Magnavox codes are as follows: 0054, 0706, 0030, 1454, 1254 (according to page 20 of these instructions)
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc4021expert4&kw=&st=&ar=&dt=&so=&pg=3&file=others/one_for_all/urc4021-manual.zip
Jan 06, 2010 | One For All URC-4021 Remote Control
I need the code for my oneforall remote to program it on a magnavox TV
try these codes taken from ONE FOR ALL URC6012w remote control it might work , good luck AJ
0054 , 1254 , 0030 , 0179
Nov 23, 2009 | Philips Magnavox 20MS3442 20" TV
Oneforall remote urc-3021B00
i need the instruction for my OneForAll Remote URC3021B00 i have all the codes needed for any tvs
Jun 28, 2008 | Televison & Video
Remote code
I have a goldstar tv and a oneforall remote and need the codes so I can program my remote,thanks.
Dec 08, 2007 | GE JASRM24912 Remote Control
Is it multiregional
Sony are probably the most protective manufacturer of this kind of information. All manufacturers carrying a DVD logo are obliged to say "no" but will normally intentionally leak this to boost sales, particularly in non-US areas.
But try this:
  • Press the DVD button
  • Hold down the Magic button until the unit performs a double LED flash
  • Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option 3. On your DVD recorder, using the official Sony remote, select the Setup option 4. On your DVD recorder, using the official Sony remote, select the Options option 5. On your DVD recorder, using the official Sony remote, select the Command-Mode option 6. On your DVD recorder, using the official Sony remote, select the DVD1 option 7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover 8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player 9. Program your OneForAll remote with the following instructions:
  • Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
  • Press the Magic button once
  • Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
  • Press the 1 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
  • Press the 2 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
  • Press the 3 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
  • Press the 4 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
  • Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode 15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 16. Your DVD player should show the words TIMER OK 17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 18. Your DVD player should return itself to Standby mode 19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Nov 27, 2007 | Sony DAV-S500 System
One For All URC-3021 Remote Control Logo
559 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
