Question about HP Color LaserJet CM4730f MFP - Multifunction - laser - copying : 30 ppm / 3... Printer
Having problem with out going faxes. Customers not receiving. HP CM4730 MFP
    Problem Solver:
  • 16 Answers
You need to set your fax settings differently. Print out a MENU MAP (menu,information,config pages, menumap) and find these settings....ECM to ON JBIG to OFF V34 to OFF and MAX BAUDRATE to 14.4. After those are set you need to upgrade to latest firmware
Posted on May 14, 2010
HP 1217 M1217 nfw MFP won't receive fax
Having the TAM set to four rings seems a bit high to me. Decrease the ring count on the Tam. the fax ring count does not really matter.
Keep your outgoing message to a minimum . if too long the calling machine will time out and drop off the line.
see how that goes. Also are you using the genuine adaptor lead. Does the tam actually ring? I suspect not. there are literally loads of adaptor leads that will fit and look the same but they are wired internally for that make only.
Jan 25, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
I had received mms from my message key is MSG.67.4073 how can i open on my net..??
Dear kunal89rkl
Hope you have 3G enabled in your mobile, if so you could be able to open the mms.
Feb 04, 2012 | HP COLOUR LASERJET CM4730 F MFP Printer
HP Color Laserjet CM4730 Scanner Not Initializing
I had an issue similar to this and it was fixed by replacing the memory dimm on the bottom of the formatter.
Nov 17, 2011 | HP LaserJet 4730 MFP Printer
My HP cm4730 won't make make copies, It still prints fine
have a professional take a look at it to see whether there is any internal damage that disallow for copies to be made.
Jun 11, 2010 | HP LaserJet 4730 MFP Printer
Magenta pin stripe on HP-CM4730 crossing the full length of page.
Replace the magenta cartridge or replace the plastic clear guide on underside of document feeder if happening using the document feeder
Jan 13, 2010 | HP LaserJet 4730 MFP Printer
HP laserjet M1319f MFP "no fax detected" error
I had the same problem and just solved it by going into Setup - then Fax Setup - then All Faxes - Then Speed - and lowering the speed from fast to medium. Sure it's a couple seconds slower, but it finally works!!!
Dec 02, 2008 | HP LaserJet 3015 All-In-One Printer
Hp laserjet m2727nf mfp - fax errors - sending and receiving. comm error 350, and comm error 232. Dedicated fax line. Any advice?
Check if you have the latest firmware for this multifunctional on, installing newer firmware fixed communication problem for us.
Apr 17, 2008 | Office Equipment & Supplies
Receiving faxes with a Cisco ATA 186
More investigation implies that faxing over VoIP, as I am doing, requires setting the fax BAUD rate to 9600 bps or slower. So does anyone know if it is possible to set the BAUD rate on the Dell MFP 1600n multifunction printers?
Feb 22, 2008 | Epson Stylus Multifunction Inkjet Printer/...
HP Color LaserJet CM4730f MFP - Multifunction  - laser - copying : 30 ppm  / 3... Printer Logo
110 people viewed this question
Ben Johnson
