Question about Cutler Hammer Cutler-Hammer No.BR48L125RP 125A Out Load Center
Need wiring info for cutler hammer C25DND330 30amp fire shunt breaker...need to shunt 4/220's and 1/110 can you help
  • 565 Answers
Probably easier and about the same price to just buy a shunt trip main breaker. IIRC, code usually requires that anyway.
As far as the c25dnd330, it's just a regular 3 pole contactor, each pole is good for 30 amps. The three poles are L1,2,&3>>>T1,2,&3. The other two contacts are the control coil. I believe your model is 120 volt (most are)....the voltage should be stamped somewhere near the contacts.
Posted on Jan 29, 2009
  • Bob
    Bob Feb 21, 2009
    Thanks for the positive feedback and taking the time to vote.
What voltage and amperage is required to trip a shunt trip unit
The circuit breaker will have a shunt trip voltage & current ratings, a variable current selector knob, etc. - based on the type breaker (Catelog number). Here is a link to images of C-H shunt trip devices and circuit breakers
cutler hammer shunt trip circuit breakers parts Google Search If you can provide the catelog or model number - I 'll be able to provide add'l help.
Mar 11, 2014 | Eaton Electrical Supplies
Cutler Hammer 15 amp circuit breaker keeps tripping
No - because this will cause the electrical wiring to overheat which could cause a house fire.
This may be helpful:
Basic House Wiring Circuits and Breakers
If a circuit is over loading then it may be because there are too many devices on the circuit which could be solved by removing some of the load, or an additional circuit may be installed for specific devices, such as a microwave oven etc..
Jun 29, 2012 | Cutler Hammer Electrical Supplies
Arc fault breaker trips when you turn florescent and can lights on
Sounds like something is wrong with the light check the wiring. Unhook the light and try ther breaker if breaker does not trip then problem is in the circuit.
Jul 24, 2011 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
Cutler Hammer 20 Arc Fault breaker for bedroom outlets will not reset after activating test switch.
The circuit breaker must be turned to the "off" position first from the middle position, and then to the "on" position. The cutler hammer arc breakers carry a lifetime warranty so if it will not reset you may want to contact the manufacture.
Oct 24, 2010 | Cutler Hammer BR120AF BREAKER CIRCUIT BR 1...
For 240 if it is a single pole breaker then no. You need a double pole breaker or 2 single breakers , one above the other, connect the red wire to one and the black wire to the other. this way you are drawing from both legs. hope this helps you...
Sep 15, 2009 | Cutler Hammer Eaton Electical #BD3030...
Cutler Hammer Cutler-Hammer No.BR48L125RP 125A Out Load Center Logo
465 people viewed this question
Top Cutler Hammer Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Cutler Hammer Hammering Expert? Answer questions, earn points and help others
